Old 02-12-2013, 12:38 PM   #1
milocas
Member#: 201641
2010 Legacy Gt Prem.
D4S
Default Advice on Clutches for 05 Wrx
Alright I've done research on clutches and what not.. But my current clutch has about 60k on it and want to upgrade it or at-least have one when it does. There's no symptoms of it slipping, Just want to be ready. It currently has a exedy clutch and stock flywheel. I've search on the pros and cons of a light flywheel, but in reality, i rather not deal with noises and retain my stock flywheel and just resurface it. Now, Im currently modded with 16g, sti pinks, TBE, intake, Headers pushing about i wonna say 300 to the wheels, Give or take 50. I daily drive this car, street race here and there, NO Auto-x! But the clamp force for me wont really matter as i can take the beating. Im looking for a clutch that'll last awhile and hold my power.
Currently looking at ACT clutch, Number ACT SB3-XTSS. Is this clutch going to provide me what i am looking for? Thanks.
milocas is offline   Reply With Quote
Old 02-14-2013, 11:02 PM   #2
milocas
Member#: 201641
D4S
Anybody?
Old 02-15-2013, 02:52 AM   #3
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Torque is low enough on the 2.0L that you don't need much. I ran a stock clutch with an 18g @ 20psi on E85 for a long time, but don't street race or do any real straight line power shifting at all. It was definitely putting out more power than any car with pinks can.
With the 5MT as sensitive to shock loads as it is, you want to use a stock clutch as long as you can. pinks on pump gas isn't going to push enough to kill a stock clutch quick. Replacing clutches > replacing transmissions. Stock is best if it works for you... and it should. As a bonus, the Exedy branded version of the stock clutch (KSB03) is <$200.
Concillian is offline   Reply With Quote
Old 02-16-2013, 08:17 PM   #4
Cois32
Member#: 294755
2004 Impreza WRX
WRB vf39'd
OEM Clutch
Cois32 is offline   Reply With Quote
Old 02-16-2013, 10:33 PM   #5
milocas
Member#: 201641
D4S
Any disadvantages to using a OEM grade clutch rather than a upgraded one?
Old 03-03-2013, 07:03 PM   #6
minorc
Member#: 208229
2010 STi
Inability to hold high torque load without slipping.
At a price of more stress on your gears.
Stick with OEM or stage 1
minorc is offline   Reply With Quote
Old 03-04-2013, 02:13 AM   #7
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
OEM will hold anything you're going to do with STi pinks.
An upgraded clutch will grip better, and slip less when you are shifting quick... but that will also shock your transmission more. I personally know someone who killed their 04 tranny with a 16g on pump gas less than a month after he upgraded his clutch. There's a reason people are recommending you stay with OEM. It may wear out sooner than a grippier clutch, but clutches are a lot cheaper to replace than transmissions.
Old 03-05-2013, 09:56 AM   #8
Nat
Member#: 759
2004 WRX
2000 SV650
Just note of caution, I recommend using the OEM Subaru clutch - not the "OEM" Exedy clutch. The Exedy can cause transmission noise on decel that depending on your personality may be OK or drive you crazy. I'm the latter - I deal with it but wish I spent the extra money on the Subaru part.
Nat is offline   Reply With Quote
