Old 02-04-2013, 12:59 PM   #1
ryblair
Member#: 309638
2011 wrx premium
dark metallic grey
So for the past 8 months or so I have been getting some kind of high pitch flutter under part throttle when I give it full throttle it goes away. It sounds like me Cobb intake making the noise but tuner said its my vf52 wastegate. It's gotten to be pretty annoying cause I highway drive a lot and it only seems to do it in 4th or 5th mostly under part throttle. It seems to high pitch to be the wastegate and it cant be a leak cause it doesnt happen at full throttle. Anybody else experiencing this? Thanks Ryan
Edit: mods are grimmspeed ebcs, turboxs catless turbo back, Cobb sf intake, torque solution Tmic, dw65c fuel pump, turbo smart Bpv full recirculating
ryblair is offline   Reply With Quote
Old 02-04-2013, 01:08 PM   #2
The Duke
Member#: 264877
Wastegate.
The Duke is offline   Reply With Quote
Old 02-04-2013, 01:16 PM   #3
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
Intakes don't make noise, especially not fluttering. All they do is allow other noises to resonate and get louder when compared to the stock intake.
Old 02-04-2013, 01:25 PM   #4
coalslaw
Member#: 324808
2006 IWL Stg2
list your boost controller and your exhaust setup
coalslaw is offline   Reply With Quote
Old 02-04-2013, 02:01 PM   #5
ryblair
Member#: 309638
2011 wrx premium
dark metallic grey
Post edited
Old 02-04-2013, 02:13 PM   #6
tuzzio
Member#: 292532
05 STI
You're just hearing the wastegate opening and closing under heavy load.
tuzzio is offline   Reply With Quote
Old 02-04-2013, 02:31 PM   #7
ryblair
Member#: 309638
2011 wrx premium
dark metallic grey
It's not under heavy load though its happening around 10psi heavy load would be more around 18psi
Old 02-04-2013, 02:40 PM   #8
ryblair
Member#: 309638
2011 wrx premium
dark metallic grey
Thanks that's what I figured I suppose ill just put up with the high pitch flutter
