Old 02-13-2013, 07:58 AM   #1
solort
Member#: 261484
Default Creaking when braking or accelerating
I recently had some transfer box bushings and pilot bearings replaced. Now, I get a creaking noise up front (sounds like center front or maybe rt front) when I put on brakes, and then when I accelerate. It "feels" like something may be shifting fore to aft and vice versa. I had it on a lift and cannot find anything loose. Any recommendations on what to look for? Thx for any help!
solort is offline   Reply With Quote
Old 02-13-2013, 11:24 AM   #2
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
There's only one pilot bearing that I know of and its in the flywheel.. if you had the flywheel out any number of things could be clunking.. axles, hubs, endlinks, brake calipers..
Start putting wrenches to bolts and hope its not inside somewhere
Old 02-14-2013, 04:55 PM   #3
solort
Member#: 261484
Now that it is dry, I can get the noise more consistently. a creaking noise, not during bumps, just like the momentum of the engine. I tried tightening bolts. Swaybar bushings look good (70K miles on 07 2.5i Impreza 5 speed). Maybe it could be the car shifting on the motor mounts? It seems like it should be easy to find, but no luck yet. Suggestions? Thx
Old 02-14-2013, 05:19 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
check all of the engine/trans mount bolts/nuts
also...check the rear lca bushings for leaks....they are liquid filled on some models and if they are leaking they can do that
Old 02-15-2013, 06:31 AM   #5
solort
Member#: 261484
Thx. May start with replacing engine mounts. Is there a good how-to with pics for the basement jack stand job?
Old 02-15-2013, 05:49 PM   #6
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Is your pitch stop/dog bone worn out (upper motor mount) it controls the fore/aft movement of the driveline along with the trans mount..
Old 02-19-2013, 07:43 AM   #7
solort
Member#: 261484
Found it finally! Pitch stop was not tight enough against firewall. Now all is quiet. Thx to everyone for all the suggestions!
Old 02-19-2013, 01:52 PM   #8
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Bam!...
