Old 02-02-2013, 05:56 PM   #1
vf22Bugeye11
Member#: 272096
2002 6Speed swap wrx
Function Warrior!!
Default front camber suggestions!
Hey guys I just want to improve contact patch when cornering..
My current setup
Tein H Techs with excel g's
Im not looking for crazy neg camber I actually want the lest possible. That will help handling thanks
vf22Bugeye11 is offline   Reply With Quote
Old 02-02-2013, 07:41 PM   #2
Bikelok
Member#: 254851
2002 WRX wagon 5mt
I will assume you do not have slotted struts, or aftermarket camber bolts, or camber adjusting strut tops. Your only option then is to max out the negative camber in the front, EVEN.
The rear is not adjustable, in stock form and is set at approx. -1.5 from the factory.
Stock should get you any where from -1.2 to -1.5 front. So tell them to give you as much as the front will go while keeping it even. Then zero out toe all around.
If you go with any aftermarket item that will get you more front negative camber, then shoot for -2.0 front with the rear at the stock -1.5 range.
Bikelok is offline   Reply With Quote
Old 02-02-2013, 07:45 PM   #3
Bikelok
Member#: 254851
2002 WRX wagon 5mt
Oh, what I mean by even is, perhaps they can get -1.6 front right, but only -1.3 front left. Then they should only go with the -1.3 for both. Both sides EVEN!
Old 02-02-2013, 08:51 PM   #4
04furesterXT
Member#: 73223
2009 STI
Depends on your driving habits as to what's appropriate. Ask a competent tech for their advice.
04furesterXT is offline   Reply With Quote
Old 02-02-2013, 11:46 PM   #5
flk
Member#: 280838
2016 S4/GT4
Agree with Bikelok; ideally you want more -camber in the fronts, opposite of what the factory settings are. You can go with 0 toe all-around, but I have some slight toe-in on the rear to help with stability in high speed/braking.
flk is offline   Reply With Quote
Old 02-03-2013, 02:37 PM   #6
vf22Bugeye11
Member#: 272096
Function Warrior!!
Awesome thanks for the advice. Yes I have all stock components except for rear camber bolts I have those..I have an appointment tomorrow for alignment I will talk to the tech about what you said
Old 02-03-2013, 02:58 PM   #7
vf22Bugeye11
Member#: 272096
Function Warrior!!
So if its decided that 1.3 will be it how bad will that affect tire wear ? From normal driving
Old 02-03-2013, 03:03 PM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
it wont
Old 02-03-2013, 03:15 PM   #9
vf22Bugeye11
Member#: 272096
Function Warrior!!
Originally Posted by Uncle Scotty View Post
it wont
I gotta say one of the nicest responses from you haha thanks
Old 02-03-2013, 05:31 PM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
toe is what will eat tires quick....keep toe at zero and ya likley wont have any irregular wear issues
many of us have run -2.x* camber and had no irregular wear issues.
now...if you do a LOT of highway driving and drive like grandma when not on the highway......then a lot of neg camber may cause irregular wear issues
AND....the particular tires used may or may not be more prone to irregular wear
Old 02-03-2013, 06:08 PM   #11
vf22Bugeye11
Member#: 272096
Function Warrior!!
So toe 0 all the way around and just max out my front stock camber bolts. And the car doesn't see a lot of highway driving since its not my dd. When I do drive it def don't drive like grandma lol . Thanks for the input Mr Scotty
Old 02-03-2013, 06:45 PM   #12
Uncle Scotty
Member#: 16200
OK buy Nates beans
and if ya have the stock front strut tops....get rid of them---they are garbage
and an alk would be great.....and if ya dont have hd cowl stays---get 'em
Old 02-03-2013, 07:17 PM   #13
vf22Bugeye11
Member#: 272096
Function Warrior!!
Awesome new list of parts that will actually improve the handling of my car. Do you suggest any specific brand for any of those parts...I'm thinking white line and for the braces not sure
Old 02-03-2013, 08:54 PM   #14
Uncle Scotty
Member#: 16200
OK buy Nates beans
whiteline com c or camber/caster adjustable front tops...rears arent as important
whiteline is the only one who makes an alk....if this isnt a daily driver, you coud do the 'sport' version and not hate it, i think ...do NOT get the 'motorsport' one
and the hd cowl stays....get em where ya get the rest of it
Old 02-03-2013, 10:29 PM   #15
vf22Bugeye11
Member#: 272096
Function Warrior!!
Sweet thanks for taking the time and helping out
Old 02-03-2013, 10:54 PM   #16
Uncle Scotty
Member#: 16200
OK buy Nates beans
ya wanna know some realativly cheap and easy stuff to do to it, lemme know
you could make the car a LOT better for not too much if ya spend the right $$$ on the right things
most buy the wrong stuff for too much $$$ and chase their asses and dont know it
Old 02-04-2013, 07:07 PM   #17
13BRZltd
Member#: 344145
I ran -2.1 with whiteline bolts on my 03 and the front tires wore pretty evenly. Thus was with an autox about once a month and track day mayne once a year. Id go 2+ if youre doing any of that stuff. Better traction amd better wear characteristics
13BRZltd is offline   Reply With Quote
