Old 02-05-2013, 09:27 AM   #26
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
Originally Posted by Shinji Hirako View Post
That doesn't even look like synthetic Mobil 1 to me, does the oil look clean? I would drain that stuff immediately.
Originally Posted by mod maniac View Post
I replaced mine with a blouch dom 2.5 xtr but mine is built. If you need a turbo I have a fresh td04hl-19t.
If you're looking for a cheap replacement, I would jump on that.
Subian is offline   Reply With Quote
Old 02-05-2013, 11:12 PM   #27
Shinji Hirako
Member#: 301002
08 Impreza Wrx
Definitely not synthetic! I'm picking up 5 quarts and a filter from advance (I get that ex employees discount) tomorrow see if that makes it stop smoking. Also picking up the leak down tester from my job Friday seeing as in someone took home the only one we had in the lab.
Shinji Hirako is offline   Reply With Quote
Old 02-06-2013, 11:46 AM   #28
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
Keep us updated, you can also buy Rotella t6 at a much cheaper rate at Walmart and they usually carry gallons/quarts.
Old 02-06-2013, 12:25 PM   #29
Shinji Hirako
Member#: 301002
08 Impreza Wrx
Should I pick up 5w30 or 5w40?
Old 02-06-2013, 12:50 PM   #30
rdieder
Member#: 257818
2007 STi
CGM
Drop the turbo heat shield and downpipe and tmic. you'll have an easier time to inspect all the coolant hoses, and oil line banjos for leaks. If the back of the turbo is oily, then that catted downpipe is toast. clean up the top of the coolant fill tank too, it looks like it had a spill or cracked hose dripping coolant all over it too.
Everything looks stock on that, if it has the stock uppipe, maybe the cat and/or egt probe is broken in it choking off your turbo.
rdieder is offline   Reply With Quote
Old 02-06-2013, 02:29 PM   #31
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
I run Rotella t6 5w-40 all year round.
Old 02-06-2013, 04:20 PM   #32
Andrewxxcarlson
Member#: 316415
2006 WRX
This s**t ^^^ love it.
Andrewxxcarlson is offline   Reply With Quote
Old 02-07-2013, 06:06 AM   #33
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
Any updates on this?
Old 02-07-2013, 04:58 PM   #34
Shinji Hirako
Member#: 301002
08 Impreza Wrx
UPDATE!!!!!!
Took today and tomorrow off.
So changed the oil with the t6 like ya'll suggested. This guy over filled this car by over a quart. I started it this morning and on initial start up a small cloud came shooting and then immediately idles properly. not sure if that fixed the blue smoked from the exhaust but it helped a little.
Now there's still the issue of the smoking from the engine bay.
It looks like it's smoking from the coolant fill cap (since there's no cap on the radiator???).
What the hell is that thing called??? It looks like its smoking from underneath that. I checked opposed forces but theres no name for it. Any ideas???
Old 02-07-2013, 05:28 PM   #35
SlverEJ20
Member#: 157158
05 WRX stage 2
replace the cap with a new one, easy fix
SlverEJ20 is offline   Reply With Quote
Old 02-07-2013, 05:37 PM   #36
Shinji Hirako
Member#: 301002
08 Impreza Wrx
You honestly think it's that simple? My OCD will not let me believe that lol!
It still pretty much smokes from the bottom of that unit. I'll pick up a new radiator cap tomorrow just for good measure.
On another note the clutch is going.
Old 02-07-2013, 06:19 PM   #37
Shinji Hirako
Member#: 301002
08 Impreza Wrx
I'm thinking that it might be a cracked hose or the coolant fill tank might have a crack in it thats leaking down to the exhaust causing it to smoke as well?!!!? I'm gonna check this tomorrow. Then do the leak down test and compression test. Just for good measure.
Old 02-07-2013, 06:21 PM   #38
SlverEJ20
Member#: 157158
05 WRX stage 2
If you havent add/ changed the coolant, and coolant is leaking from the cap then yeah I would start there first. Is the passenger side valve cover or head breather leaking at all?
Its kind of hard to determine if the smoke you are seeing on start up from your exhaust is typical cold weather condensation or smoke from burning oil. If it smells like burning oil pull the down pipe and check for oil on the hot side of the turbo. When my turbo seals went bad, it was a slow process that got worse over a month or two until it was embarrassing to drive in traffic.
Hopefully checking those things will help you narrow down your issue
Old 02-07-2013, 06:48 PM   #39
Shinji Hirako
Member#: 301002
08 Impreza Wrx
Thanks slverej will do. Definitely oil, but also cold weather condensation it was about 30 degrees out which was colder then the first video.
Old 02-09-2013, 10:05 PM   #40
Shinji Hirako
Member#: 301002
08 Impreza Wrx
It snowed pretty bad yesterday. I did get a chance to replace my radiator cap and it's still leakinge coolant from the fill tank so im assuming that needs to be changed.
Old 02-10-2013, 12:18 AM   #41
Cois32
Member#: 294755
2004 Impreza WRX
WRB vf39'd
pretty sure its just the cap leaking..replace it
in my case, the filler neck on that turbo coolant resevoir rusted and coolant seeped thru and burnt off it..I replaced mine with the black plastic ones on the newer wrxs..
Cois32 is offline   Reply With Quote
Old 02-10-2013, 12:26 AM   #42
Shinji Hirako
Member#: 301002
08 Impreza Wrx
This is exactly what's happening with mine. I replaced the cap already and its still leaking.
Old 02-10-2013, 03:44 PM   #43
IheartAWD
Member#: 329962
2016 WRX 6MT
Shadowmere
Here's how I fixed my smoke:
1.)Jack car up, clean anything that looks wet under the engine.
2.) Drive it for half an hour.
3.) Find where its leaking from.
You might be leaking more than just coolant, usually burnt coolant smoke isn't that thick.
IheartAWD is offline   Reply With Quote
Old 02-10-2013, 05:25 PM   #44
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
When you take the radiator cap off when the car is cold, is the coolant level topped off? Might be a head gasket or coolant getting by the iacv going into the intake tract. If you take off the iacv (on top lf the throttle body) make sure you have a replacement gasket.
Old 02-10-2013, 07:42 PM   #45
Shinji Hirako
Member#: 301002
08 Impreza Wrx
Just checked it and The coolant level is definitely topped off. Just an update but i haven't seen any blue smoke come out of the exhaust since the day after i changed the oil.
Old 02-10-2013, 09:26 PM   #46
kage
Member#: 25101
Chapter/Region: HIIC
2002 PSM WRX Wagon
1999 Twilight Blue Miata
If it's actually smoke and not steam coming from under the coolant tank cap, then I'd suspect a leak in the head gasket. I think you can get test strips to check for exhaust byproducts in the coolant, or take it to a shop.
kage is offline   Reply With Quote
Old 02-11-2013, 08:48 AM   #47
rrg123
Member#: 344639
2002 Impreza WRX
Midnight Black Pearl
Yes, open the cap when cold, start the car.
If it's puffing then the exhaust is in there.
Also do the same for the main radiator.
Open when cold start the car and look for puffs of smoke.
You can do a combustion leak test on it for $44 -$55 for the kit.
Napa sells a kit with the blue liquid that turns yellow if it finds combustion in the coolant.
Just be sure to remove some coolant so you don't pick up coolant into the tester.
Head Gasket or Combustion Leak Test
Check youtube for examples.
I have to do a HG leak test this week with the kit I got.
I hope the turbo seals are bad and the exhaust is being pushed up that way?? or HG blown.
rrg123 is offline   Reply With Quote
Old 02-11-2013, 04:07 PM   #48
Shinji Hirako
Member#: 301002
08 Impreza Wrx
Thanks for this. I'm gonna try to get all this done through out the week. I'm hoping its just the turbo seals too. Good luck your diag.
Old 02-12-2013, 11:15 PM   #49
Shinji Hirako
Member#: 301002
08 Impreza Wrx
I did the compression test and my numbers are pretty low!
Cylinder
1.119
2.110
3.115
4.115
Not sure if these are my numbers or tool is messed up but its a new tool.
Old 02-13-2013, 02:46 AM   #50
corvallisbattery
Member#: 333030
'05 WRX
On a cold engine those numbers are decent. On a hot engine with fuel cut and WOT I'd say maybe a bad tester. If you tested it twice with two different tools and got the same results I'd say low compression. But fact is you have a good grouping with low cylinder variance. About %8. Well within spec.
corvallisbattery is offline   Reply With Quote
