Closed Thread
Old 04-28-2013, 03:12 AM   #1
lavid2002
Member#: 226864
Default Exhaust wrap under heat shields? Overkill?
Hey everyone.
Going with OEM headers, STi up pipe, and a catted downpipe.
Here's the plan
-Cut the OEM heat shields off the STi up pipe + wrap it
-Wrap the OEM manifold and put the heat shields back on
-Turbo blanket
-Wrap most of the down pipe
Am I going crazy with this heat insulation? Reasonable?
lavid2002 is offline
Old 04-28-2013, 03:42 AM   #2
p951951951t
Member#: 276541
1972 Alfa Romeo GTV
Alfa Rosso
Not at all. In fact wrap really does little in the way of thermal insulation, but it is better than nothing.
If you want the best thermal insulation you need to cut off the heat shields and wrap the pipes in 3/4 thick high temp insulation then put the shields back on to protect from fluids.
I got my shields zinc plated to freshen them up and protect from corrosion while I was at it.
p951951951t is offline
Old 04-28-2013, 04:44 AM   #3
Sn0wKing
Member#: 341560
2011 STi
You know what's overkill?! Making two of the exact same threads, asking the exact same question less than 20 minutes apart.
http://forums.nasioc.com/forums/show....php?t=2498881
Sn0wKing is offline
Closed Thread
