Welcome to the North American Subaru Impreza Owners Club Monday March 2, 2015
Old 04-25-2013, 04:59 PM   #51
DP2
Member#: 330532
2011 WRX Hatch LTD
DGM - Stage 2
Hairspray on the inside of the hose where it connects to the Throttle Body. It allows the hose to easily slide on and fully seat to the TB. Then you tighten the clamp at the TB.
I do this connection as the 1st step, so there's room to tug on the hose to ensure it doesn't pull loose from the TB. This connection is the one that is most likely to come loose, so this is where I concentrate.
The hairspray, once dry, acts as a mild bonding agent between the hose and TB. I then proceed to connect the same hose to the IC output side, install the PW, and finally connect turbo to IC hose and clamps. Some people use the hairsprat on all the hose connections.
Finally, double-check that all clamps are tight, close hood, start car, and enjoy.
DP2 is offline   Reply With Quote
Old 04-25-2013, 05:03 PM   #52
Syndr78
Member#: 336966
2013 WRX
Satin White Pearl
So far I have been lucky, as my PW tmic has not had any loose hose issues since installing about 3 months ago. BTW--just installed the GS EBCS and flashed TP stage 3 this afternoon...
Syndr78 is offline   Reply With Quote
Old 04-29-2013, 12:38 PM   #53
Subie_do_me
Member#: 334167
How is this piece? I have it in a box ready to go into my car shortly.
Subie_do_me is offline   Reply With Quote
Old 04-29-2013, 01:04 PM   #54
Jdub.csu
Member#: 283784
2013 EVO X GSR
Have fun! I loved that before getting a custom tune
Jdub.csu is offline   Reply With Quote
Old 04-29-2013, 03:48 PM   #55
SenorDucK
Member#: 327511
13' WRX 6 Speed
11sec VF52 EL-EWG-E85
it's very nice.
SenorDucK is offline   Reply With Quote
Old 04-29-2013, 05:15 PM   #56
JAMM0N
Member#: 318736
2013 WRX Hatch
CBS (BLCK)
Buys it and asks us if its nice? Derp
JAMM0N is online now   Reply With Quote
Old 04-29-2013, 06:32 PM   #57
D S WRX
Member#: 348060
2011 Sedan
Appreciate the write up, but mine actually came with 2 sets of instructions...maybe that's why other people didn't get theirs, lol
D S WRX is offline   Reply With Quote
Old 04-29-2013, 07:17 PM   #58
JAMM0N
Member#: 318736
2013 WRX Hatch
CBS (BLCK)
It is really easy to install anyways but the hood scoop could be the tough part.
I am fabricating the arm extension from a piece of metal and the gasket is on order feom RSD. 90 dollars for a atupid gasket for next day are no thanks abs not worth the 70 dollars which is ridicolous.
Old 05-14-2013, 05:17 PM   #59
DisrupTer911
Member#: 352071
2013 Impreza WRX
Dark Grey Pearl
Does this require any additional ecu retuning?
DisrupTer911 is offline   Reply With Quote
Old 05-14-2013, 06:57 PM   #60
JAMM0N
Member#: 318736
2013 WRX Hatch
CBS (BLCK)
No it does not. Just more airflow and you build bigger boost. You can ask your tuner to do that via email than going in for a tune just for a change in tmic.
Great tmic and very tough to get now cause pw is always on backorder
Old 05-14-2013, 08:23 PM   #61
DisrupTer911
Member#: 352071
2013 Impreza WRX
Dark Grey Pearl
cool thanks
Old 05-14-2013, 10:53 PM   #62
BigRob74
Member#: 305107
2012 wrx
360/386 E85
ok, i am going to be using my forge bpv on this and i have the diamond shaped one. is there any issues with leaking using the oem bpv or the forge?
BigRob74 is offline   Reply With Quote
Old 05-14-2013, 11:15 PM   #63
SenorDucK
Member#: 327511
13' WRX 6 Speed
I've used both and they were fine. the forge seals just like the oem.
Old 05-14-2013, 11:35 PM   #64
BigRob74
Member#: 305107
2012 wrx
360/386 E85
thanks for the info!
Old 05-14-2013, 11:36 PM   #65
RSD Performance
Member#: 346602
2013 Subaru WRX
www.rsdperformanceinc.com
Installed the PW on my '13 a couple weeks ago. Install was straight forward. No tuning was required.
James
RSD
RSD Performance is offline   Reply With Quote
Old 06-21-2013, 02:10 PM   #66
WickedRX
Member#: 298302
2013 WRX 5 Door
ISM
Does anyone has a list of the TBolt clamps I should buy, I have the TMIC on order and should be here Monday.
WickedRX is offline   Reply With Quote
Old 06-21-2013, 08:25 PM   #67
JAMM0N
Member#: 318736
2013 WRX Hatch
CBS (BLCK)
just buy a bunch and return the ones you dont use?
i'm surprised they have some in stock from RSD cause i've been waiting 2 months for a flange i'm a cheap so i bought it used didnt come with the flange or the hood splitter. anyways i asked for a refund and had someone else mock me up one and bought the splitter off someone else.
PW get your stuff together.
cant wait for install!
Old 06-22-2013, 10:50 AM   #68
BigRob74
Member#: 305107
2012 wrx
360/386 E85
you dont need them, my pw came with some decent clamps
Old 06-25-2013, 11:49 PM   #69
jewbaru42
Member#: 265098
2003 wrx
silver w/ blk enkei rims
This was EXTREMELY helpful. However mine was a knock off from this design and needed some minor fabrication thanks to a bag of assorted nuts, bolts, washers and some j-b weld but it was helpful hahaha
jewbaru42 is offline   Reply With Quote
Old 06-26-2013, 07:05 PM   #70
CO11WRX
Member#: 304018
2011 WRX Sedan
TP Stage 1
Thanks for posting this! I plan on using this guide for my install. I am still waiting on my order to come through (the estimated shipping date is the 28th, but I'm not holding my breath as it's already changed twice since I placed my order on the 14th). I can't wait to get this sucker installed
CO11WRX is offline   Reply With Quote
Old 06-26-2013, 09:01 PM   #71
Jdub.csu
Member#: 283784
2013 EVO X GSR
No problem you are welcome
Old 06-28-2013, 11:21 PM   #72
steve2788
Member#: 346875
2013 wrx sedan
SWP. TP stage 3
Yea I was told mine was going to ship today too, I really hope it does because I have been waiting since the 15th for it
steve2788 is offline   Reply With Quote
Old 06-29-2013, 11:19 PM   #73
CO11WRX
Member#: 304018
2011 WRX Sedan
TP Stage 1
I actually received mine on Friday. Overall the build quality seems to be fantastic. I plan on installing it at some point tomorrow.
Edit: you know, I am going over the instructions and I just cannot figure out where to use these fasteners:
6 X M6 flange nuts (what are these used for? )
2 X M6 10mm allen key bolts + M6 flat washers (are these used to secure the bypass valve?)
Old 07-04-2013, 11:03 PM   #74
CO11WRX
Member#: 304018
2011 WRX Sedan
TP Stage 1
I finally found some time to do my PW install. I have the TMIC installed but still have to finish the hood scoop. I don't know why, but this install was a major PITA for me. My biggest challenge was getting the transmission bell housing bolt off. I managed to break a socket wrench, but did eventually manage to get it off. I would definitely suggest NOT using a socket wrench to get this bolt loose. Maybe I should have used a breaker bar. Also, I had to re-route my BPV hose as it was not long enough after I got everything hooked up. On to the hood scoop! I will post some pics when I'm done.
Old 07-05-2013, 04:52 AM   #75
JAMM0N
Member#: 318736
2013 WRX Hatch
CBS (BLCK)
Mine was a little difficult on the right side. That hose is all warped ill post a pic when i can.
I mocked up the extemsion bracket FTW everything else was easy. Mske sure those clamps are tight!
