Old 04-07-2013, 06:47 PM   #1
BananaSammiches
Member#: 347739
2006 WRX wagon
Default Oil Buildup on Downpipe
Is oil build around the catalytic converter on the downpipe normal? It's a pretty thick layer of oil, but it's only around the underside of the catalytic converter right after the turbo. My buddy and I were looking at it, and we were able to scoop off globs of it with our fingers. The car runs and idles perfectly fine. There are no modifications done to it. I have an '06 WRX wagon with 41k miles.
BananaSammiches is offline   Reply With Quote
Old 04-07-2013, 06:51 PM   #2
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
No it is not normal and ya need to find out where exactly it is coming from. Takes some pics and post them
trev762 is offline   Reply With Quote
Old 04-07-2013, 07:06 PM   #3
BananaSammiches
Member#: 347739
2006 WRX wagon
I don't know how well you'll be able to see it. This is the best I can do.
Old 04-07-2013, 07:26 PM   #4
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
No fluid should touch the exhaust components as that is a major fire risk. (Especially oils) Climb under the car and start cleaning it off, then monitor it (by climbing under and looking for leaks) often.
My guess. Turbo OR valve covers.
Old 04-07-2013, 07:32 PM   #5
Francois_
Member#: 284101
2004 STI
world rally blue
My guess is a torn cv boot flinging grease onto the exhaust
Francois_ is offline   Reply With Quote
Old 04-07-2013, 07:37 PM   #6
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
^^ this definitely looks like grease from torn cv boot have a look and see
Old 04-07-2013, 07:42 PM   #7
BananaSammiches
Member#: 347739
2006 WRX wagon
I had actually already taken a look at the cv boot and it was completely fine.
Old 04-07-2013, 07:49 PM   #8
WickedRydaX
Member#: 31900
I think it is the CV (inner by the trans) also. Did you spin it around and look into all the low spots for cracks?
MCL
WickedRydaX is offline   Reply With Quote
Old 04-07-2013, 07:53 PM   #9
BananaSammiches
Member#: 347739
2006 WRX wagon
MCL
Yes. I crawled underneath and inspected everything. Everything is intact and in good working order.
Old 04-07-2013, 07:57 PM   #10
BananaSammiches
Member#: 347739
2006 WRX wagon
The only thing I couldn't see was the oil lines going to the turbo.
Old 04-07-2013, 09:14 PM   #11
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
yeppers...or maybe gear lube bein slung out
if it was oil, you would easily see where it was coming from....and oil usually wont make thick 'globs' like grease or gear lube will.....also...the SMELL should tell you what it is
Old 04-07-2013, 10:07 PM   #12
BananaSammiches
Member#: 347739
2006 WRX wagon
Hmmm. But if the cv boot on the right side is completely intact, what else could it be?
Old 04-07-2013, 10:27 PM   #13
Uncle Scotty
OK buy Nates beans
it could be that it really ISNT intact and the grease is slinging out the end past the clamp
Old 04-08-2013, 12:38 AM   #14
DHRDAN
Member#: 204358
01 2.5RS W/ EJ257
If that catches fire... your whole car is going to go up in flames.
Literally.... flames.
DHRDAN is offline   Reply With Quote
Old 04-08-2013, 10:19 AM   #15
WMCCook29
Member#: 152685
2016 Forester XT
^^This! I was changing my oil yesterday and found grease being pushed past the outer clamp on my CV (fortunately, it's on the driver's side).
WMCCook29 is offline   Reply With Quote
Old 04-08-2013, 10:48 PM   #16
Uncle Scotty
OK buy Nates beans
ive seen the power steering line fail right there next to the up pipe and torch 2 cars......once it ignites and gets going...that's it....done deal
this is why i ALWAYS suggest that anyone who wraps any of the exhaust....should get some super HD al foil(or the HD al foil tape) and wrap THAT around heat wrap.....helps prevent the wrap turning into a wick and keeping the fire burning
Old 04-08-2013, 10:52 PM   #17
Uncle Scotty
OK buy Nates beans
and you are super lucky that it only takes a few minutes to fix that!!!
just get some cv grease and one of those cake decorator thingies and load the grease in it and after you cut the band off, push the boot back and squeeze in the grease and put a new band on and done in a half hour
http://static.ddmcdn.com/gif/icing_1.jpg
Old 04-09-2013, 02:13 AM   #18
sedonarex13
Member#: 313573
06 wrx
You could check to see if your tranny dipstick was pushed in all the way. Just a thought.
sedonarex13 is offline   Reply With Quote
Old 04-09-2013, 08:52 AM   #19
WMCCook29
Member#: 152685
2016 Forester XT
Thanks for the suggestion!
