Welcome to the North American Subaru Impreza Owners Club Friday October 24, 2014
Old 05-23-2001, 01:22 PM   #1
JNaubur
Member#: 4366
2002 Impreza 2.5 TS
Midnight Black Pearl
Have a Nice Day? Rear main seal gone - 650kms? Help!
HELP! I was leaking oil on my brand new '02 2.5 TS and took it into service. They said that the rear main seal needed to be replaced. How concerned should I be? Will this cause long term reliability problems?
Thanks in advance
Jason
JNaubur is offline   Reply With Quote
Old 05-23-2001, 01:27 PM   #2
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
Post
I would be really concerned. Any leak would can cause oil leak which "may" lead to an engine failure.
You shouldn't have a single leak anyway. Get it replaced for free!
tmat3 is offline   Reply With Quote
Old 05-23-2001, 01:33 PM   #3
JNaubur
Member#: 4366
2002 Impreza 2.5 TS
Post
I meant that they are replacing it.
I was wondering if I should be concerned about having a lemon. Or if the repair of this part may mean more trouble down the road.
jason
Old 05-23-2001, 01:40 PM   #4
Charge
Member#: 3313
Post
I don't think so. I had the repaired on my old S-10. I watched them actually do it. Doesn't seem like it should be much issue if it's done right. The seal on my truck started leaking around 75,000(my brother over filled the engine oil by 1 quart once, noticed it about half way to the Outer Banks, that's why it leaks there and at the valve cover gasket). I didn't get it fixed until about 140,000. Just kept putting oil in every month, as it was a slow leak. If you didn't lose too much oil, it won't be a problem at all.
Neil
Charge is online now   Reply With Quote
Old 05-23-2001, 01:57 PM   #5
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
Post
I doubt you have a lemon. You just had a defect in the seal. Replacing it should solve problems.
Old 05-25-2001, 12:14 AM   #6
AndyHidley
Member#: 1031
Post
Thats funny that you say that. I had a 2000 RS and very often I smelled oil. I suspedted it was leaking from the rear main and drippin on the y pipe and burning. It will do that FOR SURE if its overfilled.
AndyHidley is offline   Reply With Quote
Old 05-25-2001, 12:29 AM   #7
travman733
Member#: 5649
2002 WRX wgn bl stg2
(sold)'93 Impreza L Sedan
Cool
Yeah I wouldn't worry about it either. I discovered a gas leak around 18 months after I bought my '93 Impreza (the weld seam where the top and bottom of the tank come together was coming apart). Got it replaced under warranty and haven't had one problem since.
travman733 is offline   Reply With Quote
Rear Main Seal help ! DemiSlayer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-09-2008 10:25 AM
rear main seal help Imprezanize Normally Aspirated Powertrain 11 02-24-2005 02:36 AM
Installing a clutch? Why not throw in a new rear main seal. Tim Sanderson Transmission (AT/MT) & Driveline 0 07-08-2004 10:02 AM
rear main seal mybluesubi Service & Maintenance 11 02-09-2004 06:28 PM
rear main seal replacement?+ flywheel and pressure plate bolt torque? Haase14 Transmission (AT/MT) & Driveline 7 01-17-2003 10:42 AM
