Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Bay Area Impreza Club
Go Back   NASIOC > NASIOC Chapters > Bay Area Impreza Club Forum -- BAIC
Old 02-08-2013, 10:15 PM   #1
Walwezzy23
Member#: 337851
2006 WRX
CGM
Default Ca Smog Help!!
hey guys i keep failing smog! EVERYTHING is completely stock but the car is running rich, though it was a bad cat changed that. thinking it is my front 02 but not sure. i got a Cell for a small evap leak (P0442 i think) any thoughts? Thanks in advanced for any helpful input.
Walwezzy23 is offline   Reply With Quote
Old 02-08-2013, 10:29 PM   #2
AWD Freak
Member#: 262593
You could check out this page for info on that code. http://www.p0442.com/
AWD Freak is offline   Reply With Quote
Old 02-08-2013, 11:23 PM   #3
paulpat
Member#: 237145
02 WRX
12 FXT
To determine if you are running rich you should get it scanned with a tactrix cable. Your A/F learnings will show with learningview.exe , if they are maxing at 15+ or - then you have a problem with your air/fueling system. My guess is that there is an excessive vacumm leak that is maxing out your A/F compensation at 15, and making you run rich. This could explain the destroyed cat.
So find some one with a Tactrix cable and a laptop already with Learning view and Rom Raider.
Local sub forums may come in handy. Offer beer for service.
paulpat is offline   Reply With Quote
Old 02-09-2013, 11:53 PM   #4
Walwezzy23
Member#: 337851
2006 WRX
CGM
thank for the advice man ill check if i can find someone!
Old 02-09-2013, 11:56 PM   #5
Walwezzy23
Member#: 337851
2006 WRX
CGM
if anyone has a Tactrix cable and the laptop i would appreciate it, ill offer cash since i despise beer. thanks in advanced if anyone is willing to help a fellow member out!
Old 02-23-2013, 06:02 PM   #6
subiejames
Member#: 345185
2007 Wrx
Aspen white
I have tactix cable but no laptop, let me know
subiejames is offline   Reply With Quote
Old 03-09-2013, 11:34 PM   #7
brodi11
Member#: 341291
2004 Impreza WRX STI
Bump^
brodi11 is offline   Reply With Quote
Old 04-02-2013, 09:18 PM   #8
2007_sti_412
Member#: 352237
2007 STi
Grey
I need some help too. I just moved from CO to CA, and I am now passing the emissions side of the test, but failing the visual test. Do I need OEM parts on my exhaust to pass the visual? I have a 2007 STi, with an Invidia N1 Cat Back Exhaust and Invidia Downpipe Catted. Originally I pretty much just had straight pipes to the muffler from the turbo and was failing the HC emissions side at idle, but with no cats and pass the visual.... I got the new exhaust, installed it, and now they say I am missing the rear cat and failing visual...
Any suggestions? or places to take it in San Luis Obispo?
2007_sti_412 is offline   Reply With Quote
Old 04-02-2013, 09:41 PM   #9
WillGeorge
Member#: 339409
2006 WRX
CGM
Put your stock dp back on its not hard. I got failed for a Perrin afta maf hose... It was lame...
Op
Consider using e85 for testing? I blew perfect 0's...
WillGeorge is offline   Reply With Quote
Old 04-03-2013, 11:42 AM   #10
2007_sti_412
Member#: 352237
2007 STi
Grey
I got the car used and it no longer had the stock dp. All the cats were cut out and a pipe was welded in place of the cats.
Any one have a downpipe I could borrow ?
Old 04-03-2013, 02:22 PM   #11
WillGeorge
Member#: 339409
2006 WRX
CGM
I do if you are near sac or wanna come pick it up. Also have a good smog place up here that doesn't look to far in. You will need all the basics, but I covered up a gimmick turbo inlet with a hose clamp in the right spot haha
Old 04-05-2013, 12:12 AM   #12
2007_sti_412
Member#: 352237
2007 STi
Grey
I just moved here. I'm guessing "sac" is Sacramento. I live in San Luis obispo... so that's quite a drive.
Old 04-05-2013, 12:25 AM   #13
WillGeorge
Member#: 339409
2006 WRX
CGM
Well if you have no other options lmk.
I may actually be coming to slo to pick up a part...
If you could put it on, pass, take it off in good time I have people I would visit anyway
Old 04-05-2013, 12:31 AM   #14
joebobanaught
Member#: 43566
2002 WRX Sedan
BAIC is aimed more for Bay Area and more northern CA. Maybe ask around on the SCIC forum. There might be more people close to you.
joebobanaught is offline   Reply With Quote
Old 04-07-2013, 01:23 AM   #15
Vanderkitten
Member#: 218648
2009 WRX
Spark Silver
I have one off of my 2009 in Berkeley you can def borrow doubt it likely won't not fit... but I think the vacuum lines are the issue with that error code. You can also got to a test and repair facility?
Vanderkitten is offline   Reply With Quote
Old 04-08-2013, 11:07 AM   #16
2007_sti_412
Member#: 352237
2007 STi
Grey
I found a guy in slo that is letting me borrow his OEM exhaust. Thanks for the help.
Old 04-08-2013, 04:06 PM   #17
Godzillaclaw
Member#: 348129
2008 WRX
You could bring it to EQ tuning in fairfield if you still havent figured it out im pretty sure they could diagnose it, and theres also a smog shop literally 50 ft from EQ.
Godzillaclaw is offline   Reply With Quote
