Welcome to the North American Subaru Impreza Owners Club Tuesday March 19, 2024
Old 02-01-2013, 08:42 PM   #1
eagle98ak
Member#: 49526
2006 20GXTR 6spd Wgn
SGM
Default 2006 WRX 20G-XTR Dyno Tune
Dyno tune
Where? Cobb Tuning Plano, TX
Temp Upper 60s
Weather. Clear
Car. 2006 wrx wagon
Tuner, Calvin @ Cobb
Trans. 07 sti six speed. Stock gearset.
Gear. 3rd
Max power. 353 @ ?rpm
Max tq 339 @ ?rpm
Stock wrx on this dyno ??/??
Target boost 21 psi
Target afr. Unknown.
Fuel. Pump 91 octane.
Engine mods.
Blouch 20gxtr turbo,2.4 inlet, 8cm hotside. Killer B header,
DIY TGV delete's, dw850's, walbro 255,
Process West TMIC, grimmspeed 3 port bcs, Samco Inlet,
Ported intake manifold, Cobb intake, Helix catted 3 inch DP,
Mad Dad 3 to 2.5in mid pipe, and Prodrive axle back.
Here is the graph.
So far pretty happy with the tune. Huge improvement over my old VF-39. Nice smooth power delivery.
eagle98ak is offline   Reply With Quote
Old 02-01-2013, 09:55 PM   #2
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
What did your VF39 make? Can you post the plot?
Old 02-01-2013, 10:07 PM   #3
Slimsti
Member#: 155696
2007 BLK STI Dom3XTR
415/405 Precision Tuning
Wow man that looks really nice. Smooth power delivery, great spool and it holds the power well. Very nice. You must love it. Get some meth or e85 and crack 400. Lol
Slimsti is offline   Reply With Quote
Old 02-01-2013, 10:41 PM   #4
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
2.5 hybrid 367whp/363wtq
Looking good!
shadowmd is offline   Reply With Quote
Old 02-01-2013, 10:49 PM   #5
Android287
Member#: 180861
2005 IAG Closed Deck
Larry's Power built heads
Nice set up! Was the pull def done in third gear?
Android287 is offline   Reply With Quote
Old 02-02-2013, 07:13 AM   #6
eagle98ak
Member#: 49526
SGM
Thanks guys.
The 39 was never on a dyno, so no plot for you.
Yep pull was in 3rd. Calvin said with the 07+ 6 speeds he uses 3rd because of the taller 4th and 5th gears.
Old 02-05-2013, 08:02 AM   #7
NoGraffix
Member#: 276209
I am Rub
Function>Form
How long do you expect the engine to last?
NoGraffix is offline   Reply With Quote
Old 02-05-2013, 04:33 PM   #8
shano
Member#: 223839
2004 WRX
Java black
Nice graph, looks like a fun ride.
Full boost at 4000rpm on a 2.5l, I can't imagine a 2.0l! (probably 4500 lol)
What would a normal 20g without the xtr reach full boost? 200-300rpm later?
shano is offline   Reply With Quote
Old 02-06-2013, 06:51 AM   #9
eagle98ak
Member#: 49526
SGM
NO idea. I guess it will last as long as it lasts.
Probably negligible difference between the XT ans XTR. Keep in mind it does spool faster on the street. Not a lot faster, but faster nonetheless.
Old 02-06-2013, 01:35 PM   #10
k04sti
Member#: 171773
04 wrx sti
jbp dom 3 xtr w meth!
That all depends on maintenance, how you drive, and the tune. As long as you take care of your car it can last.
k04sti is offline   Reply With Quote
Old 02-06-2013, 08:56 PM   #11
some dude
Member#: 100300
06 WRX
CGM
Very nice graph! Good amount of stable torque in there and hp pretty much climbs to the end. How does it feel? Congrats as well, post some pics of the car.
some dude is offline   Reply With Quote
Old 02-07-2013, 11:45 AM   #12
AndreBakhtin
Member#: 346280
congrats man! looks very good. Could you post some pics of the car?
AndreBakhtin is offline   Reply With Quote
Old 02-10-2013, 02:21 AM   #13
LightningLemke
Member#: 254371
2003 WRX, Sedan
Platinum Silver
Just out of curiosity, do you know what effect a 3" inlet housing would have in terms of power/ spool? I am thinking of purchasing a about the same sized turbo, Dom1.5xtr-ts, for my stroked Ver.8 ej207 but I am having a hard time figuring out what the advantages of going with either inlet housing would be.
Otherwise the graph looks awesome and I hope I have near the same results. Although I have been thinking about going w/ e85 as well, which would be a whole different ball game lol.
-Luke
LightningLemke is offline   Reply With Quote
Old 02-10-2013, 12:40 PM   #14
wildt267
Member#: 161812
06 Wrx STi
CGM
I'm sure a 3" inlet wouldn't hurt. It seems on some turbos it makes a big difference in spool. There is a thread of here from the guy that ran Deadbolt Turbos. He did some testing on the 2.4 vs 3" inlet on an Sti and concluded the gains in spool they saw had more to do with having to do tgv deletes to get the compressor cover to fit than having a 3" cover. I don't have empirical evidence but I bet it would make a difference on 60 lb/ min turbos in a rotated setup.
wildt267 is offline   Reply With Quote
