Closed Thread
Old 02-12-2013, 04:40 PM   #1
CarverSnell
Member#: 256218
2004 Impreza WRX
FP Black, 380whp
Default Drag Dr31 17x9 +38 offset 5x100 question
Drag Dr31 17x9 +38 offset 5x100 question: What do I need to make sure they don't rub on my '04 WRX sedan? What tire size do you recommend? I'll be lowered on H&R sport springs (-1.4 front, -1.3 rear)
CarverSnell is offline
Old 02-12-2013, 04:45 PM   #2
imprezafreak3
Member#: 184136
2013 WRX
PBP
why are you in the newbie section??? do some research and stop expecting to be hand fed the info..
imprezafreak3 is offline
Old 02-12-2013, 04:52 PM   #3
ClemRoo
Member#: 343934
2011 WRX
Charcoal Gray
i had these same wheels on my 2011 sedan and i would still rub occasionally, they were on my buddies 04 WRX and they rubbed pretty bad taking chunks at the tire. tire was 255/40/17 im almost positive your going to have to roll your fenders.
ClemRoo is offline
Old 02-12-2013, 04:55 PM   #4
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
1050 Triumph Speed Triple
To be fair, he is doing research over in the tire/wheel fitment thread. He's just looking for a quick answer from the Newbie section because we're not supposed to flame or make fun of him.
Loyale93 is offline
Old 02-12-2013, 04:59 PM   #5
CarverSnell
Member#: 256218
2004 Impreza WRX
FP Black, 380whp
Quit acting like I haven't searched. I've been searching tons of threads since earlier this week. Just trying to triple check my research.
Oh wow. So maybe I'll have to go 235 or 245s and rolled fenders.
Old 02-12-2013, 05:05 PM   #6
ClemRoo
Member#: 343934
2011 WRX
Charcoal Gray
yea especially since your lower my budfie wasnt he was at stock height and rubbing the rear was rubbing more than the front
ClemRoo is offline
Old 02-12-2013, 05:06 PM   #7
SlverEJ20
Member#: 157158
05 WRX stage 2
http://forums.nasioc.com/forums/show....php?t=1588960
http://forums.nasioc.com/forums/show....php?t=1850467
Research, research, research and then buy. If you run 255's on them you will need to roll the fenders, add camber bolts and get an alignment.
I've been running these wheels with 255's for over 6 months now on stock STI springs and just a roll in the rear (They arent rolled flat) and I rub from time to time, with no one else in the car and all the time over dips and during turns with a full car load.
in short roll fenders flat, get an alignment with negative camber.
I'm sure I could get these wheels and tires to fit with minimum rubbing, I just havent had the funds to do so.
My fronts have never rubbed
SlverEJ20 is offline
Old 02-12-2013, 05:45 PM   #8
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
FYI if you posted this elsewhere, and then made a thread, that is CROSS POSTING and against forum rules.
Edit: Oh look, you did. http://forums.nasioc.com/forums/show...5#post39127535
HinshawWRX is offline
Closed Thread
