#1 |
Member#: 204014
South East
Vehicle:02 Bugeye Rotated, HTA3582, E85 |
I'll use this thread to log my progress.
I sold my STi last year and bought a bugeye project that will end up being a fun street/weekend car. The car had a broken timing gear so I had planned for the worse. I already had everything I needed for a 2.5L build, including block halves, heads etc. etc., so I was planning to have the car running pretty quickly.... Unfortunately I ran across a good deal on an 07 STi driveline, which I bought. That purchase was a bit of a setback but in the end the car will be a lot of fun. Summary: Build, 2.5L Built short block, Ported heads, Kelford cams, Perrin Rotated kit, Perrin big tube ELH, GT35R (for now), SD tuned, running E85. Driveline/Suspension, Full 07 STI driveline, RCE yellow springs, all new bushings (Whiteline and Tic), whiteline 24mm sway bars, kartboy endlinks and short shifter etc. etc. Brakes, Brembo's painted black with yellow stickers, racebrake 2 piece front rotors, DBA4000 rear rotors Interior, 07 STi seats and door cards, gray carpet, all weather floor mats Exterior, I'll probably end up wrapping the car blue or white, Wing-less and scoop-less Everything except what is in red I already have. Bolt-ons: Garrett HTA3582R with .82 ar hotside Perrin Rotated kit Perrin Big tube ELH Heat Wrapped: Header, UP, DP and turbo blanket Tial 44mm EWG Perrin FMIC KSTech 83mm Cold air intake Topfeed TGV Deletes Boomba or Perrin topfeed fuel rails Five0 1600cc topfeed injectors Walbro 400LPH fuel pump Hallman MBC DIY AOS Tial BOV Reverse STi Intake AEM Wideband AEM oil pressure gauge AEM Boost gauge Engine EJ257 case halves (09 STi 18k miles) OEM Nitrided crank BC I-Beams Rods Wiseco 99.50 pistons, SwainTech skirt coating Ported heads, DIY Kelford 199-E Cams, non-AVCS Manley Valve Springs and retainers ARP headstuds Balanced rotating assembly (front pulley - pressure plate) Blue printing Full Timing belt kit Water pump 10mm oil pump New OEM Oil cooler King bears Full factory gasket set Killer B oil pick-up and windage tray Driveline and Suspension: ACT HDSS Clutch kits ACT lightened flywheel 07 STi 6speed Kartboy shifter Bushing Combo Kartboy short shifter Whiteline positive shift bushings New finder liners Whiteline adjustable sway bars 24mm front and 24mm rear Kartboy front and rear endlinks Cusco front and rear strut bars Cusco H brace, lower control arm brace 07 STi Struts RCE yellow lowering springs Group N front Strut tops/top hats Front and rear Brembo brakes Racebrake front 2 piece slotted rotors DBA 4000 slotted Rear rotors PFC-Z front brake pads StopTech rear brake pads Goodridge brake lines Beatruch motor mounts Group N pitch stop mount Cusco trans mount Tic diff mount bushings Whiteline steering Rack bushing kit Whiteline lower control arm bushing-front Tic lower control arm bushing-rear Whiteline control arm bushings Whiteline trailing arm bushing-front Tic trailing arm bushing-rear Whiteline diff front support lock bushing As purchased ![]() ![]() ![]()
#2 |
Member#: 204014
South East
#3 |
Member#: 204014
South East
#4 |
Member#: 79983
Vehicle:2005 STI Aspen White |
I like the direction this thead is going.
#5 |
Member#: 204014
South East
Thanks. I have the rear end, trans and part of the front end back in the car, post pics later
#6 |
Member#: 204014
South East
#7 |
Member#: 204014
South East
#8 |
Member#: 204014
South East
#9 |
Member#: 204014
South East
#10 |
Member#: 204014
South East
#11 |
Member#: 204014
South East
#12 |
Member#: 204014
South East
#13 |
Member#: 125927
Vehicle:2000 2.5rs Brp |
looking good
#14 |
Member#: 204014
South East
#15 |
Member#: 204014
South East
#16 |
Member#: 285270
NESIC
Vehicle:03 WRX PSM |
Well this looks like a ton of fun! Looking forward to further progress! :-)
#17 |
Member#: 149130
Vehicle:2002 WRB WRX VF39 Brembos etc |
Looks like a fun project! My car is slowly moving this same direction, wrb bugeye with morettes, brembos, alot of similair suspension bits etc. Once I have another DD it may finally get the built 2.5 and big turbo, and 6 speed, but the vf39 setup works for now.
#18 |
Member#: 204014
South East
Thanks guys. I'm really starting to have fun with it.
#19 |
Member#: 204014
South East
#20 |
Member#: 204014
South East
#21 |
Member#: 180748
VIC
Vehicle:2005 STi CGM |
Awesome build!!!
#22 |
Member#: 204014
South East
#23 |
Member#: 216597
Vehicle:2003 WRX PSM |
This is looking like an awesome build, please keep it coming as I am living vicariously through this
If only I could afford to do a build like this at this time... |
#24 |
Member#: 204014
South East
#25 |
Member#: 243697
Vehicle:02 Stg2+ WRX Top Scoob 031 |
A lot of really fine work there. It's good to see people save Bugeyes. I've been on a similar path.. picked up a junked Bugeye about two and a half years ago and have been restoring it to glory.
I def wish I had your built engine setup! |
