Old 03-14-2006, 01:54 AM   #1
hotrod
Member#: 14141
2002 Impreza WRX
Default < 13.000 registry for TD04 turbos ( quick list II )
I've decided to freeze updates to my old post on quick times for the stock TD04 turbo on :
http://forums.nasioc.com/forums/show...=527449&page=2
As of today 3/14/06, I'm starting this thread for TD04 turbos with sub-13.000 second times, so it is easier to find with common search terms like "registry" etc.
List of fastest known stock turbo new Gen USDM 2 liter WRX
Rules are simple -- You must be running a USDM WRX, with the stock TD04-13T turbo on a stock internals 2.0 L engine.
You must validate your claim with a time slip, date and location of run.
Listing is ranked by ET with earliest date for identical runs ranked first.
P&P is allowed with the stock compressor wheel, but will be noted with an * entry.
Use of Nitrous must be declared. Anything else goes.
IE. WI Alcohol, high octane fuels, weight reduction etc. are all acceptable.
Please post weather conditions with your listing, and relevant mods so others know what works on the stock engine/turbo setup.
For those who can only run 1/8 mile times, conversions will be made using a conversion factor of 0.63505 or 1.57468 to convert from 1/8 <--> 1/4 mile ET's.
IE a 12.999 1/4 mile ET is equivalent to an 8.2550 ET on the 1/8 mile
.. a 13.999 1/4 mile ET is equivalent to an 8.8901 ET on the 1/8 mile
[edit 4/22/06] Timing slips that show obvious timing errors will not be accepted. They will be listed as a near miss,(probable run), if the driver can document other near 13.000 times at my discretion.
Low altitude < 12.99, high altitude < 13.99
Stock Turbo + Nitrous
Overall
STEALTH-WRX
quallcom stadium (8/7/02) 1/8 mile
[email protected] <---- this corresponds to a 11.967 ET on the 1/4
AWD1320 1.563 60'
[email protected] with Nitrous 75 shot 3/23/03
STEALTH-WRX 1.762 60'
12.068 @111.53 With Nitrous 95 shot wet
at fomoso raceway august 10, 2002
BYBYV8 1.786 60'
12.328 @ 110.51
5/11/2002 Atlanta, GA
NOS brand 50 shot single fogger wet kit
Stock Turbo only near sea level (less than 1600 ft altitude)
JaMes W 1.708 60'
12.404 @ 109.67
Ambient Temp: about 65
Weather: sunny, C16 fuel
See link for mods --- http://forums.nasioc.com/forums/show....php?t=1971717
OppositeLock 1.757 60'
(previous best of ) 1.755 60'
12.487 @ 109.45 Atco raceway 28 Feb 2009
Absolute barometer 29.38
RH = 88%
Temp = unknown
(previous best mph [email protected] Cecil County Dragway March 2 2008)
Str8Gone 1.624 60'
12.695 @ 106.71 March 22 2009 Capitol raceway
stock EJ205 TD04 running PPG 1-4 Helical synchro transmission
Tires -17x8.5 slipstreams with kumho allseason 245s with tire pressures around 20-25 psi
car weighed about 2860 #
JaMes W 1.825 60'
12.645 @ 107.46 (ATCO) 12/13/08
Quicktime 1.742 60'
[email protected] Atco 3/23/04
jmlaser 1.838 60'
12.8848 @ 107.14 Dragway 42 11/25/2007
O Stylee 1.739 60'
[email protected] Maryland Intl Raceway 9/20/04
Amazake 1.770 60'
[email protected] New England Dragway 5/19/05
Gadiel 3/20/03
[email protected] Puerto Rico
DFL2.5RS 60' = 1.777
[email protected] Mid Michigan Motorplex (stanton, MI ) 9/27/07
Temps high 60's low 70's
IWRXIT 1.82 60'
[email protected] Bremerton Raceway Wa 4/9/04
Quick scooby 1.86 60'
[email protected] Temple Academy Dragway Tx 2/07/03
Carlo 1.843 60'
[email protected] Atco 5/31/2003
12.9$500rex 1.781 60'
12.989 @ 102.99 US 41 Dragway 12/05/04
Hassassin 1.784 60'
[email protected] Etown 11/15/02
Near miss runs
WRXOFIVE
12.966 @ 101.28 @ Norwalk
Timing slips shows timing errors on the 1000' lights, so not an official time for the list.
WRXOFIVE has documented to me, other low 13 second runs at other strips on other days.
Dug-e-fresh 60' 1.836
13.097 @ 103.11 Cecil County Dragway May 3 2002
JaMes W 60' 1.816
13.071 @ 101.80 Atco 15 Mar 05
Stock turbo only at high altitudes > 3500 ft
For high altitude runs times can be converted to approx sealevel numbers using the 1/2 correction factor for altitude found on the NHRA tech page at:
http://www.nhra.com/tech_specs/altitude.html
For Denver Colorado (Bandimere 5800' altitude) sea level numbers ET = 0.9702 MPH = 1.0281
For Albuquerque, NM (5400' altitude) sea level numbers ET = 0.9725 MPH = 1.0260
Hotrod 60' 1.787
13.239 @ 102.85 Bandimere 6/23/04
Sea level equivalent according to NHRA correction factors:
13.239 ~= 12.844
102.85 ~= 105.74
Dustin AKA moorewrx 1.801 ? 60'
13.633 @99.89 Bandimere 9/23/02
Slatera666 1.883 60'
[email protected] Bandimere 4/17/04
*ported turbo by FP
Thought it would be useful to put this info all together.
Larry
Unconfirmed
marksWRX03 1.796 60'
[email protected] unknown strip, Tampa Fla area 01/17/04
(use of nitrous cannot be determined, as it has been neither confirmed or denied. Only the following stated to be stock, turbo, IC, tranny, clutch, ecu. Using 110 octane fuel, alleged to have been run on a slipping clutch )
Larry
search key words :
registry quick list TD04 TD04-13T TD04-13G <12.9xx 12.9xxx
hotrod is offline   Reply With Quote
Old 03-14-2006, 02:08 AM   #2
Phil Jr.
Member#: 62221
1.56 60'
Phil Jr. is offline   Reply With Quote
Old 04-11-2006, 02:32 AM   #3
sovietjet
Member#: 76600
2008 BMW M3
what kinda mods to these people have such as the high 12 second cars? Cobb stage 2 + some other goodies?
sovietjet is offline   Reply With Quote
Old 04-11-2006, 09:10 AM   #4
hotrod
Member#: 14141
2002 Impreza WRX
Off the top of my head I believe generally they all had, up pipe, down pipe, after market exhaust, some sort of boost control, many have some sort or after market intake, and some sort of tuning. Most were running a high octane fuel. About 1/2 the runs were made in cool or cold weather. Several of us lightened the car by removing some items. A few had upgraded intercoolers, some of us were on the stock tmic.
I don't have an accurate summary handy, but if I get the time one of these days I'll try to put one together.
If you want the details you can look them up by searching on the "user name" and the drag strip time "[email protected]" etc. Usually the oldest thread will be the one where they announce the run, and give mods list.
Here are some of the mods, will add others as time allows
STEALTH-WRX
12.068 @111.53
fomoso
[email protected]
quallcom
stock turbo set at 14 psi but spiked to 17 then settled at 15
stock ecu
stock fuel with walbro gss342 fuel pump
blitz front mount
custom intake
i was running no exhaust
greddy profec b
greddy type s blow off vavle
nos wet kit 45 nitrous/ 28 fuel about 95 hp shot ( never again)
Car was lightened (removed seats etc.)
12.068 @111.53
fomoso
AWD1320
12.052 @ 111.91
stock turbo at 16psi on 110 leaded
75 shot nos
running apexi avc - r running 13lbs and then with the nos it runs a steady 16 lbs to redline
car has a apexi afc for fuel management
650 cc injectors rails (vishnu rails with honda stock injectors that were sent to Venom and changed for 650cc with high imadence instead of the low)
dogbox (gear set is a MRT )
twin disc clutch
front mount
hks headers
drag radials
launched at 5000 rpm and pushed button as soon as the pedal hit the floor
BYBYV8
12.328 @ 110.51
STOCK TURBO at 15 PSI
Injen intake
TurboXS turbo-back exhaust (great piece, GREAT service!)
Hallman MBC
M2 up-pipe
Samco IC hoses
Supra TT fuel pump
Autometer EGT, Boost, and AF meter
Stock injectors, stock ECU, etc.
Oppositelock
UTEC
DSBC
coated header/uppipe combo
catless tbe with 2.5" axleback
Helix TMIC
JDM intake manifold
turbo inlet
CAI
lightened crank pulley
SMC alcohol injection
all group N drivetrain mounts.
JaMes W
93 octane. Cobb ots map
mod list :
Cobb Access Port Stage 2 OTS Injen Intake map
PWR Top Mount Intercooler
Perrin Turbo Inlet Hose
Perrin Intercooler Hose's
Injen Cold Air Intake
Grimm Speed External WasteGate Uppipe/ ceramic coated
Tial 38mm Wastegate
Perrin Divorced WasteGate Downpipe
Perrin Lightweight Crank Pulley
Gruppe-S V2 Header/ Crucial Ceramic Coated
HKS Carbon Ti Exhaust
Koyo Radiator
Samco Radiator Hoses
Hallman Manuel Boost Controller
Blitz High Pressure Radiator Cap
Crucial Coolsafe 160 Degree Thermostat
Ported And Polished Throttle Body
Throttle Body Coolant Bypass
Oem Bypass Valve/ Refinished
Intercooler Water Spray
PPG 1st and 2nd gear
Subaru JDM ver 6 STI 3rd and 4th Gears
Subaru JDM Sti Group N Tranny Mount
Subaru STI Pitch Mount
Kartboy Transmission Cross Member Bushings
Kartboy Short Shifter
Kartboy Shifter Bushings
Goodridge Stainless Braided Clutch line
18" SSR Competition Rims
Bridgestone Potenaza Re760 tires
Quick time
03 WRX Sedan
AEM Short Ram Intake
TXS DSBC
stock TMIC
Greddy S Type BOV
Quick Time Performance Electric Cutout Down Pipe (E-cutout was open!)
Quick Time Peformance Long Tube Tri Y Header
TXS UTEC Dyno Tuned @ Turbotrix
Centerline RPM 17X7 Rims
Nitto 450 225/45/17
Dyno and 1/4 mile was on 93 octane!
Full Weight with spare/jack.
jmlaser
Stock TD04 turbo 91Kmiles
Stage 2 full catless (Buschur Racing CBE) Turbo XS (up), Invidia (down)
Perrin LW crank pulley
Cobb SF intake
IC hoses
APv2
94 Oct pump gas made 233whp/242wtq
C16 made 247whp/276wtq
O Stylee
Helix Downpipe
Helix Uppipe
Borla Hush Cat-Back
Homemade IC Spray
Cobb Stage 2 ecu
Greddy TVVC MBC
sti RA gearset
Homemade Ground wire kit
HKS SSQV BOV
Amazake
GFB pullies
Optima red top battery
Speedmonkee grounding kit
Zero/sports cooling plate
Samco radiator hoses
Samco ancillary hoses
Apex'i short ram intake
Zero/sports intake pipe
Samco Turbo inlet hose
GM boost controll selenoid
Cusco heat shield wrapped in thermotec
Samco intercooler hoses
TurboXS ver II TMIC
SMC alcohol injection kit
Throttle body bypass mod
NGK BKR7E copper plugs
APS 3" to 2.5" turboback with cat
TurboXS UTEC
stock wheels, tires, and lugs
aluminum control arms
Whiteline heavy duty front end links
Whiteline front sway bar
Whiteline ALK
removed A/C
GT-Spec ladder bar
pressed in Group N bushing set
Group N top hats
Sti version 7 struts and springs
Whiteline rear end links
Whitleine rear sway bar
Whiteline subframe lock
Kartboy hangers
Whiteline steering rack bushings
empty trunk
Weather was 60 degrees? mostly cloudy
OppositeLock
'04 wrx
Deg 64f..........69f
Baro 29.57.......29.37
UTEC
DSBC
Helix TMIC
JDM intake manifold
turbo inlet
CAI
lightened crank pulley.
Fuel - 50/50, 93 octane/100octane mix.
Other than taking everything out of the trunk, there is no weight reduction yet.
It weighed 3296 with me in it on the return and I weigh about 210 clothed.
(Tracking down and fixing small boost leaks and the tune are what put me over the top.)
IWRXIT
Turbo stock 19 psi.
Intercooler type--- stock
txs mbc and rfl bov
hks up/dp
megan muffler and cai, custom piping,
cobb stage 2, stock everything else.
Fuel 110 octane leaded
Quick scooby
[email protected]
1/4 tank, no spare or jack and the rest full interior it weighs 3,120 pounds.
pump 93
ecu reflash from vishnu
turboback
uppipe
hoses
k&n
The weather is around high 20's-low 30's though.
Gadiel 3/20/03
[email protected]
temps 90 deg F.
using C16 to lower the EGT.
Utec stage 2 map
m2 up-pipe
Downpipe with cat
Hallman mbc @ 18 psi
Stock cat back
the rest is stock
BBS wheels 17 in
mods are:
uppipe
TBE (exhaust turns down at the rear diff instead of coming out the back)
APS shortram intake.
tuned via opensource by owner
Stock turbo and stock IC and original clutch.
Car is a 2002 5mt WRX with ~108k on the clock.
Carlo
Atco raceway. 5/31/2002
12.981 @ 107.00
List of Mod:
Turbo XS Stage 2 system with 94 octane map. The components of this system can be looked up at www.turboxs.com.
Other Mods:
TurboXS High Performance MBC
tuned Unichip
ATR uppipe
GFB pulley kit
Colder NGK Spark Plugs
Cat-less Mid Pipe
Samco IC Hose kit
Grounding Mod
Silencer Removal
Filter Removed from Airbox (racing only)
Knife Back & Porting of Throttle Body
Cleaned up (dremel) manifold & turbo inlet
IC elbow cleanup with Dremel
STI Short Shifter (edited 6/8)
"Special Gas" It was mostly Sunoco GT 104 Unleaded (3 gals)
The car has no N20. It has stock turbo (not FP), stock fuel system including injectors. Stock 16" Rims and tires.
12.9$500rex
12.989 @ 102.99
3" catback
3" downpipe
injen intake
home made - mbc @ 17-18 psi
temp was in the high 40's
93 octane fuel
Hassassin
[email protected]
godspeed up/downpipes
hks carbon ti exhaust
turboxs rlf bov
aem intake
samco intercooler hoses
greddy profec-b
apexi s-afc
pump gas 94 octane Good Ol' Sunoco
took out the spare and my monster truck jacking tools(not oem)
Temps -- cold
JaMes W
Cobb stage 2+
cobb accessport
Dug-e-fresh
13.097 @ 103.11
Power mods on the 13.097 run:
Vishnu Uppipe
Vishnu Unichip
Vishnu Crank Pulley
NGK 7 sparkplugs
(Stage 0)
SBC i-D EBC (16psi)
Removed Muffler
95ish Octane
Other Stuff on the 13.097 run:
STi Shifter Linkage
STi Tranny Mount
STi based intercooler sprayer (didnt really use)
Full Interior
1/4 tank of gas
225lbs driver, me
High altitude
Hotrod
13.239 @ 102.85 (5800 ft altitude)
Generic CAI from Mike Shaw Subaru -- Flat4Engineering
Forge BOV ( recirculating )
Torque chip II + (basically a hard coded SAFC and FCD)
Blitz DSBC boost controller at 16 psi
Crucial Racing 160 deg Cool Safe thermostat
90% water coolant with water wetter
Walbro 342 pump
gasket match Intercooler inlet ports
Samco turbo -to- TMIC hose
stream line throttle body inlet
Champion C59YC racing plugs
Lighten car, about 450 lbs - remove heat shields, remove sound deadner, AC unit, Cruise contol
Race weight 2835 #
unleaded racing fuel (mostly Sunoco GT+ 104 octane)
Light weight battery
relocate coolent tank to right fender
Insulate stock TMIC
Hard engine and tranny mounts
Heat wrap up and down pipe and stock cast iron exhaust manifolds and crossover pipe
Gutted stock Up pipe
Oakos Automotive down pipe (2.5 inch stainless flat plate entry)
Muffler pulled, but still running through 3rd cat.
Pre-turbo WI ( don't try this at home unless you know what your doing)
Iced TMIC 46 deg F at launch outside air temp, about 77 deg F.
Fox sport 16x7 rims
Yokohama A520 tires
No rear spoiler (order from factory that way)
Home made 2" airdam on front lip, closed off most of lower grill.
Stock 2.0 Liter engine, Stock TMIC, stock TD04-13T turbo, stock injectors fuel pressure regulator, and fuel rails , stock intake pipe under manifold to turbo, stock 5MT tranny and clutch.
Moorewrx
13.633 @99.89
TurboXS HPMBC
Injen CAI
Vishnu Up-pipe
Vishnu Pulley
Vishnu Unichip
Colder Spark plugs
BPM GT Exhaust.
Slatera666
[email protected]
no nitrous 77 deg
Stock Turbine Ported by FP
Intercooler hoses
Spearco TMIC
Invidia Cat-back
HKS catless Heat wrapped up/down pipes
MBC
Custom tuned UTEC
stock hacked air box and filter
I did take out the headlight
I was 3232lbs. with me in it.
Larry
Old 04-11-2006, 09:41 AM   #5
AudiTTkiller
Member#: 72875
2004 W R X
platinum silver metallic
lol it will take way more than cobb stage 2+ to run 12s
AudiTTkiller is offline   Reply With Quote
Old 04-11-2006, 12:05 PM   #6
kcook
Member#: 78074
2005 STi
im a 13.84 @ 97.94 mph with tbe & up pipe. 1.9 60' , i should be under 13.5 with my stg2 now
kcook is offline   Reply With Quote
Old 04-11-2006, 12:09 PM   #7
intence
Member#: 58477
. Member #1 of
the witty MS Crew
not with your driving. OOOOO
intence is offline   Reply With Quote
Old 04-11-2006, 03:10 PM   #8
kcook
Member#: 78074
2005 STi
lol we'll c on the 23rd
Old 04-11-2006, 08:54 PM   #9
lawn boy
Member#: 16345
2003 WRX- Sold
E60 BMW 545i
im hoping for 12.9x's with my setup. Utec dyno tuned by Xotic Motorsports, txs fmic, up pipe, catless 3" helix turboback, txs intake.
this coupled w/ 15lb wheels and a normally 1.70 60ft (can do better)...i hope to make it to the 12's without any kind of spray or injection
lawn boy is offline   Reply With Quote
Old 04-12-2006, 06:07 PM   #10
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
So turbo porting is out. What about ceramic coatings or wraps? Weight reduction is fine?
WRXRallyBlue is offline   Reply With Quote
Old 04-12-2006, 09:00 PM   #11
ejsportcom
Member#: 88905
thats something i'd like to know, cause i have turbo X on the hot side of my turbo..... and hell if we can port it then i will.....
ejsportcom is offline   Reply With Quote
Old 04-12-2006, 09:01 PM   #12
hotrod
Member#: 14141
2002 Impreza WRX
All that is pretty much covered in the first post?
In short yes to all the above are acceptable.
Like I said in the other original thread -- this is an "informal" standard, so as long as you post your mods so others can see what was done to get the time, pretty much everything is open and acceptable except major engine modifications and upgraded compressor wheels in the stock turbo.
The whole point of this is that the stock turbo provides a fixed point of reference, much like the restrictors used in the WRC and SCCA. By its very design it puts a pretty bullet proof upper limit to how much air you can get into the engine. With that hard limit, then it is up to the driver and the tuner to make the most with what is possible with that limited air intake volume.
Larry
Old 04-12-2006, 11:19 PM   #13
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
Thanks, I must have read over that.
Old 04-13-2006, 05:39 AM   #14
Amazake
Member#: 9889
hotrod we need your mod list...
Amazake is offline   Reply With Quote
Old 04-13-2006, 04:19 PM   #15
GetSideways
Member#: 44665
03 wrx sedan
platinum
Ill post my timeslip next time I go back to the track break into the 12.8xx range........still not dyno tuned
GetSideways is offline   Reply With Quote
Old 04-13-2006, 05:25 PM   #16
hotrod
Member#: 14141
2002 Impreza WRX
Its coming, just working my way down the list as time allows
Larry
Old 04-13-2006, 08:00 PM   #17
kcook
Member#: 78074
2005 STi
post my time up.. i aquired that with just tbe and up pipe
Old 04-13-2006, 08:03 PM   #18
Amazake
Member#: 9889
Thanks, I just figured if you are making others public yours should be too.
Old 04-13-2006, 09:45 PM   #19
OppositeLock
Member#: 54060
Now: 16 FXT/04v8 207
Then:JRTuned fastest td04
Yeah man, I am really interested to see what you run with a tune. Your time is serious with just that flash. I am finally getting a new (used) td04 and a few other things installed next week, so I can finally get back to the track and see if I can improve on my time.
OppositeLock is offline   Reply With Quote
Old 04-13-2006, 10:06 PM   #20
hotrod
Member#: 14141
2002 Impreza WRX
Yep -- like all the rest of you, mine had been public since the day I made the runs --- you just have to do some searching to find it.
Like today while searching for the mods info on one of the others on the list, I finally found the thread for Gadiels <12 run on the stock turbo and added him to the list as well. Some of these mods lists are assembled out of multiple posts in several threads on more than one web forum.
In my case, my mods and primary discussion of my runs were originally posted over on clubwrx because the folks over here didn't seem to care about or understand how difficult it is to run comparable times at high altitude.
Larry
Old 04-22-2006, 06:05 AM   #21
Amazake
Member#: 9889
BUMP for OP
Old 04-22-2006, 09:14 AM   #22
OppositeLock
Member#: 54060
Thanks Larry!
Old 04-22-2006, 04:48 PM   #23
JaMes W
Member#: 41500
2002 stock turbo WRX
[email protected]
cobb stage 2 + meaning cobb off the shelf tune plus other goodies.
JaMes W is offline   Reply With Quote
Old 04-29-2006, 08:50 PM   #24
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
6spd, EJ255, VF39 & EWG
Hotrod, does the motor have to be USDM?
I have a JDM LGT longblock that replaced my 2002 motor after a needing $1700 worth of work on a 90k motor. I'm still running my WRX manifolds, gutted UP, Bosal DP and TD04. I know the motor has either a 9.5:1 or 10:1 CR, so I'm guessing it's a no, but I think I could definitely see times under 12.5 with the right tune.
wrxfactor is offline   Reply With Quote
Old 04-29-2006, 11:12 PM   #25
hotrod
Member#: 14141
2002 Impreza WRX
It would be unfair I think to compare the JDM motor to the stock USDM for the reason you mentioned. Higher compression ratios make the the engine more thermally effecient so it should make more power if you have the octane to take advantage of it.
It would be interesting to have you post up what you could do just for reference though.
Larry
FS: Stock TD04 Turbo and WRX TMIC < 35K Miles All4BeSpinnin Engine/Power/Exhaust 9 12-22-2009 04:33 PM
WTB: Wastegate Actuator for TD04 Turbo coby73 Private 'Wanted' Classifieds 2 01-21-2008 08:02 AM
Looking for TD04 Turbo mdunkley43 Private 'Wanted' Classifieds 4 05-28-2007 01:12 PM
Looking for a turbo kit for my rs >.> <.< >.> 907racer Alaskan Impreza Club Forum -- AKIC 28 09-14-2006 02:13 PM
Is it 13.5 psi for stock turbo?? minisiu Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 07-27-2002 08:26 PM
