Old 02-12-2013, 09:17 PM   #1
Boxerscoopy90
Member#: 309974
Default Ej16 :(
Hey guys i have 1.6 07 impreza which never came to us but u cant even imagine how slow it is . I've searched for power mods and found out that swapping the block would be a worthy mod to start with. The ej16 is sohc so my question is would i be able to put a block from a dohc 2.0 engine in mine ? And would i need to change anything else like the head or head gasket ?
Boxerscoopy90 is offline   Reply With Quote
Old 02-12-2013, 09:21 PM   #2
JordanM9
Member#: 273214
2013 WRX Limited
CBP
Although I'm sure its doable, the resulting power upgrade can't justify any cost to do this. I would sell the car and looked for something that will meet your goal from the start.
JordanM9 is offline   Reply With Quote
Old 02-12-2013, 09:41 PM   #3
ClemRoo
Member#: 343934
2011 WRX
Charcoal Gray
new block-new heads
ClemRoo is offline   Reply With Quote
Old 02-12-2013, 10:48 PM   #4
scoobynoobEMT
Member#: 199206
2002 WRX wagon EJ257
I have a EJ20 Bare longblock that only needs new valves that I can sell ya..
scoobynoobEMT is offline   Reply With Quote
Old 02-12-2013, 11:05 PM   #5
WoodsWagon
Member#: 180769
lots of junkers
I assume you're planning to swap in a non-turbo Ej20, right? That is not the ej20 that most USDM subaru owners are familiar with so most wont be able to give you good advice.
Subaru is usually pretty good about engine interchangeability in the same year range of cars. You could potentially swap in the whole engine instead of just the block. Worse case you transfer the intake manifold harness to match it to your firewall harness.
WoodsWagon is offline   Reply With Quote
