Old 09-18-2002, 09:21 AM   #1
ants wrx
Member#: 17885
2006 Scion xB
93 RB25det powered 240sx
Default does the vishnu unichip = turboxs unichip
hey guys.. i did a search but i want a specific answer.
its time i get some kind of management in my car.. i keep seeing a lot of turboxs unichips for sale and hardly any vishnus. is there a reason..is one better than the other? i want one that just plugs in, and can un-plug it at any time to return to stock. (no wire splicing). i have an EBC, so would a unichip be safe with it?
someone in the past has recommended to me vishnu as the way to go because of something to do with the harness, i dont remember the exact reason.
thanks,
Anthony
ants wrx is offline   Reply With Quote
Old 09-18-2002, 09:23 AM   #2
mlambert
Member#: 13831
same piece of hardware, different tuning. TXS bases their maps off TPS and vishnu does MAP (right?)
I havnt really followed the unichip saga very closely so I could be wrong. Im pretty sure COBB does TPS as well.
mlambert is offline   Reply With Quote
Old 09-18-2002, 09:49 AM   #3
arew_WReX
Member#: 22093
I'm pretty sure the chips are the same, the two company's have slightly different tuning philosophies so the maps could be signifigantly different.
The reason your seeing so many TXS chips for sale is probably due to the users wanting to switch over to TXS's new UTEC engine management system.
Later,
Andy
arew_WReX is offline   Reply With Quote
Old 09-18-2002, 10:05 AM   #4
WRBLUEWAGON
Member#: 10745
2006 VW SUV
anthony,
Vishnu uses MAP as a Load instead of tps.
TPS does work but does require that the boost is there at it's load points. if there is more boost you will run lean if less boost it will run rich.
With the SBC-ID that you run I would run Vishnu's tunned uni-chip. But yes it is the same as turboxs and cobb. Just diffrent tunning technics.
Sending you a PM.
Eric
WRBLUEWAGON is offline   Reply With Quote
does the vishnu unichip interfere with my AP stage 2? blackrexnj Engine Management & Tuning 4 04-14-2005 11:21 AM
Quick..whats the difference btw Vishnu and Turboxs unichips. enewtabie South East Region Forum 4 12-03-2002 06:43 PM
What does the Vishnu Signature Series includes?are you? Coquipelao Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-21-2002 10:23 PM
vishnu tuned turboxs unichip jaywrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-04-2002 10:45 AM
TurboXS Stage 2, what exactly does the remapped unichip do? MrWRXNYC Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 02-16-2002 10:27 PM
