Old 02-11-2013, 09:59 PM   #1
bman59
Member#: 344529
2012 Impreza Sport
Grey
Default Impreza Sport Exhaust Tip?
Ok so I know this is probably a really dumb question, and I am really new to car stuff so please go easy on me. On my '12 impreza sport (5 door) I want to know if there is an exhaust tip that will fit. The impreza exhaust points down and is not visible, and I would really like to be able to see the it. I am guessing that there may be some sort of tip that curves out under the bumper so you can see it without looking under the car?
bman59 is offline   Reply With Quote
Old 02-12-2013, 12:50 AM   #2
garzdos
Member#: 333423
2012 WRX Hatch
Dark Gray Metallic
Go to your local exhaust shop...they can hook you up...or measure the diameter of your exhaust then go to an autoparts store and buy a tip you can put on yourself with a drill and screws. Exhaust shop job should/would look better as then can spot weld it on versus you using a few screws, but the screws will likely not show and it would be cheaper to do yourself.
Your call!
garzdos is offline   Reply With Quote
Old 02-12-2013, 02:28 PM   #3
danstheman7
Member#: 331089
2012 Impreza Base
DGM/Dark Grey Metallic
If you want the look and sound, get a muffler like the Magnaflow 11236, and get a tip for it done at a shop. If you just want the look then get something like the perrin
danstheman7 is offline   Reply With Quote
