Old 02-09-2013, 03:43 AM   #1
Mosting3
Member#: 296753
2005 V7 JDM STI swap
Default Aquamist nozzle size?
Hello Richard,
Am buying HFS-3 , but before doing so, i would like to know what nozzle size to use;
I have :
EJ207 V.7 STI,
1000 cc injectors
50/50 WM.
stock fpr
power band 375-400 WHP.
APS TMIC
What injector size come with the system? is it better to use dual nozzle or single? and what injector size do i need?
Thanks for your advanced help.
Mosting3 is offline   Reply With Quote
Old 02-09-2013, 01:04 PM   #2
carnz-pj-410
Member#: 110994
2004 Impreza WRX STi
If you go on the Howerton Engineering site, they have a page for Nozzle size calculation, it's a pretty simple formula and includes a chart to help with sizing.
carnz-pj-410 is offline   Reply With Quote
Old 02-09-2013, 02:56 PM   #3
Mosting3
Member#: 296753
Thanks, i have looked on the Howerton website, and from my calculation it seems i need 2x0.9 jets, but maybe 1x0.8 and 1x0.9 will work fine.
but my question, the fuel injectors that i have are 1000 cc, and the max i reached of IDC is 60-70%. will this change the formula?
I put 30 PSI as peak while i think the max i will reach is 26 PSI/
Thanks again.
Old 02-11-2013, 04:15 PM   #4
Aquamist
NASIOC Manufacturer
Member#: 110029
2004 Citroen Picasso
Here is a simple chart to calculate your jet requirement:
Aquamist is offline   Reply With Quote
Old 02-11-2013, 05:31 PM   #5
Mosting3
Member#: 296753
Richard, can you help me with my post #3? am i right? or am i missing something?
Thanks a lot.
Old 02-11-2013, 05:36 PM   #6
Aquamist
NASIOC Manufacturer
Member#: 110029
If you match the full flow capacity of fuel injector to the full flow capacity of the water jets, duty cycle % does not matter.
Old 01-06-2014, 12:18 PM   #7
streetking
Member#: 244036
I still can't seem to wrap my head around how to determine the nozzle size. I am on stock turbo and am boosting 20psi. I have DW 850cc injectors which flows 877cc average and am plan on runing 50/50 alcohol/water. What nozzle and restrictor should I pick? How to read that chart? I am just so dumb....
streetking is offline   Reply With Quote
Old 01-08-2014, 03:01 AM   #8
Aquamist
NASIOC Manufacturer
Member#: 110029
OK
1. Total fuel flow = 3508cc/min
2. M50:W50 flow = 3508 x 17.5% = 613.9cc/min
Your jets: 0.8+0.9 = 700cc/min @140psi (with a little bit of head room). The 0.7mm restrictor is ideal.
Old 01-08-2014, 09:21 PM   #9
streetking
Member#: 244036
Aren't I supposed to use the nearest larger restrictor to regulate flow? Isn't the .7 smaller than the .8 and .9 combined? Wouldn't the .9mm restrictor be a better choice? Sorry I am a total noob on this.
My peak IDC would only be around 70% or so...
Old 01-09-2014, 11:41 AM   #10
Aquamist
NASIOC Manufacturer
Member#: 110029
my fault, I meant 0.9mm.
