Old 02-12-2013, 12:48 PM   #1
vandy2
Member#: 346819
2013 WRX Sedan
Dark Gray Metallic
Default Total Newb: Flash ECU?
I just got my first WRX last Friday. 2013 Sedan. I have the Cobb AP and was wondering if I should flash the ECU to stage 1 for the break-in period. I've already put over 400 miles on it (mixed highway and in-town). After the first 1K, when should I upgrade to the cold air intake? After first oil change (3K)? Thanks, Loving this car!
vandy2 is offline   Reply With Quote
Old 02-12-2013, 01:06 PM   #2
luan87us
Member#: 335013
2013 Premium WRX 5dr
It shouldn't matter really. The sooner you flash the stage 1 ots map the sooner your car run on a better tune.
luan87us is offline   Reply With Quote
Old 02-12-2013, 01:07 PM   #3
Heedlessone
Member#: 254130
1993 LS1 RX7
Just do it now, it won't harm the car.
Heedlessone is offline   Reply With Quote
Old 02-12-2013, 01:16 PM   #4
SpamBot
Member#: 287534
Better hope not, because your warranty coverage on your powertrain goes bye-bye.
SpamBot is offline   Reply With Quote
Old 02-12-2013, 01:20 PM   #5
nmlittlebigman
Member#: 321409
2003 Big Effing Van
7.3L powerstroke diesel
Meh, I'd drive it stock for a bit. That way when you do go stage 1 you'll feel like you have made some gains. As for the CAI... at this stage it would just be for noise. The stock airbox is pretty good. Make sure to read before you mod:
http://forums.nasioc.com/forums/showthread.php?t=533787
nmlittlebigman is offline   Reply With Quote
Old 02-12-2013, 01:26 PM   #6
SWP n Gold
Member#: 110783
2010 WRX
Satin White Pearl
As long as you realize that flashing your car can result in a warranty claim denial if something goes wrong with your engine, then you can flash whenever you want. I would wait until the break-in period is over, change the oil and flash to stage 1, but that's just me. If you want more power later on, I would skip the intake for now and do a downpipe and flash to stage 2.
SWP n Gold is offline   Reply With Quote
Old 02-12-2013, 01:52 PM   #7
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
You have lots of learning to do. Start by reading http://forums.nasioc.com/forums/showthread.php?t=533787
You car COMES with nicely designed cold air intake so don't think that by switching to aftermarket that you are "upgrading" as by doing so you will need to get a custom tune for it. Custom tunes after labor and materials can be from $200 to $800. All that money for 8 HP? You can get that with no tune by slapping on a $100 lightweight pulley. Research twice, buy once.
Old 02-12-2013, 02:08 PM   #8
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
^ this
There is absolutely no reason to wait unless you want to give it some time to make sure there aren't any problems before tossing your powertrain warranty aside. If you do want to give it some time to make sure there aren't any problems, then the amount of time you want to wait is completely up to you.
Personally, I felt like I was killing my engine every time it switched from CL to OL on the stock tune, so I flashed to stage 1 as soon as I possibly could. I think the car had something like 60 miles on it at the time...wish I could have done it sooner.
Old 02-12-2013, 02:16 PM   #9
vandy2
Member#: 346819
2013 WRX Sedan
Dark Gray Metallic
Yeah, I do for sure. I got the CIA and the AP in a package deal for a good price, that's why I was asking. I have been reading through your great FAQs, but I don't know where to start. Maybe, I will just do the flash and enjoy the car for a bit while doing more research...Thanks!
Old 02-12-2013, 02:53 PM   #10
Member#: 51961
2005 STi
2012 WRX
What intake is it? Make sure that if you're using the stock intake you use a tune designed for the stock intake, and if you're using the CAI you use a tune designed for that CAI.
Old 02-12-2013, 02:59 PM   #11
vandy2
Member#: 346819
2013 WRX Sedan
Dark Gray Metallic
Cobb SF intake + sf airbox. Yeah, I'll want the map that doesn't include the SF until I actually put on the CAI.
Old 02-12-2013, 04:34 PM   #12
ABeastinWRX
Member#: 239469
2004 WRX
Listen to this guy.
ABeastinWRX is offline   Reply With Quote
Old 02-13-2013, 01:25 AM   #13
jebjkey
Member#: 73884
Chapter/Region: HIIC
16 HyperBlue STi
16 Crystal White STI
Cobb SF (even with the SF airbox) is not a CAI, it is a SRI. The SF airbox helps to keep IAT in check, but you will still get lower IAT's with the stock airbox since it is already a CAI.
Run the Cobb SF intake if you like, there is nothing wrong with it and Cobb has a OTS map for it. Do not be surprised if the only difference is the intake noise and higher IAT.
I would run stage 1 with the stock airbox for a little bit, get some good datalogs (with IAT) to get your baseline. Then install the SF intake/airbox, drive around some and repeat the same datalogs. You can do a comparison then and see how the car reacts to the aftermarket intake. Based on what the datalogs tell you and how you feel about the two intakes, make a choice and be happy.
jebjkey is offline   Reply With Quote
Old 02-13-2013, 02:02 AM   #14
jhmr
Member#: 313217
2013 STi Sedan Stg 1
Plasma Blue Pearl
Research on how to use the AP to data log before you install the CAI. There have been certain instances where people with 08+ WRX's have experienced boost creep while using a aftermarket CAI. While you may not be affected by this problem, you won't know unless you're able to keep track of your boost.
jhmr is offline   Reply With Quote
Old 05-15-2013, 12:16 AM   #15
Dblockdc
Member#: 345856
2013 Impreza sti
What if you reflash your ecu to stock settings will the people from the dealer realize that an ap was installed and how?
Dblockdc is offline   Reply With Quote
Old 05-15-2013, 01:22 AM   #16
hendo741
Member#: 40834
2009 DGM STi E85+
08/13 WRX,03 EVO,12 GT500
The ECU has a check sum counter that advances when flashed. This will most likely not be checked however, but that possibility is always there.
hendo741 is offline   Reply With Quote
Old 05-15-2013, 07:36 AM   #17
Dblockdc
Member#: 345856
2013 Impreza sti
Ok thanks again.
