Old 02-08-2013, 11:32 AM   #1
beastaru
Member#: 346386
Default head unit blue tooth ?
Hello fellas. new to the forum but i have had a 2011 wrx for a while and just up traded to a 13 sti hatch. My ? is in my 2011 wrx when i got into the car and started it the bluetooth would auto pair up with my phone. now in this new 13 sti i have to manually pair it every time i start the car. I cannot find the settings to fix this issue does anyone know what im talking about and the solution?? the head unit appears to be the exact same as the 11. any advise would be appreciated.
thanks.
beastaru is offline   Reply With Quote
Old 02-08-2013, 11:46 AM   #2
Mike 01Hawk
Member#: 219162
2011 WRX Sedan Base
Talk to your salesman.
Mike 01Hawk is offline   Reply With Quote
Old 02-08-2013, 11:49 AM   #3
beastaru
Member#: 346386
They do not know whats up with this situation i did already. it has a sensor in there that wont let me pair if the car is in motion so i have to remember to do it at a stand still when i start the car. the other one didnt have that sensor and just paired up by itself and would resume my music where it left off which was really awesome. i hope there is a setting that can be messed with to fix it.
Old 02-08-2013, 11:54 AM   #4
leftyonly
Member#: 343811
2013 WRX Wagon
ISM
Likely a phone settings issue. My new 2013 WRX Hatch (base) pairs automatically after starting up.
That being said, there has been one occasion since I got it where I had to re-pair the phone for some unexplained reason. It had stayed paired for many starts before and after the event...
leftyonly is offline   Reply With Quote
Old 02-08-2013, 12:25 PM   #5
beastaru
Member#: 346386
hmmmm this sucks i cant figure it out. no options on my iphone or nothing in the sti manual about this...
Old 02-08-2013, 01:25 PM   #6
sketcheroo
Member#: 339856
2013 WRX Premium
Satin White Pearl
I remember reading in another thread that you need to pair it using the voice recognition setup, otherwise you'll always be manually pairing it.
sketcheroo is offline   Reply With Quote
Old 02-09-2013, 07:57 PM   #7
seanx820
Member#: 325319
make sure you deleted all the bluetooth stuff out of your phone, maybe they used the same naming scheme/pin as the original 2011 on your 2013. 9/10 resetting the wi-fi/bluetooth/whatever setting for pairing laptops/phones, etc for any wireless setup will resolve this kind of issue. Let me know if that helps.
seanx820 is offline   Reply With Quote
Old 02-09-2013, 08:22 PM   #8
warpdwhim
Member#: 204130
2016 Legacy 3.6R
Twilight Blue Metallic
I had an issue with my '12 - Don't try to setup/pair directly at the headunit...
only go through the steering wheel controls....then it'll stick, at least that's what I found with mine.
warpdwhim is offline   Reply With Quote
Old 02-10-2013, 09:31 AM   #9
mejifair
Member#: 11356
2012 WRX STi Hatch
Yup - I had the same issue, and when I unpaired it and paired it using the steering wheel controls with voice everything works perfect. It pairs automatically everytime now.
mejifair is offline   Reply With Quote
Old 02-10-2013, 10:50 AM   #10
osiris22
Member#: 346544
try to pair one of your friends iPhone see if it does the same thing, if it doesn't pair your friends iPhone then definitely something wrong with head unit, if it does pair, then its your iPhone
osiris22 is offline   Reply With Quote
Old 02-10-2013, 11:20 AM   #11
WRrex12
Member#: 327113
2012 WRX Sedan
DMG
I have the same issue with my SG3. I found this app called 'bluetooth audio' for my phone and it solved the pairing issue..
WRrex12 is offline   Reply With Quote
Old 02-10-2013, 05:44 PM   #12
myee111
Member#: 261852
2011 Impreza 2.5i
Dark Grey
Thanks for this. I've been trying to figure out how to pair my blackberry 9900 for almost a year now. uuuuugh
myee111 is offline   Reply With Quote
Old 02-15-2013, 02:45 PM   #13
iamdrumming
Member#: 347146
2013 Impreza
Cherry
Default Pairing Blackberry Bold and older iPod via BT
I have a newer Blackberry Bold and an older iPod Touch (3rd gneration maybe?). Both are Blue Tooth compatible and I was able get both working separately. Is there a way to have my iPod playing music via Blue Tooth AND have my phone paired via Blue Tooth at the same time?
Thanks,
Rob
iamdrumming is offline   Reply With Quote
Old 02-15-2013, 03:40 PM   #14
luan87us
Member#: 335013
2013 Premium WRX 5dr
Yeah I noticed when I installed new rom on my phone and had to re-pair my phone. I have to manual pair it everytime when I did it through the HU. Deleted all saved devices on my HU and used the SWC to pair and it automatically sync everytime now.
luan87us is offline   Reply With Quote
Old 02-15-2013, 03:44 PM   #15
iamdrumming
Member#: 347146
2013 Impreza
Cherry
So, I can pair my Blackberry AND my iPod through the steering wheel commands?
Old 02-15-2013, 04:43 PM   #16
luan87us
Member#: 335013
You should be able to. Make sure your device is discoverable. Press the "Talk" button then say "Set Up" then just follow the instruction the car gives you.
Old 02-15-2013, 06:36 PM   #17
Burn30363
Member#: 347168
2012 WRX
Satin White Pearl
Thumbs up Paring via voice promt worked
i bought my 2012 Subaru WRX and was wondering about the auto connect not working. This just solve a problem Ive been having for almost a year.
hope in to your car turn the key to on( the engine doesn't have to be started) and start talking to your car set up, phone pairing, start pairing in your phone now and done you're good to go. Worked for my galaxy s3.
Burn30363 is offline   Reply With Quote
