#1 |
Member#: 332781
Vehicle:2002 WRX AW (soon to be grey) |
So I'm doing a clutch install on my 02 WRX (5-spd).
I've only made so much progress because I ran into a problem. Solved it. ...anyways I'm going to drop the transmission out tomorrow and don't have a transmission jack so ill be using a regular jack with wheels. I know it won't be perfect and I understand the transmission weighs 135lbs give or take. but I'm strong so I can handle what the jack can't. Just wondering if someone could point out the center of gravity so the jack can be placed in an efficient place. Could someone do me a huge favor and edit this photo and point to the center of gravity (on the bottom, I can use my imagination). ![]()
#2 |
Member#: 167772
SCIC
Vehicle:03 wrx white |
there is a little bump on the bottom of the trans, its about 1x1/2x1/2 in size. remove the pad from the jack and use the hole to line up with the bump. fwiw, i only use the jack to install the trans, i man-handle the trans out of the car with my mitts. like you said, it only weighs 135lbs(caution bodliy injury may occur).
#3 |
Member#: 332781
Fwiw?
Thank you. Hopefully I find that bump in the morning. |
#4 |
Member#: 124581
For what it's worth. The bump is near the front of the trans. It's noticable to say the least. I have seen some people use 2x4s just to act as a larger plane but placing the jack hole on the "bump" seems to be the best idea.
#5 |
Vehicle:OK Houston we have an Uncle |
dont forget about the ground wire that goes from the top of the trans to the pitchstop mount on the firewall
#6 |
Member#: 332781
That wire isn't on my car. Before I bought it, the clutch was replaced (eBay I'm assuming) and the wire just wasn't mounted next to the engine mount. Stupid question, but is it important?
#7 | |
it it aint there.....put it back |
#8 |
Member#: 332781
#9 |
second top trans case bolt, from the front.....to the pitch stop mount on the firewall
#10 |
Member#: 237145
SCIC
Vehicle:02 WRX 12 FXT |
FYI for a sti 6mt the center of gravity was the lower fluid plate thing.... U know what I'm talking about and it worked. I did what u did with the 5mt. It's a bear but thank god it's smaller than a six speed. Omg. If I was at my parents place I would of found your COG on the 5mt. Good luck with the clutch!
#11 |
and its more the center of mass...not gravity...but anyway
#12 |
Member#: 237145
SCIC
#13 |
Member#: 283968
Vehicle:2003 WRX MBP |
I grounded mine to the same ground as the starter
much less resistance = better accuracy yore wires might not stretch over there, I think I had to make mine myself |
#14 |
Member#: 332781
Looks like I'm going to have to make one too considering whoever took the transmission out before never put the ground back. What does it ground? What do you lose when the ground isn't there? What gauge wire do I have to use?
#15 |
Member#: 283968
speed sensor, reverse lights, and neutral position switch
just find a piece of wire laying around, and use it if you have to buy something, I'd say around 16 gauge stranded would do fine and can be found at every hardware store known to man |
#16 | |
![]() you grounded WHAT to the starter ground??? and the resistance isnt the issue....the location IS the issue grounding the trans to the BODY is intent and im not sure you understand what is going on, here....and making all the difference of potential equal is the intent of grounding |
