Old 02-11-2013, 10:30 PM   #1
colt_4590
Member#: 306908
2003 WRX
Default kinugawa turbo?
After doing some reasearch ive decided I'm gonna go with one of these turbos. Now my question is I wanna go with a 20g but they have 3 different options.
Td05h td06h or td06sl2 I wants power I'm not to worried about spool. 7 or 8cm turbine?
colt_4590 is offline   Reply With Quote
Old 02-11-2013, 10:41 PM   #2
wrx1392
Member#: 342331
2003 wrx
blue
20g is kinda big for a 2.0 it going to make power way up in the rpm range.no bottom end. i just did a 16gxt on mine and it spools nice and has lot of boost for top end.
wrx1392 is offline   Reply With Quote
Old 02-11-2013, 10:58 PM   #3
colt_4590
Member#: 306908
2003 WRX
I want to beat v8s I was told I need a 20g turbo for that
Old 02-12-2013, 12:31 AM   #4
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
I ran a td06-20g on mine, It spooled at 4k and made 325 whp. It was fun and not laggy if you know how to drive,
Old 02-12-2013, 07:34 AM   #5
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
You also are a 2.1 stroker with cams and meth.
If you have a stock 2.0, a td05h 20g with an 8cm hotside would be really stellar provided you can run e85 and not worry about the trans.
Zee Biker is offline   Reply With Quote
Old 02-12-2013, 08:00 AM   #6
Harbs
Member#: 335235
05 Liberty GT
Dude.. my stock fv38 twinscroll 2.0 will run head to head with a 5L V8 up to about 100mph.. then the V8 eats me. Small turbo. 3.5k stall, auto.
From the lights, (I mean the dragway lights on a 20g turbo... you'd take a good precious seconds to hit the 4.5-5k rpm you'd need to just spool it... the V8 would get nearly 100-150 yards on you before you hit boost.
After the 20g comes on you would b ****ing flying.. but you gotta catch up a long way and it's not cool on saturday night fast food cruises. I don't use the 160+ mph range much though. I might be an idiot. heh
16g is awesome. 18g if you wanna go racing. 20g for dyno numbers.
I'd reccommend a 18g td05 for maximum lolz.
Edit:- Also 20g, td06.. you'll stress your engine to pieces if you hitting 400-500hp/Stupid torque, every time the tacho hits 5k (full boost)..gear change at 7k+.. fun but only for a short while before you gota fix it I think. And you gotta get to high revs to enjoy it.
Harbs is offline   Reply With Quote
Old 02-12-2013, 09:46 AM   #7
colt_4590
Member#: 306908
2003 WRX
So a 18g would be the biggest turbo to for the steet? A td05 20g would be to big?
Old 02-12-2013, 09:48 AM   #8
insaneimpreza
Member#: 83291
1998 RSTi
IAG Stg4 Extreme S366SXE
I ran a td06 20g, 8cm hotside on my 2.0l. The lag wasnt anything to cry about. If you get a good tune from someone that knows how to make a larger turbo spool up better, you wont be disappointed. I would get full spool in 4th at 4250 and rev to over 7k on my stock motor. Did a best of 11.6 @ 122 with that setup on my car, totally stock engine.. Oh, and it made 346whp with the internal wastegate. I never got to dyno it with the external and meth on the car. The 346 was with 22psi.
insaneimpreza is offline   Reply With Quote
Old 02-12-2013, 10:24 AM   #9
colt_4590
Member#: 306908
2003 WRX
I want a 20g because I dont wanna look back and wish I would have gone bigger. I will also do ewg. Would the 18g or td05-06 20g be better for the street
Old 02-12-2013, 10:24 AM   #10
D-Rodman
Member#: 110078
05 saabaru artc gr
02 wrx wag wrb ej207
Your engine still runs with that same setup or did you change setup?
D-Rodman is online now   Reply With Quote
Old 02-12-2013, 10:45 AM   #11
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
1. You have not read http://forums.nasioc.com/forums/show....php?t=1218459
2. You obviously don't know if you are afoot or horseback on turbos, so you NEED to research.
3. I can list probably 200 4 cylinder cars that will beat you regardless of what turbo you have....you set GOALS with your car in terms of WHP and go after them, not "beating V8s".
4. You are obviously young....take some sage advice: Research twice, purchase once....otherwise you will be throwing good money after bad.
Old 02-12-2013, 11:28 AM   #12
insaneimpreza
Member#: 83291
1998 RSTi
I ran it like that for a few years, prolly 100+ passes on the car with the 20g on it. Its mainly my track car, but I do DD it when I get bored with driving my truck all the time lol.. Still got really good gas mileage in the car!
I ended up finally killing it using the GroupN rom with the aggressive launch control. Was having too much fun doing 4 wheel burnouts and spun a rod bearing eventually. Im putting a LGT motor and drivetrain next weekend.
Old 02-12-2013, 11:38 AM   #13
ppayer38
Member#: 234407
04 Self-tooned
STi
A TD05H 20g will be fine for any 2.0 with spool in the 3750 range and 320whp...
A TD06 20g is as big as I would go for the 2.0 motor as it would put you around 4k spool and can reach 320+ whp with room to grow!
The 20g in any variation loves boost so 22psi is just waking it up. If you have the balls to run 24-25psi you'll be very surprised at what this turbo can produce! I've run this turbo in both these configurations and to be honest it is the only turbo I regret selling...
You choose and be happy cause E85, meth, etc will only net more gains cause a basic bolt on 2.0 will not max out any 20g turbo!
ppayer38 is offline   Reply With Quote
Old 02-12-2013, 11:57 AM   #14
SlverEJ20
Member#: 157158
05 WRX stage 2
If you are wondering about the brand, I hear plenty of members use their turbos and are happy...
SlverEJ20 is offline   Reply With Quote
Old 02-12-2013, 01:52 PM   #15
colt_4590
Member#: 306908
2003 WRX
Ppayer38: so you recommend the td05 20g over the td06 20g for a 2.0 dd. I'm putting in the order today
Old 02-12-2013, 01:53 PM   #16
insaneimpreza
Member#: 83291
1998 RSTi
If you dont plan on just drag racing the car the td05 will respond a bit better on the street vs the td06 version and you wont be giving up a ton of power doing so. I vote that as well if you want a fast street driver. After tuning numbers of cars with VF39's and 52's on them and then doing the 16g's and HTA68's, I still recommend people get the 20g when they ask. It doesn't disappoint!
Old 02-12-2013, 01:55 PM   #17
colt_4590
Member#: 306908
2003 WRX
It also gives me the option of 7 and 8cm turbine housing and a urgraded billet wheel
Old 02-12-2013, 02:14 PM   #18
insaneimpreza
Member#: 83291
1998 RSTi
The 7cm will work fine for what you are doing. I have no first hand experience with a billet wheel in one but typically they will help get you a lil more response as is lightens the rotating assembly!
Old 02-12-2013, 02:16 PM   #19
colt_4590
Member#: 306908
2003 WRX
Awesome thank you I just ordered it. While I have this turbo pulled out should I go ahead and do ewg. Right now I have the stock boost control.
Old 02-12-2013, 02:26 PM   #20
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
I guess I couldn't convince you to buy my 16g 8cm?
Subian is offline   Reply With Quote
Old 02-12-2013, 02:29 PM   #21
CJ12
Member#: 202539
02 WRX MBP 6SPD
96 Accord/84 NH 650SC
This just reminds me of an xtranormal video
CJ12 is offline   Reply With Quote
Old 02-12-2013, 02:46 PM   #22
insaneimpreza
Member#: 83291
1998 RSTi
I made 343 with the internal WG setup on it. I wish I had dyno'd it again with the EWG to see what I gained. Its not hurting anything leaving it IWG tho. I love the sound of EWG setups tho
Here's a speedo/tach vid with the EWG setup on the car -
Old 02-12-2013, 02:59 PM   #23
subaru_gc8
Member#: 29292
2004 WRX wagon
u can try 20g twinscroll setup. that would make ups for the lack of spool
subaru_gc8 is offline   Reply With Quote
Old 02-12-2013, 03:23 PM   #24
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
Well you ordered the turbo what about all the supporting mods.
Old 02-12-2013, 03:26 PM   #25
ppayer38
Member#: 234407
04 Self-tooned
STi
Street drivability+TD05H 20g 8cm=ej205 heaven!
TD06/TD06H 20g 8cm+ej207=race car!
Do not get a 7cm as it is pointless...
