Old 02-04-2013, 09:33 PM   #1
alexandern05
Member#: 266954
04 wrx v7 sti swap
agile tuned 389hp 342ftlb
Default hfs-5 install need help
Iam installing a aquamist hfs-5 dds3v10 into my 04 wrx and need help finding wiring diagrams for the different failsafes and for what pins on the 04 ecu also what failsafes are everyone using
alexandern05 is offline   Reply With Quote
Old 02-04-2013, 11:01 PM   #2
alexandern05
Member#: 266954
04 wrx v7 sti swap
Also what jet do I use for 22-25 psi and 350-360 HP
Old 02-05-2013, 07:22 AM   #3
Aquamist
NASIOC Manufacturer
Member#: 110029
2004 Citroen Picasso
Wiring diagram.#:
http://forums.nasioc.com/forums/show...752282&page=93
1x 1mm jet will be close.
Aquamist is offline   Reply With Quote
Old 02-05-2013, 08:21 AM   #4
alexandern05
Member#: 266954
04 wrx v7 sti swap
Thank-you
Old 02-05-2013, 08:46 AM   #5
alexandern05
Member#: 266954
04 wrx v7 sti swap
would it change what jet i need i have the newer 160 psi pump instead of the 125
Old 02-06-2013, 01:51 PM   #6
Aquamist
NASIOC Manufacturer
Member#: 110029
If you have a newer pump, you need to order a newer jet to match. If you are using the order jet, you will be injecting more. We retain the cc/min based on pump pressure.
