Old 02-12-2013, 12:00 AM   #1
Nicky B.
Member#: 148261
2007 Scoopless&Proud
Default Front brake smoking w/out braking
I was cruising along at highway speed when I noticed a lot of vibration in the steering wheel. When I pulled to the side of the road my front right caliper was smoking like crazy. To see if the caliper was locked up I put the car in neutral but I could still push the car. From my understanding the parking brake only effects the back so I dont think that was the issue. The calipers I'm running were put on by waltz 20k miles ago. Does anyone have any idea as to what might be going on?
Nicky B. is offline   Reply With Quote
Old 02-12-2013, 12:52 AM   #2
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
you need a real mechanic to fix it right for ya...junk calipers installed most likely
dont drive it again until you get it fixed
Old 02-12-2013, 12:56 AM   #3
pho_shizzle
Member#: 181064
00' 2.5RS
BRP
Seized piston or really trashed brake pads, or both. You need to take it apart and see if the slider pins are retracting. Caliper might need a rebuild, or maybe they were just installed wrong. 20k is a long time ago, can you still get them to pay for repairs?
pho_shizzle is offline   Reply With Quote
Old 02-12-2013, 02:26 AM   #4
Nicky B.
Member#: 148261
Says their warranty is a minimum of 12 months or 12k miles, whichever comes first. Still have the receipt but I have a feeling they are going to say no way. This is ridiculous though, my car doesn't even have 80k miles and I'm potentially looking at a 3rd set of calipers
Old 02-12-2013, 03:55 AM   #5
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
12k miles was 8k miles ago.
Counterfit is offline   Reply With Quote
Old 02-12-2013, 09:57 AM   #6
Nicky B.
Member#: 148261
Yes it was
Old 02-13-2013, 12:36 AM   #7
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
There are plenty of Subaru enthusiasts in NWIC. Find someone who knows how to work on brakes and have them show you how to take a look at them. It's most likely a bound up slider pin or two, which can be fixed very easily. I don't see any reason to think you need a new caliper.
(Why were the calipers replaced 20k miles ago? And calipers don't have to be replaced in pairs - you only have one potentially bad caliper.)
Message Board Statistics All times are GMT -4. The time now is 10:08 PM.
