Old 02-09-2013, 12:06 AM   #1
pimprezawrx
Member#: 47807
2013 WRX STI Sedan
Satin White Pearl
Default 2013 STI Stage 2 Datalogs
Hey guys first time doing this.
Just got the accessport and Cobb catted downpipe last week. No other mods. Stock cat back.
2013 Sti sedan
Car has about 600 miles on it now. I couldn't take the stock tune any longer.
Stage2 93 v321 map
I did three 4th gear pulls in S#.
Everything felt ok and seems to look ok. Temp was low 60s tonight.
https://docs.google.com/spreadsheet/...nc&usp=sharing
https://docs.google.com/spreadsheet/...VE&usp=sharing
https://docs.google.com/spreadsheet/...Hc&usp=sharing
How do they look?
pimprezawrx is offline   Reply With Quote
Old 02-09-2013, 12:33 PM   #2
Cobb Tuning
Member#: 4803
These logs look great to me bud. You're underboosting compared to the target by a tiny amount, but no need to fret if the car feels good. Thanks for your support and please let us know if we can be of assistance in any other way.
Cheers
Lance
Old 02-12-2013, 11:52 AM   #3
pimprezawrx
Member#: 47807
2013 WRX STI Sedan
Satin White Pearl
Thanks for the reply. The car feels fine.
Maybe you or someone else can answer another question I have.
Compared to my old 03 stage 2 Wrx, when I punch the throttle at 2500 rpms to do these pulls, it sounds totally different.
Granted, I did have a full catless turbo back exhaust on the Wrx and maybe I am just hearing more engine noise with the stock cat back and catted down pipe on the Sti.
It sounds like it's "winding up" not really turbo noise but maybe fuel pump/injectors that I just never heard before? I don't really know how to explain it.
I hear it the most when I first get on the gas.
Thanks again!
Old 02-13-2013, 08:37 AM   #4
Cobb Tuning
Member#: 4803
Thanks again!
Stock catback will certainly let you hear a lot more (than just exhaust noise) than a catless full-turbo back exhaust. Different motors as well. I wouldn't be concerned about it.
Bill
Old 07-26-2013, 10:49 PM   #5
pimprezawrx
Member#: 47807
2013 WRX STI Sedan
Satin White Pearl
Ran a log tonight going through the gears.
Car was only boosting at most just under 17.
Seems low for Stage 2.
Made me want to run a log.
What do you guys think?
https://docs.google.com/spreadsheet/...2c&usp=sharing
Old 07-27-2013, 02:15 PM   #6
paul_p1
Member#: 77372
2005 Spec C
WR Blue
Hotter and humid outside? I'm guessing it is in Florida.
paul_p1 is offline   Reply With Quote
Old 07-27-2013, 04:17 PM   #7
pimprezawrx
Member#: 47807
2013 WRX STI Sedan
Satin White Pearl
Very hot and humid.
This log was at night around 10pm but probably still 85-90F and 100% humidity. Heat soak wasn't the issue because we were cruising at 80 mph for a while.
Old 07-27-2013, 05:25 PM   #8
Ryan321
Member#: 225014
2005 Impreza WRX STI
You have some feedback knock and learned knock. There shouldn't be and trailing knock a in a 2.0 continuous then tapering down to 0. I would bet if your on the OTS map then your timing is to high that's causing lower amours of knock and the 1.5 learned knock.
Ryan321 is offline   Reply With Quote
Old 07-27-2013, 05:54 PM   #9
paul_p1
Member#: 77372
2005 Spec C
WR Blue
The lower boost and subsequent lower air flow is due to the difference in atmospheric conditions. You may need to tweak some of the boost compensation tables, but in general you'll struggle to get the car performing in 90+ degree heat compared to whatever it was in February.....
Old 07-27-2013, 06:37 PM   #10
Ryan321
Member#: 225014
That's what I was thinking too but the ecu compensates for atmospheric changes. It's measured in bar and is set from the factory.
Old 07-27-2013, 06:54 PM   #11
paul_p1
Member#: 77372
2005 Spec C
WR Blue
Has Cobb altered those wastegate tables in particular though as part of the ROM, has it been tested in extremes? Genuine question. Subaru would have taken the car to the arctic circle and somewhere like Death Valley to develop the car.
Old 07-27-2013, 07:56 PM   #12
Ryan321
Member#: 225014
That's a good question. I always start from a fresh OEM map and adjust it from there. I'll check it out now.
Old 07-27-2013, 08:04 PM   #13
Ryan321
Member#: 225014
On my race tuner for my 05 STI between stock map and stage two there was no change.
Old 07-28-2013, 09:44 AM   #14
pimprezawrx
Member#: 47807
2013 WRX STI Sedan
Satin White Pearl
Drove the car last night after rain storm. Temps were in the 70s and felt a lot better. Didn't have time to do a log though.
Since I'm not hitting target boost would you guys recommend trying the high wastegate map? And yes, this is cobb ots stage 2 map.
Thanks
Old 07-28-2013, 07:17 PM   #15
Ryan321
Member#: 225014
Thanks
I suggest that you look at the knock and determine if it's false or a real knock event. Secondly I suggest you look at your timing map. I will let Cobb chime in about the rest. That's my two cents.
Old 07-29-2013, 08:49 AM   #16
Cobb Tuning
Member#: 4803
If you are comparing peak boost levels for STi, it is best to do a 4th gear (or 3rd gear if 4th is too fast) WOT run from 2500 RPM on up, if you can do so safely. Just as cold dry air is dense and improves the chances of higher boost/overboosting, the opposite is also true, hot humid air reduces air density and increasing the chances of underboosting. The additional problem you have with hot conditions is that you are increasing the chance of detonation. The stock tune actually decreases the boost target when intake temps are extreme - a feature we leave in our off-the-shelf (OTS) maps. I would not recommend running the HWG map during these extreme conditions, assuming at normal temps your car hits peak boost.
Other thing is to make sure you are in Sport # mode with these maps - Sport and Intelligent will run lower boost targets.
Bill
Old 07-29-2013, 09:37 AM   #17
pimprezawrx
Member#: 47807
2013 WRX STI Sedan
Satin White Pearl
Bill
Back in February when temps were in the low 60s I was peaking at 17.46 psi.
This was after 3, 4th gear wot pulls from 2500 rpms like you mentioned.
I believe Target boost for stage 2 STI is 19 +/- 1 psi.
I've never seen 18+ psi while having the AP plugged in using the boost gauge function.
Now that temps are in the 90s I'm seeing even less boost. (Which makes perfect sense after you explained the safety)
If I'm not hitting target boost even in cooler months, would it do any harm to try the hwg map and run a log?
Car has a cobb catted downpipe, stock mid pipe, muffler delete. No other power mods.
I'm not trying to hurt the car and would rather under boost then over boost, but just trying to find out I guess how much the HWG usually adds in psi.
Thanks for your help.
Old 07-29-2013, 09:48 AM   #18
Cobb Tuning
Member#: 4803
If you were not hitting within 1 psi of your peak boost target with a 4th gear only WOT run (in Sport #) when it was cooler out (given multiple runs), then you can give the high wastegate (HWG) map a try with careful data logging (if you can do so safely).
The reduction in target boost at high intake temps may not have occurred in your particular case (it takes very high intake temps) - I was just giving it as an example that even the factory strategy does not attempt to achieve maximum boost under all conditions (in fact, the stock strategy will also reduce boost at more extreme cold temps to help prevent running out of injector - something we also include in our tunes, albeit revised). But, your conditions can certainly drive boost down a bit regardless if the ECU is targeting "normal" boost levels.
Bill
