Old 02-12-2013, 02:28 PM   #1
Wrxhatch08
Member#: 345153
2008 Wrx
Dark metallic gray
Default A/C idler pulley/adjustment assembly 08 wrx
I noticed while doing a timing belt install the whole assembly was missing. The previous owner somehow got some tiny ass belt on there. I had to cut it off.
Was wondering if anyone knows the part
number/s for it. I need the track, pulley, adjuster rod and a new belt considering no part store can find it in their system. Must be a dealer item.
Wrxhatch08 is offline   Reply With Quote
Old 02-12-2013, 03:16 PM   #2
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Goto a dealer, will be the easiest way. Or opposed forces website. (Don't know the link, sorry)
Old 02-13-2013, 01:17 PM   #3
rallymobile
Member#: 82531
08+ uses a stretch belt and deleted the idler pulley. Now you have to stretch the belt on to install it and Gates has a tool to do it. Check out the links below and you'll see what I mean.
http://www.rallysportdirect.com/Gate...-Subaru-Models
http://www.rallysportdirect.com/Gate...8-2011-WRX-STI
rallymobile is offline   Reply With Quote
Old 02-14-2013, 08:36 AM   #4
Wrxhatch08
Member#: 345153
2008 Wrx
Dark metallic gray
Thanks man. Saves me the frustration. Only reason I thought that it had it is the mounting holes are there for the adjuster.
Old 02-14-2013, 11:53 PM   #5
dead_eye
Member#: 308265
2008 WRX
I just did belts and was confused at first about the stretch belt.
In another thread a guy stated the block was the same and therefore had the holes for the old tensioner. Said a 2005 Forester belt and tensioner would fit if you didn't go the stretch belt route.
dead_eye is offline   Reply With Quote
