Old 02-06-2013, 06:16 PM   #1
iLOVESTi05
Member#: 303072
2005 STi
Default Fuel to Lines, Not Starting?
On my 2005 STi, I cant seem to get it started now. Mod list below, the fuel pump primes, has spark(I've checked), is getting fuel to the lines by the intake manifold, has an appropriate base map, and is just cranking.
I hear the fuel pump priming when I turn the key, there is fuel flowing through the lines, but it just keeps cranking. Checked for power from the harness for the injectors, all getting power. There is no fuel coming out of the cylinder heads when I pulled the plugs and primed, which is weird.
There must not be any fuel getting to the heads, right? No clue why. Any ideas or anyone had any similar problems? I timed it perfectly lining up with all timing marks, the timing cover, etc. I guess I'll have to pull off the Intake Manifold and check each injectors to see if its spraying. No other ideas. Any ideas or help is appreciated.
Btw, I checked the harness connectors and they ARE sending electricity.
Perrin Rotated Turbo kit with Garrett Dual Ball Bearing 35r
Tial 44mm MVS EWG
Speed Density Set up(Omni 4 Bar Map, IAT Sensor)
TGV Deletes
Five-O Motorsports 1000cc injectors
Walbro 255 Pump
Grimmspeed EBCS
Grimmspeed 8mm Phenolic Spacers
TurboXS FMIC
Mishimoto Rad
Perrin Lightweight Crank Pulley
Motor:
CP Forged Pistons
Eagle H Beam Rods
ACL Race Series Main & Rod Bearings
OEM Oil Pump
Gates Timing Belt Kit
GSC Valves/Springs/Retainers
Cometic Gasket Set
Motor has 2k on it, had to pull it because head gasket blew.
iLOVESTi05 is offline   Reply With Quote
Old 02-06-2013, 08:52 PM   #2
cosseywrx
Member#: 276443
2005 2.1 stroker WRX
Motor needs air spark and fuel to start.
If spark and fuel are good and no cels present try checkibg for air leaks.
cosseywrx is offline   Reply With Quote
Old 02-06-2013, 08:54 PM   #3
cosseywrx
Member#: 276443
Injectors arent leaking?
Really make sure those 3 lines that deal with fuel are in there correct spots.
Ones fumes. Fuel out and fuel return.
Ive done this b4. Turned over all day but didnt start
Old 02-06-2013, 10:37 PM   #4
iLOVESTi05
Member#: 303072
2005 STi
Yeah. I checked the air, everything's connected. Running on a speed density set up so no maf or intake. Also, checked those lines and they're in the right spots. No cels, spark but like I said no fuel out of the heads with no plugs. Gonna pull off everything an check for blockages in the fuel rails
Old 02-06-2013, 10:47 PM   #5
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
THIS!
Additionally, we have seen it when cam and crank sensors are out of sync (unhooked, time off)
We have also seen it when ONE little tooth is broken off the crank sprocket.
AND we have also seen it when the grounds to the block are not tight (for real). Add to that if you're using the composite TGV deletes you have to move the ground from the top of the intake manifold to one of the long TGV bolts as you're now electrically isolated from the block.
Old 02-06-2013, 11:03 PM   #6
iLOVESTi05
Member#: 303072
2005 STi
Originally Posted by Turn in Concepts View Post
THIS!
THIS! Gotta move the ground from the intake manifold to the tgv bolt then. I'll do that tomorrow morning. I thoroughly checked the crank sprocket before reinstalling it. Both sensors are installed but may be out of sync even though the timing markings all lined up 110%
Old 02-07-2013, 12:42 PM   #7
04ScoobyWtf
Member#: 287974
I had the same problem and I mixed up the fuel lines going to the rail in the drivers side.
04ScoobyWtf is offline   Reply With Quote
