Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
South East Region Club
Go Back   NASIOC > NASIOC Regional Areas > South East Region Forum
Old 02-22-2013, 11:50 AM   #26
Turbo Time
Member#: 226988
Like Us on Facebook!
www.turbotime.us
Yes we are.
It is likely that your throttle plate needs a good cleaning (also time to think about catch cans if it doesn't have them already). Gunk build-up on there can cause this exact issue. A look at the tune wouldn't hurt either.
Turbo Time is offline   Reply With Quote
Old 02-22-2013, 12:25 PM   #27
scairkro
Member#: 345832
2005 wrx sti
blue
I got a catch can.....how much u charge for a tune?
scairkro is offline   Reply With Quote
Old 02-22-2013, 06:27 PM   #28
Tru's04
Member#: 132307
'04 JDM YO!!!
Ver 7 EJ207
I would recommend a tune as well. Had the same issue about 4 yrs ago. Checked a bunch of things but finally got it tuned and issue went away.
Tru's04 is offline   Reply With Quote
Old 02-22-2013, 08:10 PM   #29
scairkro
Member#: 345832
2005 wrx sti
blue
Ive been told a thousand different things....bad tune, vacuum leek, dirty iacv....ill get it all looked at eventually...what could disconnecting my battery have to do with it?
Old 02-23-2013, 05:59 PM   #30
SubyRS03
Member#: 245297
2004 WRX vf48 93 oct
Resets the ecu
SubyRS03 is offline   Reply With Quote
Old 02-23-2013, 10:25 PM   #31
Turbo Time
Member#: 226988
www.turbotime.us
If there is build-up on the plate, the ECM will have learned to compensate for the difference in positions. If the battery was disconnected, it would cause the ECM to default back to factory settings, causing it to have to re-learn the variance caused by the gunk and what not.
Old 02-24-2013, 02:04 AM   #32
jenzos
Member#: 90363
2005 Nobro
yeah.....
what he said.
jenzos is offline   Reply With Quote
Old 02-24-2013, 09:54 AM   #33
scairkro
Member#: 345832
2005 wrx sti
blue
I just opened it up to look at the throttle body and it was all very clean...I cleaned it just to be sure, no change. Any other suggestions?
Old 02-24-2013, 10:09 AM   #34
Timmy P
Member#: 134521
2010 WRX Stg 2 +
I highly recommend letting the guys at Turbo Time look at ur car!
There are only 2 shops/tuners I would let touch my car them and Robbie.
Timmy P is offline   Reply With Quote
Old 02-24-2013, 10:13 AM   #35
scairkro
Member#: 345832
2005 wrx sti
blue
I heard robbie a lot. How can I get a hold of him and where is he at?
Old 02-24-2013, 12:02 PM   #36
Turbo Time
Member#: 226988
www.turbotime.us
Have you had it smoke tested?
If you need a tune let us know. We are a COBB pro-tuner and can tune opensource as well. Don't know if you have an accessport or not, but if you're interested in one we have a special going for another week for $50 off a protube with the purchase of an AP. let us know if we can help.
Old 02-26-2013, 04:14 PM   #37
scairkro
Member#: 345832
2005 wrx sti
blue
Had some vacuum leaks. Got them fixed. It only bogs down once or twice after I go in neutral and then idles fine. Im guessing thats just the way its tuned?
Old 02-27-2013, 12:55 AM   #38
SubyRS03
Member#: 245297
Mine does that to but for safety reason I would get a pro tune. That way you know she's running right! And if ur car doesn't already have it get a wide band sensor as well AEM has a really good one for about 150
Old 02-27-2013, 12:56 AM   #39
SubyRS03
Member#: 245297
Ill be getting a pro tune soon as well for the same reason
Old 04-03-2013, 10:46 PM   #40
scairkro
Member#: 345832
2005 wrx sti
blue
Long time since I had an update. Took the motor apart today. Had a blown tgv gasket. Replaced it and its running a lot better. Pretty sure I still need a tune though
Old 04-04-2013, 11:16 AM   #41
SubyRS03
Member#: 245297
Nice happy for you bro! That would a air leak big time!
Old 04-04-2013, 12:33 PM   #42
Turbo Time
Member#: 226988
www.turbotime.us
Wow. Good find!
Let us know if we can help with the tune.
