Welcome to the North American Subaru Impreza Owners Club Thursday September 18, 2014
Old 02-09-2013, 01:59 AM   #1
Alecb280
Member#: 324774
2003 WRX
Default At oil temp light flash
So I just had an engine swap done and now my at oil temp light is flashing. It's an auto trans 2003 wrx. What would be the cause for this? How do you fix it?
Alecb280 is offline   Reply With Quote
Old 02-09-2013, 12:01 PM   #2
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Check the fluid for starters
Old 02-09-2013, 07:26 PM   #3
Alecb280
Member#: 324774
2003 WRX
Checked they are all good
Old 02-09-2013, 07:34 PM   #4
Strider327
Member#: 131280
2004 Impreza WRX
It could be the throttle position sensor. Everything is all speculation at this point. I would download a program called FREESSM and get a Vagcom OD2 cable and read the codes.
Strider327 is offline   Reply With Quote
Old 02-09-2013, 11:46 PM   #5
Alecb280
Member#: 324774
2003 WRX
I read the cars manual and it said when the light is flashing the automatic transmission control system is not working properly. I'm bringing it back to the shop that did the swap Monday but I miss my car terribly it took a month to do the swap
Old 02-10-2013, 04:43 AM   #6
WRX_02_227
Member#: 12434
2002 WRX, 2015 WRX
2011 BMW 135i
What swap??
WRX_02_227 is offline   Reply With Quote
Old 02-10-2013, 09:18 PM   #7
Alecb280
Member#: 324774
2003 WRX
I blew my motor and swapped in a used one. Same ej205 I believe. Sorry if I'm incorrect.
Old 02-10-2013, 11:15 PM   #8
Big Joe
Member#: 3722
2002 WRX Wagon
Pull the code. Could be overheated, overfilled, bad sensor, etc.
Big Joe is offline   Reply With Quote
Old 02-11-2013, 02:58 AM   #9
Bikelok
Member#: 254851
2002 Wrx wagon 5mt
How does it drive? Does it drive normal?
How many miles on the transmission?
Do you feel torque bind? You will really feel this when you are going slow while making a sharp turn, the transmission will be fighting with itself (the car does not want to move without giving it more throttle than usual). You may also feel a lurch when you stop and turn off the car.
Bikelok is online now   Reply With Quote
Old 03-03-2013, 05:56 PM   #10
Alecb280
Member#: 324774
2003 WRX
I do feel the torque bind a bit. They told me the sensor was bad though
Old 05-07-2013, 11:13 PM   #11
Alecb280
Member#: 324774
2003 WRX
What causes this torque bind? And how can you fix it?
Old 05-07-2013, 11:29 PM   #12
Bikelok
Member#: 254851
2002 Wrx wagon 5mt
A bad duty c solenoid can do it, as well as a bad clutch pack. It could even be a bad electrical connection.
Start with all the elect. connections first. You can also try replacing the fluid which occasionally helps with a sticky clutch pack.
If those don't help then I'm sorry to say its probably the Duty C solenoid.
Not the end of the world, but...
Look up: 4EAT,16 Flashes of Death, or Torque Bind Sucks, or How to Replace a Duty C Solenoid.
^^^That big mess is the title.
Old 05-07-2013, 11:43 PM   #13
Trustkevin13
Member#: 259184
2008 Subaru WRX
damn good luck with that, I hope I wont deal with that in my 4eat
Trustkevin13 is offline   Reply With Quote
Old 05-08-2013, 04:35 PM   #14
Alecb280
Member#: 324774
2003 WRX
Thanks guys its most likely electrical because of the flashing AT oil light.
Old 05-08-2013, 11:46 PM   #15
Bikelok
Member#: 254851
2002 Wrx wagon 5mt
The flashing light does not necessarily mean an electrical problem only.
Old 05-09-2013, 07:37 PM   #16
CNY_Dave
Member#: 354655
It may not be electrical, but it has to be something the TCU can detect.
I know the TCU can detect a short or open on the transfer duty solenoid circuit, I know it can detect a bad vss, I dont know the mechanism by which it can detect a bad clutch pack, unless it calls for 'lockup' but still detects wheelspin.
CNY_Dave is offline   Reply With Quote
Old 05-13-2013, 11:44 AM   #17
Alecb280
Member#: 324774
2003 WRX
Ya i'm just going to take it into a shop soon. How much do you think these repairs will be? I know auto Trans repairs are expensive.
Old 05-13-2013, 12:34 PM   #18
CNY_Dave
Member#: 354655
It could be not bad or a lot. Could even be a bad TCU.
I'd make sure they are familiar with the AWD part of subes.
Old 05-14-2013, 02:35 PM   #19
Strider327
Member#: 131280
2004 Impreza WRX
Seems like 2002-2004 WRX's have planetary gear sets like the STI's. I'm betting its the Duty C Solenoid in the rear housing. However this is all speculation until you get the code read.
