Old 02-02-2013, 12:30 AM   #1
MRF22
Member#: 210516
2005 Sti
AW
Hello,
I have a 2005 STi and I will be swapping exhausts soon.
Current set up: Tomioka UEL header/up-pipe combo.
4" cat-less DP
3" TurboXS "cat" back
320whp and 330 wtq @ 16psi on Tomioka TD05 18G
I will be swapping the TurboXS cat back to an OEM STi cat back. So I will still be catless.
I will get a retune.
Questions:
1. What will it sound like?
2. Will I be able to say around 300whp and 310wtq?
Oh and I do have cobb intake, turbo inlet, and EBCS.
I'm looking for decent power but quieter for highway and city drive ability.
Thank you.
MRF22 is offline   Reply With Quote
Old 02-02-2013, 12:36 AM   #2
Tdaz250
Member#: 310744
02 WRX
Pretty sure you don't even really need to retune if your just swapping catbacks.
Tdaz250 is offline   Reply With Quote
Old 02-02-2013, 01:03 AM   #3
MRF22
Member#: 210516
2005 Sti
AW
Really? I thought I would be running a tad rich. Which would see a drop in mpg's.
thanks for the response.
Old 02-02-2013, 01:39 AM   #4
RoadKillDMD
Member#: 284792
2011 STI
Blurple
No tuning is required for swapping catbacks.
It would be absurd if you even lost 5whp doing this. It adds a bit of backpressure, but not enough to make a huge difference. If you're willing to do so, dyno your car before, then after the swap, and see for yourself.
RoadKillDMD is offline   Reply With Quote
Old 02-02-2013, 02:04 AM   #5
MRF22
Member#: 210516
2005 Sti
AW
Cool thanks. You ever heard a set up like this? I looked at a few on YouTube but they all sound tinny and high pitched. Maybe it's just bad camera.
Old 02-02-2013, 12:12 PM   #6
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Sound is different and relative to everyone. We cannot tell you what it will sound like. I had a similar setup on my 04 YEARS ago and liked it, but others did not.
No retune is needed for a catback. There is nothing in that part that will change a single bit of your AFR. If you are worried about the power you put on a dyno, don't switch your exhaust.
Old 02-02-2013, 01:13 PM   #7
MRF22
Member#: 210516
2005 Sti
AW
I want as close to stock sound as possible.
Thank you for the info regarding the tune.
Old 02-03-2013, 07:07 PM   #8
Tdaz250
Member#: 310744
02 WRX
Lots of people run an aftermarket down pipe with the stock catback. I personally like to hear mine, i have invidia n1 and catless dp.
Old 02-03-2013, 07:59 PM   #9
Leafy
Member#: 330625
2006 WRX
It will increase the back pressure, you will gain some spool up time. If your tune is pushed to the limit spark wise (practically no sube tune is, which is a shame) at least log it for a while to make sure the added back pressure hasnt lowered you knock limit.
Leafy is offline   Reply With Quote
Old 02-03-2013, 10:29 PM   #10
MRF22
Member#: 210516
2005 Sti
AW
Ok cool. I will probably get a tune later down the road but as long as I can commute.
Main concern is it being quiet. Lol
Old 02-03-2013, 11:18 PM   #11
Leafy
Member#: 330625
2006 WRX
I wouldnt worry about it too much. With how most subarus are tuned you wont notice anything beside sit being quieter.
Old 02-04-2013, 01:12 AM   #12
synolimit
Member#: 225225
11 WRX
335HP, 394TQ, 93 VF52!!
It's going to sound like crap!! I did it, worst raspy crap ever.
synolimit is offline   Reply With Quote
Old 02-04-2013, 01:21 AM   #13
MRF22
Member#: 210516
2005 Sti
AW
Really!? Dang. That's what I was worried about.
Old 02-04-2013, 01:21 AM   #14
MRF22
Member#: 210516
2005 Sti
AW
What was your set up?
Old 02-04-2013, 01:31 AM   #15
synolimit
Member#: 225225
11 WRX
Durr! OEM CBE, catless dp.
OEM mufflers have no glass packs. It's just chambers of raspy air blowing around back there. Don't do it unless its with OEM dp.
Old 02-04-2013, 01:42 AM   #16
MRF22
Member#: 210516
2005 Sti
AW
So do you think putting a resonator on my current exhaust would quiet it down?
Old 02-04-2013, 02:00 PM   #17
Vrooom_Psh
Member#: 311923
04 STi
Yeah it would, hard to say if it will quiet it down ENOUGH for you though
Vrooom_Psh is offline   Reply With Quote
Old 02-04-2013, 02:12 PM   #18
MRF22
Member#: 210516
2005 Sti
AW
Cool thanks! I'm gonna do a resonator and if that's not quiet enough then ill put in the stock axle back.
Old 02-04-2013, 02:22 PM   #19
synolimit
Member#: 225225
11 WRX
Quite? No, zero. Change the sound? Yes a little.
Old 02-04-2013, 02:23 PM   #20
synolimit
Member#: 225225
11 WRX
2.25" mated to 3" isn't going to really work.
Old 02-04-2013, 02:34 PM   #21
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
I haven't tried it catless, but my catted DP into stock catback on my '12 sounds almost exactly like stock. It's just a hair more aggressive sounding than stock, but barely noticeable.
Old 02-04-2013, 02:47 PM   #22
MRF22
Member#: 210516
2005 Sti
AW
Ya it will work. It's 2.5" and I will be using the Grimmspeed adapter to mate it up.
