Old 02-11-2013, 03:16 PM   #1
13_DGM_Hatch
Member#: 331661
2013 Impreza WRX
Dark Grey Metallic
Default Gas question!
So I have a 2013 wrx with stage 2 protune for 93 octane. My dad took my car for the day and he decided to put gas in it, but he put 91 in instead of 93. It had half a tank and he filled it so it now has half 93 and half 91 in it. How bad is this for my car?
13_DGM_Hatch is offline   Reply With Quote
Old 02-11-2013, 03:20 PM   #2
rexspeedworthy
Member#: 26965
2013 XV crosstrek
Stay outta boost. Drive this tank in valet mode... or better yet, let your dad switch cars with you till he drives the out the entire tank...with no boost. There's a sticker right on the gas door.
rexspeedworthy is offline   Reply With Quote
Old 02-11-2013, 03:21 PM   #3
Amazing Asian
Member#: 259589
05 Saabaru 9-2X
Deep Blue Metallic
Just baby it and take it easy till you refill it back with 93. Don't get sucked into the octane booster products either.
Amazing Asian is offline   Reply With Quote
Old 02-11-2013, 03:22 PM   #4
13_DGM_Hatch
Member#: 331661
2013 Impreza WRX
Dark Grey Metallic
What does a sticker have to do with anything? He got it filled at a service station, therefore he didn't read any stickers lol.
Old 02-11-2013, 03:33 PM   #5
13_DGM_Hatch
Member#: 331661
2013 Impreza WRX
Dark Grey Metallic
Ok that's what I figured. Thank you!
Old 02-11-2013, 04:02 PM   #6
paulpat
Member#: 237145
02 WRX
12 FXT
there is a sticker that says premium only. its not bad. bad. CA has only 91....
paulpat is offline   Reply With Quote
Old 02-11-2013, 04:06 PM   #7
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
91 just detonates faster than 93, but as long as he wasn't going WOT and shifting that thing like a racecar, you should be fine. Smack him and make sure he never uses anything but 93 ever again. EVERRRRR.
Mr Wrex is offline   Reply With Quote
Old 02-11-2013, 04:06 PM   #8
snowboarder2587
Member#: 322407
2012 WRX Limited
Plasma Blue Pearl
Are you protuned through an AP or opensource? If the AP then (depending on your mods) you can put the cobb stage 2 for 91 on it until this tank is empty and then switch back when you refill 93
snowboarder2587 is offline   Reply With Quote
Old 02-11-2013, 04:10 PM   #9
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Stop.
OP, on your AP you can go in and retard timing upto X degrees. (I believe 5) Do that and you'll be fine. Or you can flash over a 91 octane map if you are THAT worried about it. However half a tank of gas isn't going to kill your car.
Old 02-11-2013, 04:42 PM   #10
13_DGM_Hatch
Member#: 331661
2013 Impreza WRX
Dark Grey Metallic
Originally Posted by HinshawWRX View Post
Stop.
Thank you. I'm open source tuned but ill just be sure to take it easy until this gas is run through.
Old 02-11-2013, 04:44 PM   #11
13_DGM_Hatch
Member#: 331661
2013 Impreza WRX
Dark Grey Metallic
Haha I already told him my car only takes 93 but I'm not gonna smack him because he was generous enough to fill my tank so I guess it's the thought that counts lol.
Old 02-11-2013, 04:44 PM   #12
13_DGM_Hatch
Member#: 331661
2013 Impreza WRX
Dark Grey Metallic
Open source tuned so I can't switch maps at will unfortunately.
Old 02-11-2013, 04:49 PM   #13
luan87us
Member#: 335013
2013 Premium WRX 5dr
one more reason for me to go with Cobb instead of a pro-tune. Less hassle.
luan87us is offline   Reply With Quote
Old 02-11-2013, 04:56 PM   #14
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
Both open source and AP's have their advantages and disadvantages.
Old 02-11-2013, 05:24 PM   #15
13_DGM_Hatch
Member#: 331661
2013 Impreza WRX
Dark Grey Metallic
You could always get a protune using the accessport. Best of both worlds.
Old 02-11-2013, 05:46 PM   #16
flukewrx
Member#: 75081
2003 WRX
Are you sure about that? I thought that was one of the reasons to go with an Open Source Tune so that you could easily switch maps as need be.
flukewrx is offline   Reply With Quote
Old 02-11-2013, 05:51 PM   #17
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
You can switch maps fairly easily on both, AP being the easiest. Open source you need a tactrix cable, which OP might not have.
Old 02-11-2013, 05:53 PM   #18
13_DGM_Hatch
Member#: 331661
2013 Impreza WRX
Dark Grey Metallic
Yeah I don't have a tactrix. If I did would it be fairly easy to switch maps via laptop?
Old 02-11-2013, 06:08 PM   #19
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
Of course. The COBB AP is nothing more than a cable and a mini-computer, which is the same as the tactrix and a laptop. Just download COBB Tuner Race beforehand.
Old 02-11-2013, 06:43 PM   #20
13_DGM_Hatch
Member#: 331661
2013 Impreza WRX
Dark Grey Metallic
Yeah that makes sense. Thank you.
Old 02-11-2013, 07:23 PM   #21
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
yes, stay out of boost and get 93 in immediately. Reset the ECU once 93 has been put in as well.
BlazeRex is offline   Reply With Quote
Old 02-11-2013, 08:13 PM   #22
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
An ECU reset will do NOTHING. He can still hit boost, the ECU will compensate. Stop giving bad advice.
Old 02-11-2013, 08:33 PM   #23
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
LOL? when the car has learned knock correction, resetting the ecu once fresh 93 is put in will reset that back to zero. Not sure how that's bad advice?...
Old 02-11-2013, 08:38 PM   #24
wrX-MEN
Member#: 330488
03 WRX
Just don't drive crazy! and like what everyone else is saying stay out of boost! drive around for couple of hours non stop and it wouldn't take long to empty the tank of the subie since gas mileage is around 19-22mpg
wrX-MEN is offline   Reply With Quote
Old 02-12-2013, 12:01 AM   #25
mclrn227
Member#: 83441
2013 5DR WRX
Wait, someone pumped the gas for him? Is this 1950?
mclrn227 is offline   Reply With Quote
