Old 10-22-2013, 06:03 AM   #51
BeachZone
Member#: 232668
'11 Sti Limited
Matte White
Aren't the blue filters made by Fram? Doesn't Fram suck?
-Beach
BeachZone is offline   Reply With Quote
Old 10-22-2013, 07:33 AM   #52
bluesubie
Member#: 767
04 FXT
Originally Posted by BeachZone View Post
Aren't the blue filters made by Fram? Doesn't Fram suck? -Beach
Yes (Honeywell actually). No.
-Dennis
Old 10-24-2013, 07:25 PM   #53
battlemike
Member#: 191771
2005 Subaru STi
Well, I checked today and the part number is the same. I'm unsure of the freaking date, I wasn't even interested to see it as the part number is the same and I'm obviously having an oil leak at the filter (I whipped it down in this pic...but you can see the leak at the o-ring).
The the dealer installed this...if it is the date that should not have been installed...this is sad, as I had my oil changed by them about a month ago.
Here's a pic...oh, I just happened to check my oil a week ago (it hadn't been long since the oil change) and my dip stick showed zero oil! My car was running fine. I then filled it up to the almost full line last week...it is now at the low part..wow. How do I know this hasn't messed up my motor...
battlemike is offline   Reply With Quote
Old 10-25-2013, 10:37 AM   #54
donnyjaguar
Member#: 363137
There are some videos on Youtube of Fram oil filters cut open to show how poorly they are made. Has anyone cut open a Subie OEM filter to have a look-see?
donnyjaguar is offline   Reply With Quote
Old 10-25-2013, 04:25 PM   #55
bluesubie
Member#: 767
04 FXT
Yes, about 345 times
-Dennis
Old 10-26-2013, 06:05 AM   #56
battlemike
Member#: 191771
2005 Subaru STi
I sure as hell am not using one anymore after this fiasco
So may i'll cut open mine
Old 10-26-2013, 08:47 AM   #57
battlemike
Member#: 191771
2005 Subaru STi
I'm at the dealer now (wilkins Subaru) they are telling me these filters are okay to use in certain vehicles...yet the info I read says for all Subaru that use this filter. Wow...stay away from Wilkins Subaru. I'm waiting for the to attempt to prove me wrong.
Old 10-26-2013, 11:19 AM   #58
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
-Dennis
Quoted for awesome.
mechatricity is offline   Reply With Quote
Old 10-26-2013, 06:02 PM   #59
AMCjavelin74
Member#: 368199
2004 Impreza 2.5 5sp
Red
Subaru OEM filters are fram? Hmmm I see "honeywell" stamped on my filter... and honeywell owns fram... yikes! I had one internally collapse on my 74 AMC Javelin (360 4bbl, 4sp, 3.54s)
AMCjavelin74 is offline   Reply With Quote
Old 10-28-2013, 11:41 AM   #60
donnyjaguar
Member#: 363137
Okay, I found the information. I wouldn't use the blue Subaru filters myself. They are just re-branded Fram. Pretty much anything else is better (not including the other Fram made off-brands of course). No sense in having brand-loyalty to Subaru for this kind of thing.
Old 10-28-2013, 12:33 PM   #61
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg "2+" 300hp/360trq
I ran OEM blue Subaru filters exclusively for over 100,000miles. There's nothing wrong with them.
A lot of you guys are getting all scared of some hypothetical scenario that I've yet to see happen on these cars.
Can anyone show me a single case where the OEM blue filter directly caused an engine failure? That is ignoring the recall that Subaru already addressed. But there's nothing wrong with any of the others. Sure they might be lower build quality, but who cares.
Does it still filter oil sufficiently? Yes.
Does it last the 3000-8000 mi OCI? Yes.
Then what more do you want?
gsrcrxsi is offline   Reply With Quote
Old 10-28-2013, 01:30 PM   #62
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
I don't understand why you people get so bat**** crazy about the oil filters. A good Bosch, mobil, or purolator filter will be as good as, if not better than the ones you pay $30 for from the dealer.
goregasm is offline   Reply With Quote
Old 10-29-2013, 12:05 PM   #63
donnyjaguar
Member#: 363137
This is my thought too. As for Fram, its not conjecture that cardboard end-caps, plastic bypass valves and poor attention to QC are more likely to result in oil filter-related engine failure. If you want to play Russian roulette with your engine, more power to you brutha!
Old 10-29-2013, 12:37 PM   #64
sk8eroyaker
Member#: 328067
2008 Impreza WRX
Thanks for the heads up OP, I'll be checking my stockpile of filters tonight.
sk8eroyaker is offline   Reply With Quote
Old 10-29-2013, 11:35 PM   #65
Scoobiesdoobies
Member#: 321546
2006 Wrx Limited
I always heard wix was the way to go ever since i had my fords.
But as soon as i was reading what filters the best everyone says oem subaru filters because of the bypass pressure.
Whats the big deal and if the filter was designed for the cars application shouldnt after market be designed similar and be the same pressure spec?
Scoobiesdoobies is offline   Reply With Quote
Old 07-15-2015, 10:46 PM   #66
Skankyfrankie
Member#: 354906
07 WRX
Default date code A43393 just installed leaking at gasket
I don't see how this little triangle shaped O ring could seal with the 1/16 or less crush before the outer can edge hits but I put it on anyway and guess what its leaking. It bottomed abrupt from loose to tight and hard, not gradually tightening like normal flat gaskets or even the round PL one gaskets. Got two more going to hit the trash.
Skankyfrankie is offline   Reply With Quote
Old 07-16-2015, 12:20 AM   #67
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
I've used hundreds of OE filters, and haven't had a bad one yet, although I've seen a couple of leakers.
Do you have an oil cooler? Are you sure it isn't leaking?
CosmoTheCat is offline   Reply With Quote
Old 07-18-2015, 08:25 AM   #68
Ernest
Member#: 45076
2004 Stg2 Wagon 4eat
Never had an issue with the blues.
Ernest is offline   Reply With Quote
