Old 02-11-2013, 11:57 PM   #1
KevsWRX21
Member#: 220326
2002 WRX JDM STi 2.0
Default Please help! Coolant Pressure Leak!!!!
So spent the last few weeks working on my 02 wrx, I swapped a 04 jdm sti motor in her. Everything seems to be fine but one small issue. The small coolant line coming off the left top side of radiator keeps over pressurising and leaking when motor is warmed up....Any ideas why? Thanks. Its a brand new cms aluminum radiator.
KevsWRX21 is offline   Reply With Quote
Old 02-12-2013, 12:00 AM   #2
novacivic
Member#: 117980
2005 sti
wr blue
Because it under pressure like it is supposed to be. It balances the radiator and tank. Put a clamp on it
novacivic is offline   Reply With Quote
Old 02-12-2013, 12:27 AM   #3
KevsWRX21
Member#: 220326
tired clamps then it still finds its way out, are you sure on my old motor never had any pressure in it
Old 02-12-2013, 12:51 AM   #4
moxynoff110
Member#: 346776
Check to make sure your radiator cap releases at the correct pressure. There could be a defect on your new radiator as well.
moxynoff110 is offline   Reply With Quote
