Old 02-10-2013, 03:38 PM   #1
michaeld1992
Member#: 339302
2008 Outback
Default Front wheels not spinning?
I have a 2000 legacy 5 speed. I got stuck in my driveway today and only the rear wheels were spinning. I have no clue what is happening. I do have 16" wheels with bigger tires and stock is 15" could that be the prob? Pretty pissed because I bought the car for the AWD
michaeld1992 is offline   Reply With Quote
Old 02-11-2013, 02:46 PM   #2
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
Changing the size of the rims & tires should have no negative effects as long as all 4 are the same size (like 205/55-16) and similar wear.
I did a "plus 1" on my wifes 99 Impreza L wagon a few years ago. Went from 15" steelies to 16" aluminum rims. Tires were sized to get an original tire OD.
I would get your car checked out.
Old 02-11-2013, 03:17 PM   #3
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
You have an open front diff, an open rear diff, and a pretty weak viscous limited slip center diff. If the rear tires are on a really slick surface, the center diff just won't be able to transfer enough torque to the front wheels to do anything.
You can try lightly applying the brakes as the wheels are spinning - that will put some load on the spinning rear wheels and possibly get more torque to the front wheels.
It's possible you have a bad center diff, but it's more likely that you're just expecting the AWD system to operate in a way that it's not designed to operate. The AWD setup you have is very simple and is typically effective, but it's not a truck 4WD system with locking diffs, so there are limitations.
And as Charlie said, changing from 15" to 16" wheels has absolutely nothing to do with this.
Old 02-17-2013, 04:07 PM   #4
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Pat, thanks for the reply.
Michael, if you have ABS, you can do a "poor mans TCS" by applying a bit of brake so the ABS see's the speed difference and "unlocks" the stopped wheels while "braking" the spinning wheels allowing better power balance.
BTW, crappy tires are crappy tires, AWD or not.
Not picking, just letting you know.
