Old 02-03-2013, 10:44 PM   #1
mcu81
Member#: 5796
2013 BRZ & 2004
WRX
Default EJ207 JDM WRX NON-STI specs
Does anyone have the specs on the ej207s the JDM WRX's used from 99-01? From everything I found, while the rest of world used ej205's(aussies, uk, etc.), the JDM WRX had a ej207 during those years.
Thanks!
mcu81 is offline   Reply With Quote
Old 02-04-2013, 12:19 AM   #2
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
not always true..returned from okinawa this past august.
I saw bugeyes with ej205 with avcs.
how did i know it was a 205?
the vin tag had 205 stamped on it along with engine code sticker
on the front timing cover.
Old 02-04-2013, 10:22 AM   #3
mcu81
Member#: 5796
2013 BRZ & 2004
WRX
Jax,
Thanks for that bit of info. It seems theres a boatload of info on each sti iteration, but a lack-there-of on the WRX's.
Old 02-04-2013, 11:48 AM   #4
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
So you are looking for info on the V6 EJ207? The bottom end is similar to the later models and the heads are I believe big port with no AVCS.
For jaxscuby, The JDM 205 had AVCS so that is nothing new and it was not a 207(no semi-closed deck)
lukeskywrx is offline   Reply With Quote
Old 02-04-2013, 11:49 AM   #5
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
