Old 01-09-2013, 10:23 PM   #1
romanlynch
Member#: 126684
02 wrx
PLATINUM silver baby
Default Getting ready for my build and have questions
Im going to start building my 2.1 for my wrx and I had some basic questions. Ill be using Manley 92.5 stroker pistons, the stock TD04 but plan on an 18G or a 68HTA if I can find one later on.
My questions are:
Will factory case bolts, rod bolts and head bolts be ok or should I switch rod and head bolts to APR? Should I switch to head studs?
Do I order the complete engine gasket kit from Subaru or is there an aftermarket option?
Now to the important part, torque plate. Ive read the threads where 3MI and Maxwell (and others) say how important it is. Is this just used on the final honing part? And is there anyone that would lend me 1 plate, Id pay in full for it as long as I could get a refund minus the (your) shipping. PM me on that part.
Is there anything special I need to know about any of the machining work? Im at a school with a complete machine shop, including a 4 axis CNC so I should be covered on equipment Just unsure on the process of boring and honing, like any special adapters needed?
romanlynch is offline   Reply With Quote
Old 01-09-2013, 11:10 PM   #2
wrx1392
Member#: 342331
2003 wrx
blue
head bolts are not suppose to be reused ...the arp studs are very nice .i think you can reuse the block bolts as ARPs for that are very expensive.if you change the rod bolts you should have the big end resized.at least thats what i've always herd.
wrx1392 is offline   Reply With Quote
Old 01-09-2013, 11:28 PM   #3
kakarot09
Member#: 182375
08 Sti
Wrbm
Both the block and head bolts can be reused. I like arp head studs for every build though. They aren't that expensive and I think they're a good idea. The rod bolts can also be reused, not a bad idea to replace them though. For your goals I would just do new oem rod bolts.
kakarot09 is offline   Reply With Quote
Old 01-10-2013, 01:02 AM   #4
Flat 4 Motorsport
Member#: 295846
WRX FP HTA GT3076R
Sexual Chocolate
You can reuse all these bolts:
CASE
RODS
HEADS
BUT,,,,,I would replace rods and head bolts.
I usually tell my customers to replace those,
replacing case bolts is big business! don't let anyone talk you into replacing case bolts unless you have unlimited money
align hone is expensive!
just do new bolts,
@ $52 for all new bolts you cant beat that!
Flat 4 Motorsport is online now   Reply With Quote
Old 01-10-2013, 06:24 AM   #5
romanlynch
Member#: 126684
02 wrx
I'm actually putting together a bare block do I'll need case bolts anyways. Line hones free since I have access to the equipment, but really hoping I don't have to
Old 01-10-2013, 02:03 PM   #6
kakarot09
Member#: 182375
08 Sti
Wrbm
I should have mentioned some of this stuff earlier. I think the best option unless you have a bunch of money is new oem bolts for all of it. I still like arp head studs though. I trust them more. I notice no one mentioned the gasket kit yet. There is an aftermarket gasket kit but the oem kit is preferred.
For the machining you need the torque plate for final honing. You should also use it to set the ring gaps.
For special adapters etc I'm not sure since I don't do the machining myself. However I do know one shop local to me didn't have the right boring tool and sent me to another machine shop. The way the block is supported under the cylinders doesn't leave a lot of room so you need a boring adapter that can reach the bottom of the cylinder without hitting the block.
Old 01-10-2013, 02:23 PM   #7
romanlynch
Member#: 126684
02 wrx
Ok, the teacher said he's done suby's before so I guess we have the correct stuff.
Should I use Fuji bond or the permatex equivalent?
Do I use all factory specs for clearances, ie ring, bearing, piston? I've got a factory service manual.
Old 01-10-2013, 02:57 PM   #8
ILikeBeans
Member#: 173053
I like Hondabond or Yamabond for my builds. I haven't used any of the equivalents though, and I doubt I ever will.
ILikeBeans is offline   Reply With Quote
Old 01-10-2013, 03:42 PM   #9
spackyscooby
Member#: 169257
00 rsti & 04 fxt
millenium jade
After you get a new turbo are you going to rev past the factory redline?
spackyscooby is offline   Reply With Quote
Old 01-10-2013, 07:01 PM   #10
romanlynch
Member#: 126684
02 wrx
The red line currently is 6500 since the TD04 is out of breath ~5500, but yea I was planning around 7500-8k after I do that swap.
The crank and everything I can will be balanced, I've got an Adgency whatever crank pulley (1lb), an ACT lwfw (12lbs), and a driveshaft shop alum driveshaft. I don't know how much weight I lost with the ds but the crank and fw lost me ~20lbs.
Old 01-11-2013, 02:01 AM   #11
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
I usually buy a stroker kit because it gives you room to push the motor for more hp. I also just use gray silcone and have had no problems. I run 75k for red line. I use stock case bolts and arp for everything else.
Old 01-11-2013, 12:04 PM   #12
kakarot09
Member#: 182375
08 Sti
Wrbm
many people do not like some of the factory clearances. I would not do factory ring gaps with the forged pistons. You can run around .014 top ring gap with those goals in mind. I would do .0015 for main bearings and .0017 for rods. Many people run different clearances or target clearances though. I've seen mains around .001 all the way to .002 and rods are around .002 from most builders.
I use permatex ultra gray.
Old 01-17-2013, 10:58 AM   #13
romanlynch
Member#: 126684
02 wrx
This might be an odd question but here it is. I've read that the stock STi rods will handle the power and RPM that I'm looking for (300-350 @ 7-7.5k) but does anyone have the length of a new rod bolt handy so I can see if mine are streched at all? I'd like to reuse them but just want to make sure they're ok.
Old 01-17-2013, 11:01 AM   #14
04ScoobyWtf
Member#: 287974
For added insurance I would add the arp rod bolts. At high Rpms the factory bolts like to stretch
04ScoobyWtf is online now   Reply With Quote
Old 01-28-2013, 08:29 AM   #15
romanlynch
Member#: 126684
02 wrx
Would ceramic coating ($55) be worth it on the main & rod bearings? This is 98% daily driver. I'm using the ACL Race series.
Old 01-29-2013, 05:13 PM   #16
kakarot09
Member#: 182375
08 Sti
Wrbm
I don't think so but that's just me. This is one of those things that gets debated though. Tons of people use the bearings with no coating.
Old 01-29-2013, 06:36 PM   #17
romanlynch
Member#: 126684
02 wrx
Yea I know, I think I'm going to get it. I was talking with my teacher, who believes in this type of thing and it kind of makes sense to me. The coating lasts for a time and when it wears off I still have the normal bearing to use then.
Old 01-29-2013, 07:31 PM   #18
kakarot09
Member#: 182375
08 Sti
Wrbm
I understand it and for race teams I can see an advantage to doing the coatings on everything. But I've also pulled oem bearings from an Sti that looked perfectly fine at 70k miles. Most built engines on this forum never even make it to that anyway so I just see it as an unnecessary expense. If you have the money though hey why not.
Old 01-29-2013, 07:48 PM   #19
romanlynch
Member#: 126684
02 wrx
I want my engine to do that
Old 01-29-2013, 07:51 PM   #20
kakarot09
Member#: 182375
08 Sti
Wrbm
Haha me too actually. I really see no reason mine shouldn't do 100k. We'll see I guess.
Old 01-29-2013, 09:30 PM   #21
mopar3.0
Member#: 261696
2004 wrx
red
get the subaru gasket it comes with everthing including valve spring keepers and wrist pin retainers, exhaust gaskets and intercooler gaskets....
mopar3.0 is offline   Reply With Quote
Old 01-29-2013, 11:20 PM   #22
romanlynch
Member#: 126684
02 wrx
It comes with keepers too? Cool, it should be in tomorrow so I'll see what all it has. Freakin $315, I hope its more than a couple gaskets
Old 01-30-2013, 06:15 PM   #23
romanlynch
Member#: 126684
02 wrx
Well it didn't come with keepers but it had valve seals. Ordered my pistons today, sucks they won't get here till next Friday though :/
Old 01-31-2013, 03:24 AM   #24
wrx1392
Member#: 342331
2003 wrx
blue
shoot for the factory specs on the mains and rods .if you have a used block cosworth make 3 different size of bearings ,i used the size 0 which has .001 " less oil clearance...with a used block it brought me in spec. i have a ton of oil pressure ,also using the 2005 stock wrx crank that is cross drilled. and sti 11mm oil pump.
i agree with the guy above ...use the oem gasket kit ...it has all the O-rings you need ,i bought a cometic gasket set and it had no o-rings .and the head gaskets were twice the thickness of the oem . i like the arp studs also i think it helps keep the head gaskets happy when under serious boost.
Old 02-07-2013, 10:38 AM   #25
romanlynch
Member#: 126684
02 wrx
Made a little progress, cleaned up the casting on the crank, balanced the rods, re-ground the valves and figured out the bearing clearances. Going to freshen up the seats after break here shortly. I'm hoping to get my pistons Monday so I can finish hone and balance the crank and set ring end gaps. The plan is to have a short block by the end of next week, then all I have to do is port and polish the heads and get'er together.
Since I'm not sure how long it will be till I get the engine in the car, what should I coat everything with so it doesnt start to rust while it's in the garage?
