Old 02-02-2013, 10:32 AM   #1
kamikami
Member#: 340001
Default Phase 1 gearbox to suit phase 2 engine?
HI all,
About to rebuild my motor and looking at the option of upgrading from my EJ20K to an EJ207 - Now i've just realised my gearbox bell housing is phase 1, it is the 4 bolt style, not the 6 bolt style like the EJ207.
Will it bolt up? Or can it be modified to suit? If so how!?
I have an MY97/98 JDM GC8 WRX, blown bearing from the JDM aggresive ECM.
Regards,
David
kamikami is offline   Reply With Quote
Old 02-02-2013, 12:17 PM   #2
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
Just use the four bolts and it will work fine. Some jdm motors don't have one of the starter holes so you have to put a heli-coil in the trany hole and use a shorter bolt. I'm not sure if that was one of them.
Old 02-02-2013, 01:21 PM   #3
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
I would be worried how long that older tranny would last on the 207.
It might be OK on the lighter GC8 but I would be hesitant to really push a bunch of power
lukeskywrx is offline   Reply With Quote
Old 02-02-2013, 01:38 PM   #4
drewmob
Member#: 214192
2003 WRX
This.
drewmob is offline   Reply With Quote
Old 02-02-2013, 03:04 PM   #5
hail2theTheif
Member#: 42548
2015 Base STi
Black (CBS)
Just an assumption, but being he's running a JDM WRX setup I'm guessing he's running the matching tranny as well. Can't imagine a STi/WRX JDM tranny would have a problem handling the power considering the v3/v4 motors were putting out 280ish.
My old built Version 2 Sti w/EJ257 block put down a good 285hp/330tq to the wheels and the Version 2 tranny is still running strong 5+ years now.
Should be fine if you treat them nicely and take care of proper maintenance.
hail2theTheif is offline   Reply With Quote
Old 02-02-2013, 05:23 PM   #6
amroof
Member#: 211224
2005 Saabaru
Who knows
You should be fine on bolting them together make sure you have the dowells in the right places as well. It will add a little more strength.
amroof is offline   Reply With Quote
Old 02-02-2013, 10:33 PM   #7
kamikami
Member#: 340001
So what do i do about the extra 2 holes on the block side?
Old 02-02-2013, 10:36 PM   #8
kamikami
Member#: 340001
Yes exactly, my EJ20K was a 280ps motor from factory.
Old 02-02-2013, 11:35 PM   #9
drewmob
Member#: 214192
2003 WRX
Seriously??? Nothing.
Old 02-02-2013, 11:52 PM   #10
novacivic
Member#: 117980
2005 sti
wr blue
Exactly
novacivic is offline   Reply With Quote
