Old 02-09-2013, 08:36 AM   #1
crazyjester900
Member#: 323176
2004 WRX
Hey guys,
Would live some help with this.
Details are linked below!!
Cheers
Ok here are some pics of the wiring that I have done?
I am now out of ideas.....
... Any help would be great.
Front splits work fine?
Through this amp?
Sub can't get to work??
http://www.mobileelectronics.com.au/...8-test-a-sub/#
crazyjester900 is offline   Reply With Quote
Old 02-09-2013, 08:38 AM   #2
crazyjester900
Member#: 323176
2004 WRX
Old 02-09-2013, 08:38 AM   #3
crazyjester900
Member#: 323176
2004 WRX
Double
Old 02-09-2013, 08:39 AM   #4
crazyjester900
Member#: 323176
2004 WRX
Double
Old 02-11-2013, 07:11 PM   #5
mulagain
Member#: 319912
Id suggest you familiarize yourself with BCAE and you will most likely answer your question. It's nearly impossible to diagnose your issue on pictures alone and the description you provided.
Might take you an hour to read through the site but it's worth it!
mulagain is offline   Reply With Quote
Old 02-12-2013, 04:53 PM   #6
tec_41
Member#: 346278
04 WRX
Plug an old speaker into the sub output on your amp...See if it makes any noise!
tec_41 is offline   Reply With Quote
Old 02-12-2013, 09:34 PM   #7
mikereiser
Member#: 291941
2010 Wrx sedan
Really need more details, but you can try swapping rcas around to see if its an rca issue, or try the sub on a different channel that you know is working. You can also test the sub by touching the wires to the terminals of a drill battery or similar, you should get a popping noise.
mikereiser is offline   Reply With Quote
Old 02-13-2013, 07:07 PM   #8
mikemcl
Member#: 346961
2006 wrx
wrb
Use a meter to check for remote signal power 12v and main power 12v. Does your amp have a light or on signal to view? Most likely not a dead sub.
mikemcl is offline   Reply With Quote
