Old 10-14-2013, 12:43 PM   #101
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Originally Posted by unclemat View Post
For the record, the taller 5-6th are JDM Forester STI gears. Same ratios as USDM SpecB but actually different gears that match the keyways in 08+ STI 6MT. I had the same work done by Rallispec to my 08 STI tranny.
Yes, that is correct! The part numbers are not technically from the Spec B, but the ratios are the same so that's what they've become known as.
xluben is offline   Reply With Quote
Old 11-03-2013, 11:00 PM   #102
CamGoy
Member#: 367348
2009 WRX Hatchback
Perry Tuned
is it possible to use the clutch and flywheel from the 5mt for the 6mt?
CamGoy is offline   Reply With Quote
Old 11-04-2013, 08:20 AM   #103
Ryan91
Member#: 311300
2011 WRX Sedan
Spark Silver
No, there are different.
Ryan91 is offline   Reply With Quote
Old 11-11-2013, 07:02 PM   #104
WhatsASubie
Member#: 362544
2013 Wrx
satin white pearl
How much did you send in total for the swap. hoping someday ill do this (:
WhatsASubie is offline   Reply With Quote
Old 11-11-2013, 07:42 PM   #105
norexyet
Member#: 39149
11 elantra
yea i said elantra
They are different but you can definitely use a 5mt clutch/flywheel in a 6mt.
norexyet is offline   Reply With Quote
Old 11-11-2013, 08:11 PM   #106
unclemat
Member#: 114530
2005 LGT 6MT wagon
^ Pull type only.
unclemat is offline   Reply With Quote
Old 11-11-2013, 08:31 PM   #107
norexyet
Member#: 39149
11 elantra
yea i said elantra
^ Pull type only.
Right. I assumed most people knew that, I know better than that
Old 11-21-2013, 07:05 PM   #108
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Exactly what most people are looking for. Them longer gears.
Drives like a 5spd with a highway gear
FuJi K is offline   Reply With Quote
Old 11-21-2013, 07:09 PM   #109
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
For a daily driver the longer 5th and 6th are perfect. For a drag car the normal 07+ STI 1st-4th will do the job for nearly all cars as long as you rev them enough. Fuji knows all about this
Old 11-22-2013, 11:33 AM   #110
kenliu84
Member#: 107618
2006 OBP WRX Wagon
PrecisionTuned/TiCSuspen.
What revs are you at when cruising at 75mph?
kenliu84 is offline   Reply With Quote
Old 11-22-2013, 12:48 PM   #111
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
You can expect a little higher but shouldn't be near 3000 at all.
Old 11-22-2013, 01:30 PM   #112
kenliu84
Member#: 107618
2006 OBP WRX Wagon
Higher than what? I'm currently running a 07 STi 6-speed and at 75 mph, I'm a tad over 3,000 rpms. Trying to see what this spec B 6th gear brings at that speed. I'm interested because my tuner kept it at closed loop until 3, 000 rpms after we discussed fuel economy during my last tune.
Old 11-22-2013, 05:21 PM   #113
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Higher than what?
What you see on the picture above.
Is that so!
http://m.autoblog.com/2013/11/01/new...-limit-75-mph/
Old 03-15-2014, 01:08 AM   #114
borderguy
Member#: 333855
1999 Forester S
2011 Forester X
Thanks for such a thorough write up. Now I know exactly what I need in the future when a swap is needed and not to fret the compatability of my 5x100 wheels and the 5x100 brembo kit I see in my future
borderguy is offline   Reply With Quote
Old 10-25-2015, 03:01 AM   #115
Scoobyflat4
Member#: 432866
I have a 2012 wrx hatch I'm going to do this in. So the 6 speed bolts right up to the motor no problem? Do I need the sti clutch line or will the wrx one work? How hard was it to hook up the dccd pro? Are the wrx front axles still good enough? Or should I get sti fronts?
Scoobyflat4 is offline   Reply With Quote
Old 10-26-2015, 10:07 AM   #116
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Get a MapDCCD instead.
Old 10-27-2015, 05:07 PM   #117
Scoobyflat4
Member#: 432866
OK, how did it drive without it? You said you didn't install right away. Not sure I'm going to have the time to install it when I do the Trans swap. Will it be ok for a couple weeks without the mapdccd?
Old 10-28-2015, 03:32 PM   #118
Scoobyflat4
Member#: 432866
Nvm I saw your comments further back. I'll be ok. My last question why do I need 3 more flywheel bolts I thought the bolt patterns were the same between wrx and sti?
Old 10-28-2015, 04:23 PM   #119
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Yes, you can drive it with the diff open. It won't really hurt anything unless you're doing constant burnouts/donuts.
WRX has 6 bolts and STI has 9.
Old 10-29-2015, 10:31 AM   #120
Scoobyflat4
Member#: 432866
OK but it will still bolt to my crank though correct? No special adapters, just 3 extra bolts? That's strange. Thank you for all the help xluben, I bought an 08 Trans, diff and axles, with some odds and ends with it. I just wanna make sure when it gets here I have all my bases covered. Your thread by far has been the most helpful. And with the mapdccd did you like the preloaded auto settings or did you go further and make you own settings?
Old 10-29-2015, 11:05 AM   #121
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Yeah, it will bolt up. Just use the extra bolts.
I have played with some custom ones for drag., but the auto settings on the MapDCCD look great.
Old 10-29-2015, 12:51 PM   #122
Scoobyflat4
Member#: 432866
Yeah I went on the website, doesn't seem to hard to hook up. Just time consuming if anything. Did it give you much trouble wiring up?
Old 12-21-2015, 03:09 PM   #123
Delphi
Member#: 239335
2011 WRX
When you pulled your rear diff. Did you leave the axles in and drop it out as an assembly?
Delphi is online now   Reply With Quote
Old 12-21-2015, 06:23 PM   #124
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg "2+" 300hp/360trq
That's what I did.
gsrcrxsi is offline   Reply With Quote
Old 12-22-2015, 03:15 PM   #125
Delphi
Member#: 239335
2011 WRX
Thanks that helps a bunch.
