Old 02-11-2013, 04:49 AM   #1
ehawthorne521
Member#: 149686
2002 My name is Evan
and I am an Autoholic
Default DIY Extended bent shift lever
Hi there tonight I made an extended shift lever with a bend.
Here is what you will need if you want to make your own, the nuts and metal round cost about $12 so significantly cheaper similar products vendors. The quality obviously is up to you.
1/2" Metal round (Aluminum, steel, stainless steel what ever you want)
Long Nut thing M12x1.25 (or whatever your thread is for your shift lever)
Two Nuts M12x1.25
Tap and die set with M12x1.25
Cut-off wheel or saw
Something to bend the metal with, I used a pipe but be careful as you can break the metal.
Start by cutting the metal round. I used about 6 inches. (sorry I forgot to get pictures of the first steps but they are pretty simple)
Then in a vise bend the round to desired angle and cut the threads into it.
Thread one of the regular nuts on followed by the long nut like so.
Next put the other regular nut onto your shift lever. (I had to re-cut the threads thats why it looks funny)
Put the assembly on and tighten the bottom nut up to the long nut so they don't come loose.
Place the lever where you desire and tighten down the top nut, this keeps everything from moving pretty well.
Pull the boot up onto lower nut.
And finished, well kind of...
You can thread the top and add a knob but I am planning on fitting a foam grip to the bend so I have a nice handle to grab like this
These are bike handle bar grips but you get the idea. Thanks for looking! Hope you found this somewhat useful.
ehawthorne521 is offline   Reply With Quote
Old 02-11-2013, 10:50 AM   #2
WRXSteye20008
Member#: 175565
2014 Sport Premium
Past: 351awhp Sti
That's interesting. Why the fire extinguisher on the passenger side floor well?
WRXSteye20008 is offline   Reply With Quote
Old 02-11-2013, 10:53 AM   #3
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Doesn't want to end up like XIII
Psychoreo is offline   Reply With Quote
Old 02-11-2013, 11:40 AM   #4
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Track car maybe? I have a fire extinguisher in front of the passenger seat.
Old 02-11-2013, 12:06 PM   #5
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Why did you recut the threads? Only had a standard thread cutter? Metric cutters and nuts can be found at any ACE hardware for a couple of dollars.
Old 02-11-2013, 03:29 PM   #6
ehawthorne521
Member#: 149686
Better to be safe than sorry, plus I got it on sale
I actually couldn't find the metric nuts I needed, being that it was Sunday and most stores that carry the metric fasteners were closed and I'm impatient I just went with what it had since cutting threads isn't too hard.
I am getting some pipe insulation to see if it will work for the grip today.
Old 02-11-2013, 08:50 PM   #7
ehawthorne521
Member#: 149686
Finished it up today with some handle bar tape.
Old 02-11-2013, 08:55 PM   #8
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
that looks like garbage
Old 02-11-2013, 09:11 PM   #9
ehawthorne521
Member#: 149686
Thanks for the honesty friend, I don't think its that bad. It is comfortable and works well so I am pleased over all.
Old 02-11-2013, 10:35 PM   #10
aerosaaber
Member#: 33850
2006 WRX Wagon
WRC Blue
I wouldn't want to use a metal that can "break" easily. But if you like it, you like it. That's basically the end of the story.
I would suggest painting the exposed metal section as well.
aerosaaber is offline   Reply With Quote
Old 02-11-2013, 10:53 PM   #11
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
1998 Declasse Moonbeam
Heh, I have two extinguishers plus a plumbed in halon system......
Then again it is an air cooled VW (and a camper)
Old 02-11-2013, 11:22 PM   #12
ehawthorne521
Member#: 149686
I should clarify, I meant breaks easy when using a two foot pipe for leverage to bend it. No worries about exposed metal as it is aluminum and stainless except for aesthetic purposes. I was thinking about painting it but it would get messed up when I tightened it down.
Old 02-12-2013, 12:46 AM   #13
WRXSteye20008
Member#: 175565
2014 Sport Premium
Past: 351awhp Sti
I was just wondering, our rally car has the halon system as well and an extinguisher in the back, not seeing to many people put it up front. Your shifter's final product looks like you broke the end off a golf club from the 80's, I hope you have that sleeve already ordered
