Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 02-11-2013, 12:03 AM   #1
leonbmx
Member#: 82864
2005 MPS Wagon HTA35
Domtuned Stage $$$$$
Default Pegasus 4430 Kill Switch ignition cut, which wire?
I am converting my 2005 STi to a dedicated track car, the other day I installed a pegassus racing 4430 kill switch , but when I flip the switch, nothing happens and the car just keeps running.
This is the diagram that I used:
For the ignition cut, I used the Main relay wire from the diagram here: 05 STi ECU Diagram - Plug B136, wire 7, main switch, under the assumption that if I cut that, the engine would die.
What am I doing wrong? Is there a different wire I should have interrupted instead?
leonbmx is offline   Reply With Quote
Old 02-11-2013, 01:09 AM   #2
WhatTurboLag?
Member#: 243992
2006 WRX TR
Cut main power to car with it, everything needs to have power cut when there's an emergency not just the engine
WhatTurboLag? is offline   Reply With Quote
Old 02-11-2013, 02:15 AM   #3
leonbmx
Member#: 82864
Yes, but which wire is that? I need to somehow stop the alternator from keeping the car running.
Old 02-11-2013, 08:26 AM   #4
WhatTurboLag?
Member#: 243992
2006 WRX TR
The wire right off the alt? Trace it to where it goes, im not too sure. The switch can take the direct load of that then just run it in the middle maybe.
Old 02-11-2013, 04:57 PM   #5
leonbmx
Member#: 82864
Ha, good thinking! I was thinking way too complex about this...
Old 02-11-2013, 05:12 PM   #6
dunk
Member#: 15359
It's easier just to cut the main ignition wire in the column that goes to the key. This will cut off the ECU. The battery cutoff will take care of the rest. I had this switch in my car for years.
Duncan
dunk is offline   Reply With Quote
