Old 02-03-2013, 07:57 PM   #1
majik1
Member#: 255841
2005 WTX STi
white
Default Meth installs
Hey everyone please bare all and show me where you mounted your controllers. I was thinking about the glove box for my aem kit. But I don't know where to route the boost line either. I have the 5 gal tank and did you guys just drill holes in the trunk bottom and run bolts through? Also with the pump I don't want a lot of unnecessary vibration, just use rubber piece under it? Thanks in advance for your help!
majik1 is offline   Reply With Quote
Old 02-05-2013, 01:52 PM   #2
majik1
Member#: 255841
2005 WTX STi
white
Nobody has a couple pics of their install?
Old 02-05-2013, 03:50 PM   #3
Mach V Dan
Member#: 12029
Here's a Snow Performance setup we installed in a 2008 STI.
Early on...
Reservoir on the left, pump on the right.
Reservoir
Control box in the glove compartment.
Status and warning LEDs
Hide and seek!
Spare and tools all still fit.
Wiring
I don't have any under-hood pics because everything is hidden, so just imagine a stock engine bay, and that's what it looks like.
--Dan
Mach V
FastWRX.com
Mach V Dan is offline   Reply With Quote
Old 02-05-2013, 06:00 PM   #4
majik1
Member#: 255841
2005 WTX STi
white
That's really sick. I have the aem 5 gal res. the orientation of the pump doesn't matter? And what did you have to do to mount the LEDs in the dash like that? Just drill a hole and glue them?
Old 02-06-2013, 08:41 AM   #5
MD04WRX
Member#: 72891
2014 Molten ST
2000 2.5RS - 2014 XV
Mounted my pump in the spare tire compartment on a (cloth covered) piece of wood. Wood is held down with the spare tire bolt. Spare won't fit over my brakes so it was the best place for it.
MD04WRX is offline   Reply With Quote
Old 02-07-2013, 08:17 AM   #6
majik1
Member#: 255841
2005 WTX STi
white
Do you hear any loud vibrations with that?
Old 02-07-2013, 08:33 AM   #7
MD04WRX
Member#: 72891
2014 Molten ST
None, the pump comes with rubber mounts. I get no noise from the system at all. I don't even hear the pump when it's running.
Old 02-08-2013, 11:20 PM   #8
MWRX13
Member#: 330274
2013 WRX
Pearl
can you turn the spray on and off? sorry new to this... interested.
MWRX13 is offline   Reply With Quote
Old 02-11-2013, 01:12 AM   #9
majik1
Member#: 255841
2005 WTX STi
white
Depending on what tune you run, you have to have it on or off. You can wire every controller to a switch.
