Welcome to the North American Subaru Impreza Owners Club Wednesday June 3, 2015
Old 02-06-2013, 03:06 PM   #1
the RIOT act
Member#: 341277
13' WRX Premium
Satin White Pearl
Default Okay to swap 55w for 65w/100w bulb?
I wouldn't even know what to search for so I figured I'd just post a thread. But I'm curious to know if you can install 65w or 100w bulbs where an OE 55w low beam bulb is in my 2013 wrx now? Thanks for any help given.
the RIOT act is offline   Reply With Quote
Old 02-06-2013, 03:12 PM   #2
Handsdown
Member#: 29355
2003 GD6 Hate chall
but i'mma maintain
No.
you'll increase glare and heat and voltage draw which can cause wiring problems, burns/pits/mars on the optics in the lamp, and you'll annoy people. if you need better light get better lamps, or more lamps.
even a 65w bulb, while it may be totally manageable with stock lamps and wiring, is going to increase glare for you and every other driver that has to share the roads with you. If you want nicer output, OEM hid retrofits are the only option, or just buy hid sti lights from subaru. notice i say "may"... even a good quality 65w bulb may burn your wires up and make little pits in your projector bowl.
also: always always always look through and read EVERY sticky in every forum you ever want to not be berated in.
The Ultimate Bulb Lighting Thread: All You Ever Need to Know About Bulbs
Handsdown is offline   Reply With Quote
Old 02-06-2013, 04:03 PM   #3
the RIOT act
Member#: 341277
13' WRX Premium
Satin White Pearl
Thank you very much. I can only use the app so stickies aren't something I can see. I figured swapping wattage was a no go, just wanted to check. I'll check out your link for any further questions though. Thanks again.
Old 02-06-2013, 04:07 PM   #4
frederik
Member#: 64405
2003 WRX Sedan
WRB - Cobb Stg 2
BTW can see the stickies (I assume you are using the iPhone nasioc app) when browsing say the electrical forum, on top in the blue header there is a Stickies tab.
frederik is offline   Reply With Quote
Old 02-06-2013, 08:33 PM   #5
the RIOT act
Member#: 341277
13' WRX Premium
Satin White Pearl
Lol...def never noticed that. Thanks again.
Old 02-07-2013, 09:49 AM   #6
Salvation27
Member#: 292403
2012 Legacy
Graphite
You can use 65 W
Even in the 06's there was barely any noticeable difference!
There's been threads with years of information and most positive feedback has been given.
There's been more negative feedback about HIDs in your stock projectors! Let alone the expenses and regrets of even retrofitting
Salvation27 is online now   Reply With Quote
Old 02-07-2013, 10:34 AM   #7
tmburke
Member#: 342345
2008 WRX Hatch VF-52
SSM
Just do the H11 to H9 conversion-http://forums.nasioc.com/forums/showthread.php?t=2083911
tmburke is offline   Reply With Quote
Old 02-07-2013, 11:09 AM   #8
Salvation27
Member#: 292403
2012 Legacy
Graphite
Your low beams take a 1350-lumen H11 bulb. You can easily, safely, and
effectively replace this with a 2100-lumen H9 bulb:
http://store.candlepower.com/h-9.html . You may need to shave a small
ridge of plastic off the H9 bulb's connector so that the H11 socket will
snap on. Other than that, it's a direct swap. The only disadvantage is
shorter low beam bulb life - the H11 is optimised for very long life
with relatively modest light output, while the H9 is optimised for very
high output with relatively short life. The other option is the Osram
Night Breaker H11 http://store.candlepower.com/bconibr90ulh5.html which
gives better performance than a standard H11, but nowhere near as good
as an H9.
From the man himself- Daniel Stern
Old 02-07-2013, 02:31 PM   #9
the RIOT act
Member#: 341277
13' WRX Premium
Satin White Pearl
Yeah I was actually emailing back an forth with him last night about the route to go. He pointed me in the right direction. Great guy to talk to also...very detailed!
Old 02-07-2013, 03:31 PM   #10
Salvation27
Member#: 292403
2012 Legacy
Graphite
What route did he suggest?
Old 02-07-2013, 04:26 PM   #11
the RIOT act
Member#: 341277
13' WRX Premium
Satin White Pearl
Recommended H11 Philips Extreme Vision +100 for lows, Philips HIR1 9011 conversion for highs, and 9005 Philips Extreme Power +80 for fogs. He said this is the best setup for me in a 2013 wrx.
Old 02-07-2013, 08:01 PM   #12
CRAZYHAWK
Member#: 198067
2009 IMPREZA 2.5i 4d
WHITE Premium
Not voltage draw , current draw.
Originally Posted by Handsdown View Post
No.
CRAZYHAWK is offline   Reply With Quote
Old 02-07-2013, 08:34 PM   #13
frederik
Member#: 64405
2003 WRX Sedan
WRB - Cobb Stg 2
Maybe he meant voltage drawp
Old 02-08-2013, 11:24 PM   #14
lj8915
Member#: 329252
2012 Subaru WRX
I recently went from the H9 bulbs to a cheap bolt on retrofit and it's a huge difference. Huge.
lj8915 is offline   Reply With Quote
Old 02-09-2013, 03:05 PM   #15
Salvation27
Member#: 292403
2012 Legacy
Graphite
How much is "cheap" and what one did you go with?
Old 02-11-2013, 09:04 AM   #16
lj8915
Member#: 329252
2012 Subaru WRX
$250 retro quick system
