Old 02-11-2013, 10:23 PM   #1
MoFoHead
Member#: 90452
2016 WRX
Default Catbacks that mate with a donut gasket DP
First off, I apologize if this question has been entertained before (and I'm pretty sure it has) but I've searched and searched and could not find a definite answer.
I currently have a Cobb downpipe mated with my stock catback. I'm looking for catbacks that will mate with the donut gasket style of downpipes or information on how others are mating flanged catbacks with the donut gasket DPs.
I saw the grimspeed downpipe to catback adapter but that looks like it is intended to go the other way (donut gasket style catback to a flat flange downpipe). Am I wrong?
Any info would be much appreciated. Thanks.
MoFoHead is offline   Reply With Quote
Old 02-11-2013, 10:36 PM   #2
Navendra94
Member#: 327495
2012 Impreza WRX 5DR
Plasma Blue
Cobb catback.
Navendra94 is offline   Reply With Quote
Old 02-11-2013, 10:41 PM   #3
MoFoHead
Member#: 90452
2016 WRX
Originally Posted by Navendra94 View Post
Cobb catback.
Wow, that was very informative.
Old 02-11-2013, 10:58 PM   #4
tommyson01
Member#: 154579
2005 OBXT
Old man blue
Do your homework and start shopping around. Asking to be spoon fed info around here won't get your very far.
tommyson01 is offline   Reply With Quote
Old 02-11-2013, 11:21 PM   #5
happs subi
Member#: 200288
2002 Impreza WRX
World Rally Blue
The Cobb catback works if I remember correctly
happs subi is offline   Reply With Quote
Old 02-12-2013, 12:18 AM   #6
MD04WRX
Member#: 72891
2014 Molten ST
2000 2.5RS - 2014 XV
Borla Hush and SPT
You can bolt a 3" catback to the donut style downpipe with a 3" gasket. I was running a Perrin that way and it worked ok.
MD04WRX is offline   Reply With Quote
Old 02-12-2013, 12:37 AM   #7
MoFoHead
Member#: 90452
2016 WRX
Well I suppose I should have mentioned the obvious that I was well aware that the Cobb catback works. And thanks for your worthless input Tommyson01. I've sort of been "doing homework" for quite some time and was looking for some useful input...not for you to "spoon feed me". Apparently NASIOC has officially turned into every other ****ing forum on the internet.
Old 02-12-2013, 12:38 AM   #8
MoFoHead
Member#: 90452
2016 WRX
Originally Posted by MD04WRX View Post
Borla Hush and SPT
Thanks for the input. This is what I was looking for and its appreciated.
Old 02-12-2013, 07:10 AM   #9
blue sedan
Member#: 311622
2010 WRX
Magnaflow. Cheaper than Cobb and better quality than SPT.
blue sedan is offline   Reply With Quote
Old 02-12-2013, 08:31 AM   #10
happs subi
Member#: 200288
2002 Impreza WRX
World Rally Blue
Dude I swear I thought the Cobb works. I'm sorry if you bought the wrong one. If not, I'm sure the wrx catback fits
Old 02-12-2013, 08:32 AM   #11
MoFoHead
Member#: 90452
2016 WRX
I found a nice magnaflow in the classified section a few weeks ago. So far the magnaflow and cobb were the only ones that I found that would bolt up to the Cobb downpipe.
But it sounds like no special adapter is going to be needed to go from flange catback to the donut gasket DP. So pretty much about anything should work....or least that what it sounds like.
thanks!
Old 02-12-2013, 09:06 AM   #12
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
This attitude will get you far here.
You asked for catbacks that mate up to a donut gasket.
He mentioned Cobb. (Which does, btw)
You make a sarcastic reply about how informative he is. Then you say you know the Cobb catback works. Why didn't you say that in the first place? We can't read minds.
Don't be a dickhead if you're trying to get spoon fed info that's readily available.
vision.dynamix is online now   Reply With Quote
Old 02-12-2013, 09:42 AM   #13
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
1050 Triumph Speed Triple
By searching the technical forums for the word "donut" and "gasket" I found a number of threads that provided information on this topic.
I'll let you do your own research there, but after a quick 5 second look through each thread I saw, it looks like the following will work:
Perrin
Search
Cobb
MadDad
Button
SPT
Grimmspeed
Invidia N1
Good luck!
Loyale93 is offline   Reply With Quote
Old 02-12-2013, 09:44 AM   #14
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Perrin
Search
Cobb
MadDad
Button
SPT
Grimmspeed
Invidia N1
Good luck!
I want a Search cat back.
Old 02-12-2013, 10:03 AM   #15
MoFoHead
Member#: 90452
2016 WRX
Well forgive me for assuming that most people would have enough common sense to know that a Cobb catback would mate with a Cobb downpipe.
I didn't come here to argue with people....I genuinely needed information because IF the information is readily available I obviously missed it. So if this information is readily available in a FAQ or a sticky, please point me in the right direction. That would help much more than people like you or the other guy above bitching about me wanting to be spoon fed.
I simply came here looking for some advise as almost everybody here has some experience with exhaust. My only experience was with my last suby which was a cobb tbe. I failed to mention in my initial post that I was already aware the cobb and magnaflow catbacks would work. But without contacting every single manufacturer to ask what type of catback they make (gasket vs flange) how is one supposed to know? Which is what I thought these Subaru communities were for. But with this debate people are behaving more like this is a 4chan thread.
Old 02-12-2013, 10:06 AM   #16
MoFoHead
Member#: 90452
2016 WRX
Perrin
Search
Cobb
MadDad
Button
SPT
Grimmspeed
Invidia N1
Good luck!
Thanks....apparently I was making my search criteria more complicated than it needed to be.
