Old 02-09-2013, 06:54 PM   #1
p951951951t
Member#: 276541
1972 Alfa Romeo GTV
Alfa Rosso
Default Frustration abounds. Burned my paint with a rotary
So I've been working the car over with a rotary. I was using some meguires medium cut (#7). Everything was just peachy on the door.fender, then I got to the bumper. I hit it a couple times to try and remove some of the pitting. I wiped off after the last pass, and ****, I could faintly see the black color of the bumper showing through.
The paint on the bumper seems MUCH thinner than the paint on the rest of the car.
So, a lesson to all you out there who might decide to rotary polish your car - CAREFUL ON THE PLASTIC PARTS!
p951951951t is offline   Reply With Quote
Old 02-09-2013, 11:59 PM   #2
fr_awd
Member#: 333807
Yep. I had a repair guy attempt to repair some razor blade marks on my bumper. After 1 or 2 pass with some rotary machine, he stopped and showed me the black mark. The clear coat and paint is really thin on our cars.
fr_awd is offline   Reply With Quote
Old 02-10-2013, 01:25 AM   #3
neomax
Member#: 54585
2013 WRX
Not sure of what training you have with a rotary..... As you know our paint is thin by normal standards. However, when using a rotary you must also be aware of not just the paint thickness but the material you are working with. The door is metal which can disperse heat quickly, the bumper is plastic, it will retain that heat and you will burn through the paint very fast. The is especially true if your using a heavy cutting pad and cutting compound....
neomax is offline   Reply With Quote
Old 02-10-2013, 07:09 AM   #4
p951951951t
Member#: 276541
1972 Alfa Romeo GTV
Alfa Rosso
I was using a 6" microfiber pad and the meguires medium cut (7). I've had a hard time figuring out the properties of that particular formula. It seems very inconsistent, but I'm not sure if it's my technique or the compound itself.
Either way I will only be using the light compound at most (5) on the plastic parts.
I still have to hit the burned section with a swirl remover and machine polish, but I'm going to use a RA buffer instead of the orbital and go as light as possible.
Old 02-10-2013, 07:31 AM   #5
p951951951t
Member#: 276541
1972 Alfa Romeo GTV
Alfa Rosso
Pictures of the damage:
Old 02-10-2013, 09:47 AM   #6
I WANT AN STI
Member#: 79983
2005 STI
thats definitely unfortunate man. But look at the bright side, lesson learned. We all have learned that lesson once,it happens to the best of us even with light polishing compounds. You have to go either A, extremely slow or B, extremely slow and light. I normally dont even bother trying to use a rotary on bumpers even with a micro polish and a polishing pad unless I have painted it personally or it has been sprayed in the shop I work in, since I know there will be multiple coats of clear that wont burn through so easily. I try and stick with hand polishing or super duper light buffing on bumpers.
You may be able to get someone to spot that in if they know what they are doing with melting the clear and matching that color with a little soft line backtape on the body line. Only problem is its right next to the fender so you may have a little mismatch, but our bumpers rarely match from the factory anyhow so that should be of no real consequence.
I WANT AN STI is offline   Reply With Quote
Old 02-10-2013, 01:02 PM   #7
p951951951t
Member#: 276541
1972 Alfa Romeo GTV
Alfa Rosso
Honestly I may just do a respray on the front end next year. There is some damage to the lip area from the PO anyway. I had an alpine white 86 944 turbo a while back - I had the front end done at the shop where I used to work (PPG paint system) and the paint came out nearly an exact match. I can't imagine this one would be anymore difficult.
the only reason I was working so hard was because of all the pitting. I was able to remove most of it on the front of the fender so I kinda assumed I would be able to get to the same level safely on the bumper. That is not the case.
It's definitely a lesson learned, I'm pretty new to using a rotary so I guess I got a bit cocky. Too bad it couldn't have happened somewhere less obvious!
Old 02-10-2013, 01:09 PM   #8
D. FiSioN
Member#: 346219
2006 WRX STI
and a 12 Forester XT
Used some 3M P1200 and got mine a little to much on the 90 degree edge where the trunk meets the quarter. Took off about a 1/16th to the primer on the quarter side. Aaaaahhh! Delicate there.
D. FiSioN is offline   Reply With Quote
Old 02-10-2013, 03:05 PM   #9
I WANT AN STI
Member#: 79983
2005 STI
yea man anything with sharp edges gotta be super duper careful.
