Old 02-08-2013, 10:16 PM   #1
Jake_ak_cent
Member#: 330383
Default Legacy no heat issues
New to these forums and new to Subarus. I recently got a new to me 93 BJ Legacy 2.2L. There is no heat from the vents. It does feel like there is some air movement from the vents, but I never hear a motor kick on, and dont really know if I should be hearing one. I've been doing some research and it looks like no heat is a symptom of a "phantom overheating" issue that was present in these cars. I'm trying pin down what is causing this before I just start throwing parts at it. Any help you guys can give me will be much appreciated.
Thanks,
-Jake
Jake_ak_cent is offline   Reply With Quote
Old 02-12-2013, 03:23 AM   #2
mcgarvey89
Member#: 346652
1991 Legacy L
Crimson Red
Check your heater core. If you have air flow but no heat that's where I'd start. Fairly cheap and easy to replace if necessary. Also check the lines leading to and from.
mcgarvey89 is offline   Reply With Quote
Old 02-13-2013, 11:13 AM   #3
Jake_ak_cent
Member#: 330383
Alright I'll check that. Is there different models for LHD cars and RHD cars because I have seen some people listing their heater cores as LHD Heater Cores and my car is RHD.
Old 02-13-2013, 11:15 AM   #4
thatderekguy
Member#: 301501
black
Wait, so it doesn't blow air period? Or it blows, just not hot air?
thatderekguy is offline   Reply With Quote
Old 02-13-2013, 07:13 PM   #5
Jake_ak_cent
Member#: 330383
On full blast, it'll blow a bit of cool air on cold (feels more like it should on setting 2) , and practically nothing on hot. Like if I held a pinwheel in front of it, it would struggle to spin it.
Old 02-13-2013, 07:34 PM   #6
SlverEJ20
Member#: 157158
05 WRX stage 2
Maybe a worn blower motor or bad climate control unit?
SlverEJ20 is offline   Reply With Quote
Old 02-13-2013, 08:48 PM   #7
Jake_ak_cent
Member#: 330383
Hmm I'll have to check those. Anybody know where I could find these parts that would work on my car?
Old 02-13-2013, 11:39 PM   #8
thatderekguy
Member#: 301501
black
Probably this.
Old 02-13-2013, 11:41 PM   #9
thatderekguy
Member#: 301501
black
If someone else would confirm this, I'm thinking this may be it.
https://www.carpartsdiscount.com/aut...ml?3593=305689
Old 02-17-2013, 02:56 PM   #10
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
If the fan is not blowing distinct speeds for each setting, It's likely a bad connection in the resistor in the blower housing (assuming Subaru has the same thing in that year vs. later years).
You can fix it yourself, or buy the part.
I did the fix on my wifes 1999 Impreza.
If the fan seems "OK" (not likely...but...), then a reverse flush on the heater-core may help. You can do it in the car, outside the car is "easier" for the flush, but more time consuming.
Basically, pull both heater-core hoses, run a hose (full pressure) through the "out" of the core and see if crap comes out.
Also make sure the system is properly "burped" to take an "air bubble" out of the issue.
