Old 02-01-2013, 05:23 PM   #1
kenlee
Member#: 49341
Default recommend a pad/product combo for deep scratch removal.
I have a few deep scratched from the neighborhood cats using my car as a perch. I have tried a lake county orange pad and megs 105 on it but that hasn't helped much. I'm looking for an aggressive pad/ product recommendation. I'd prefer to go this route instead of wet sanding if at all possible. Thx.
kenlee is offline   Reply With Quote
Old 02-01-2013, 06:11 PM   #2
whd1736
Member#: 287690
2006 Saabaru
Red
I would try menzerna fg400 with a microfiber pad.
whd1736 is offline   Reply With Quote
Old 02-01-2013, 07:19 PM   #3
tdekany
Member#: 144035
2015 Outback
Tungsten
Can you feel the scratches with your fingernail? Could you post some pictures of the area?
Thanks
tdekany is offline   Reply With Quote
Old 02-01-2013, 09:29 PM   #4
kenlee
Member#: 49341
I'll try to get some in the morning when the sun is out.
Old 02-01-2013, 09:50 PM   #5
tdekany
Member#: 144035
2015 Outback
Tungsten
Sounds good, or you can use a flashlight in the garage.
Old 02-01-2013, 10:27 PM   #6
IAMDABROODWICH
Member#: 306280
Try using Menzerna PG1000 on a microfiber pad, or a wool/microfiber combo pad. Also, I believe Meguiar's now sells M101 and M100 which I think are more aggressive.
IAMDABROODWICH is offline   Reply With Quote
Old 02-02-2013, 02:24 AM   #7
d0ugch0i
Member#: 198861
2004 WRX
a pic of the scratch would help a lot since most of us dont know how bad the scratch really is.
d0ugch0i is offline   Reply With Quote
Old 02-02-2013, 05:22 PM   #8
kenlee
Member#: 49341
ok, I tried to get a good photo of the scratches, however it is not showing up on my camera, (8mp). I am going to try again tonight with a light and see if it will capture the scratches better.
Old 02-02-2013, 07:57 PM   #9
05legsleper
Member#: 334524
05 lgt
regal blue pearl
i had some pretty deep scratchs i took mine out with 3m compound, with a white pad ( foam ) then used step 2, 3m with a black pad.. they came right out ... if you can feel them with your finger nail... you wont get them out, you'll have to sand them out... and if there down to the primer or metal you can never get them out unless you repaint that fender, or q panel..
05legsleper is offline   Reply With Quote
Old 02-03-2013, 04:44 PM   #10
whd1736
Member#: 287690
2006 Saabaru
Red
Old 02-04-2013, 02:02 PM   #11
AspenScoob255
Member#: 217405
2006 WRX
Like tdekany said, can you feel it with your nail? If so chances are you won't be able to remove it without sanding, and even then it's questionable.
AspenScoob255 is offline   Reply With Quote
Old 02-04-2013, 03:09 PM   #12
itstony
Member#: 253911
1999 2.5rs
black
Try either with an MF pad. i've had great luck with heavy swirls and light scratches with FG400 since the work time is longer than M105
itstony is offline   Reply With Quote
