Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 02-08-2013, 12:50 PM   #1
tmeck
Member#: 238719
Default Installing new Turbo, Wastegate hits the TMIC?
Hello, I recently bought a Kinugawa 18g and I was having it installed and they ran into a fitment issue.
04 Forester XT. 4eat.
Apprently the wastegate is hitting the TMIC?
Thoughts/suggestions?
tmeck is offline   Reply With Quote
Old 02-08-2013, 04:31 PM   #2
02nismokiller
Member#: 322963
04 wrx
psm
Possibly tilt the intercooler with a spacer?
02nismokiller is offline   Reply With Quote
Old 02-08-2013, 04:35 PM   #3
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
Is it just me, or does that intercooler look WAY too wide?
Old 02-08-2013, 04:37 PM   #4
marcymarc
Member#: 112861
2013 STi sedan
yea, on my old rex, my IC rubbed on the same AC line.. about 6 months in, it had rubbed a small hole in the line.. Huge PIA to fix. that line runs through your fire wall, so i would adjust it asap so you dont have that problem too!
marcymarc is offline   Reply With Quote
Old 02-09-2013, 03:24 AM   #5
02nismokiller
Member#: 322963
04 wrx
psm
I agree 10000000% that thing is wiiiide and pretty narrow... Get a wrx intercooler and it'll fit perfectly!
P.S. I'll sell you my old stock wrx intercooler for 80 shipped
Old 02-09-2013, 05:34 AM   #6
tmeck
Member#: 238719
WRX intercooler doesnt fit on the FXT... And I'm aware on the AC line problem. It's the IWG that's the real problem. I'm using the STI TMIC.
Old 02-09-2013, 07:37 AM   #7
FCmaniac
Member#: 142029
2013 Forester
2008 350z, 1991 Miata BRG
That is crazy looking wastegate actuator. Did that come stock with the Kinugawa? Could you swap in a stock VF actuator?
FCmaniac is offline   Reply With Quote
Old 02-09-2013, 01:55 PM   #8
tmeck
Member#: 238719
Yes that's the one that came stock. I'll ask the shop and see if they have any different ones.
Old 02-09-2013, 02:27 PM   #9
stevejones19
Member#: 275250
2006 WRX
Replacing that A/C line took me 20 minutes. Better to not rub a hole in it, buts its really not that tough if it does happen.
stevejones19 is offline   Reply With Quote
Old 02-09-2013, 03:34 PM   #10
tmeck
Member#: 238719
no worries about the AC line, that's something I'm very aware of. I'm looking for suggestions on the IWG bit
Old 02-10-2013, 12:22 AM   #11
Type2
Member#: 200436
2004 Forester XT
Probably not the easiest solution, but you could always go with 8mm phenolic spacers plus OEM gaskets to get it to clear.
Type2 is online now   Reply With Quote
Old 02-10-2013, 07:59 AM   #12
finallymysti1
Member#: 335691
2006 sti
Ewg. Problem solved
finallymysti1 is offline   Reply With Quote
Old 02-10-2013, 02:06 PM   #13
RallySport Direct
NASIOC Storefront Vendor
Member#: 33174
We are Open Late!
888-457-2559 Every day!
From the images it looks like you have 2008+ STi intercooler.
If that is the case, due to the 08+ STi's having a larger intercooler then previous STi's there is clearence issues with certain brand turbo's that placed wastegates to only accommodate for the older GD STi intercoolers.
If that is the case your 3 options are to space the IC up, make a new bracket that will offset the wastegate away from the Intercooler, or do a EWG setup.
Hope this helps.
Kirill
RallySportDirect.com
RallySport Direct is offline   Reply With Quote
Old 02-10-2013, 04:05 PM   #14
nhat
Member#: 140163
03 STi
hellaflunctional
There's a 4th option: buy a better turbo.
Old 02-11-2013, 01:57 AM   #15
tmeck
Member#: 238719
Hope this helps.
Kirill
Thanks for the suggestions, how would I go about spacing it?
Old 02-11-2013, 02:23 AM   #16
nhat
Member#: 140163
03 STi
hellaflunctional
With washers?
Old 02-11-2013, 05:10 PM   #17
RallySport Direct
Member#: 33174
We are Open Late!
As nhat stated, washers would be your best way. Just keep in mind by doing that you will effect your IC to splitter clearance.
Kirill
Old 02-13-2013, 08:06 AM   #18
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
you could clock/rotate the wastegate actuator..
the pics are not that great as far as showing the orientation
of turbo hot side.
take off your tmic and take pics
Old 02-13-2013, 11:45 AM   #19
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
It the IC mounted to the oem mounting bracket on the other side? If so you can put the washers between the bracket and IC until it clears.
Mike
GrimmSpeed is offline   Reply With Quote
Old 02-13-2013, 05:21 PM   #20
bhpsti
Member#: 145941
2008 v10 jdm sti
wrb
I have just fitted a 20g from them the other week with the same actuator.
You will need to undo the two nuts that hold the actuator to the support plate and rotate 180degs.
The I/C will clear the actuator but it’s the nipple that is the problem. Turning it 180degs has the nipple pointing in the correct direction.
As mentioned it looks like you have the 08 sti onwards tmic which is longer then the 07 and below sti. I fitted a ETS tmic that was for a 08 onwards sti to my 03 jdm sti and it clears the actuator fine once it’s rotated.
bhpsti is offline   Reply With Quote
