Welcome to the North American Subaru Impreza Owners Club Wednesday April 1, 2015
Old 09-18-2002, 11:40 PM   #1
sweeper
Member#: 13547
2002 wrx
white
Default hks ca/ti catback
good exh. just one problem that is very annoying(especially after hard cornering and with a/c on). i get a rattle from the muffler hanger hitting the swaybar. thought those kartboys would fix it but it just made the rattling faster. anyone had the same problem?
sweeper is offline   Reply With Quote
Old 09-19-2002, 10:53 AM   #2
tokigiracing
Vendor
Vendor Sales Rating: (0)
Member#: 15567
I don't think any of my hangers even come close to hitting the sway bar...I did have a problem with the rear flange banging into the diff protector, but I fixed that. Just be sure to keep an eye on the flex joint on that exhaust - mine blew itself out within 6 months of use, and HKS refuses to provide product support unless you are an authorized dealer through them.
tokigiracing is offline   Reply With Quote
Old 09-19-2002, 03:40 PM   #3
sweeper
Member#: 13547
2002 wrx
white
hummm... my flex joint seem to be neutrally aligned, plus, putting in the downpipe had only moved the flex joint about half an inch. i don't know... i'm hoping it'd fix the problem when i get aftermarket swaybars and hangers would solve this problem.
Old 09-19-2002, 03:47 PM   #4
SonicYellowWRX
Guest
Member#: 23351
Pika Chu!
TEAM DARRIIFFFTAA
yes i hear this happening with many exhaust manufacturers...
its probably the 2nd hangar location on the axel back section hitting. Its not the sway bar, i forget what it was though. Most companies dont know how to properly mount the hangar to prevent that.
all i know is that HKS's quality has gone to hell with these products for the WRX. Being some of the first, if not the first, to have these products out for the WRX... its not a big surprise that there are some problems. However, if you write a proper letter to them, anything can happen. But before doing that, I suggest that you just call them and say, "my exhaust is rattling"
Its funny... I go out and make my own exhaust with minimal welding experience and its perfect... no contact with anything, etc. however, big name companies keep screwing it up.
SonicYellowWRX is offline   Reply With Quote
Old 09-19-2002, 09:57 PM   #5
sweeper
Member#: 13547
2002 wrx
white
Default sonic
oh yeah, u know how to make ur own exhaust? i want to make one too. what material do u use? i'm thinking about doing that before considering hks. i'd sell the hks, get a borla racing titanium muffler and do my own piping. maybe u can help to do it?
Old 09-21-2002, 05:58 PM   #6
res23of
Member Sales Rating: (-1)
Member#: 24196
2003 wrx
blue
Default same problem
i just got a car\titanium exhaust on yesterday but my problem is the resinator hitting the floor board under my seat any thoughts on how to fix
res23of is offline   Reply With Quote
Old 09-21-2002, 10:37 PM   #7
SonicYellowWRX
Guest
Member#: 23351
Pika Chu!
TEAM DARRIIFFFTAA
Default Re: sonic
well i make my exhaust by going to a friends muffler shop and using their stuff. you can go to any muffler shop, you just need some know how.
i recommend getting subaru spec hangars (they are HUGE!!) by special order or something from the muffler shop. Most stock aluminized piping, but you can special order stainless steel parts if you want.
I just copied the factory hangar positions... however i believe that by placing the inner hangar (on the axel back) on the opposite side and pointing towards the left would further reduce chances of hitting. However, mine probably only hits when i go over a big bump or something. takes a lil work, but its worth the time.
OR just hack your stock muffler off and put your choice of muffler on. <--- Easiest method.
Old 09-24-2002, 08:10 PM   #8
dgp
Member#: 15593
My biggest peice of advice is to use different bolts. With the flex joint, you don't need the spring bolts b/c they were for flexibility. I had serious rattles and took it to a muffler shop. They gave me some new bolts and tightened it down for me. ALL BETTER!!!
dgp is offline   Reply With Quote
Old 09-24-2002, 11:21 PM   #9
sweeper
Member#: 13547
2002 wrx
white
thanks for the advise!
Old 10-02-2002, 09:24 PM   #10
Choku Dori
Member#: 11397
2002 ボロ
青空
Does the regular stainless steel model HKS Hiper have the same rattle issues? Just curious since I'm in the market for one...
Choku Dori is offline   Reply With Quote
Old 10-05-2002, 08:42 PM   #11
RuCKuS
Member#: 7260
bann ning teh
jamaican bobsled team...
i have one custom installed on my car and i love it...i love how it sounds...it's a little loud but i still love it...it has a nice deep tone to it unlike the exhausts on civics, integras, etc...
jeremy...
RuCKuS is offline   Reply With Quote
Old 10-06-2002, 02:08 PM   #12
monkeytronZ
Member Sales Rating: (9)
Member#: 7255
ive got the regular hiper, and its rattled once when parked on a steep hill... and i also get the nice thump, too. usually at cruise speed, spool up a little bit -let of the throttle quick and "THUMP!" heh.. we'll see if new hangers fix that..
monkeytronZ is offline   Reply With Quote
Old 10-07-2002, 11:52 PM   #13
Choku Dori
Member#: 11397
2002 ボロ
青空
Thanks monkeytronZ! Let us kno how the hangers work out!
Old 10-11-2002, 08:02 AM   #14
Ferg
Gung-ho Iguana
Member#: 14145
'02 WRX
'10 4Runner
I've got the ca/ti HKS with Vishnu hangers and I've had no rattling issues so far. Nice exhaust, just a little on the big side. Not at all what I would call subtle in appearence. Sounds wonderful.
Ferg
Ferg is offline   Reply With Quote
Old 10-19-2002, 12:41 AM   #15
Undadog
Member#: 20575
I've installed two catback exhausts on two separate cars. One was rattling from the hanger and the other had a small leak in the piping. Both times I ended up buying universals and having them intalled in a muffler shop and they turned out great. If you don't want any rattling or clearance issues I suggest that you just take it to a shop and get a custom job. I'm going to take that route when I get mine. No more catbacks for me!
Undadog is offline   Reply With Quote
Old 11-09-2002, 09:16 AM   #16
civ11c
Member#: 22011
WR Blue
I've been looking for sound clips of exhausts, especially the HKS Hiper cat backs but am not having any luck. Anyone got a sound clip of this exhaust?
civ11c is offline   Reply With Quote
Old 11-14-2002, 12:02 AM   #17
sweeper
Member#: 13547
2002 wrx
white
Old 12-13-2002, 03:14 PM   #18
PRGWRX
Member#: 22498
BLUE
i finally got my HKS ca/ti exhaust....sounds, looks, and performs great//the rattle was worring me//just have to keep a check on it//
frederick
PRGWRX is offline   Reply With Quote
Old 08-21-2003, 09:25 PM   #19
WRX2fast04
Member#: 41897
Default there was rattling on swaybar
I have the regular hyper hi power and it was rattling on my swaybar, by best friend who helped my put oon the exhaust put a small rubber heating pipe, that he cut and put on the swaybar so it wouldnt rattle, not it doesnt rattle!!
WRX2fast04 is offline   Reply With Quote
Old 08-22-2003, 12:42 AM   #20
jandc
Member#: 28149
2003 WRX
Thumbs down
I had hi-power for my 2003 wrx. I had all the problem from whoever posted above, and even worse.
I just had a big hole on the first section of the cat back.
It happenned when I was sitting on traffic, I didn't hit anything, but the welding point of the first hanger fell off from the pipe.
Now I had a big hole on the pipe, and need to order another cat back. I would never get HKS product for my wrx, they are suck. They don't know how to weld.
I just ordered A'pexi GT spec, it should be here next week. I will take some photo from that crab (HKS HI-POWER), and post them.
jandc is offline   Reply With Quote
Old 08-22-2003, 08:22 AM   #21
au112
Member#: 4412
MY01 Impreza 2.5RS
BRP
Anyone have this problem on his/her 2.5RS?
Need quick answer because I am about to get one.
Andy
au112 is offline   Reply With Quote
Old 08-27-2003, 04:13 AM   #22
Blu25RS02
Member Sales Rating: (4)
Member#: 22750
2000 LIC'd 2.5RS
BRP, Ver. 7 STi'd
Yeah, actually. My exhaust, or at least i think it is my exhaust, is rattling like hell or something. When i let off the gas, the regular sound of the exhaust starts, then a loud resonance that fades in and out as the RPMs get lower. I think i might have a leak somewhere, or my muffler is dead, ive got the Stromung Dual Tip, custom 2.5" midpipe from a local exhaust shop that really knows what they are doing, and the Borla Header, which i suspect might be the prob, ive heard of them cracking and that the build quality is not good. Also, when I first take off from a stop sign or any stop, there are some serious rattles from the back left of the car. At first i thought it was my strut assembly as i had just put some Ground-Controls on some KYB GR-2s but i checked everything and it was all still bolted up tight with the springs held perfectly in place. Any ideas? i think the rattle only happens right after i first start moving, but then again my exhaust is loud so i might not be able to hear it anymore.
Patrick
Blu25RS02 is offline   Reply With Quote
Old 08-31-2003, 10:09 PM   #23
2K4 STI
Member Sales Rating: (49)
Member#: 36367
87 Old Skool RX
just installed my hks carbon titanium cat back on my 04 wrx with stock hangers
no rubbing
great sound
great power gains
scott
2K4 STI is offline   Reply With Quote
Old 09-05-2003, 03:42 AM   #24
Rice Boi
Member Sales Rating: (11)
Member#: 25811
2002 WRX (6spd)
2010 TDI CupEdition (DSG)
I've had my on my car for almost 6 months now. It has been fine since the day I installed it. Have you guys try re-positioning the hanger that wraps around the muffeler it self? Maybe that could be a factor. Also did you guys make sure that you didn't put it on facing the wrong direction?
Rice Boi is offline   Reply With Quote
Old 09-05-2003, 06:34 PM   #25
SjpWrx
Member Sales Rating: (6)
Member#: 22554
2007 Corolla no PW!
WHITE miss my WRX :(
Ive had mine for almost a year now and its been through rain, snow, salty slushy snow and nothing as of yet and its still nice and shiny. oh and its sounds really good i highly recommend it.
steve
SjpWrx is offline   Reply With Quote
CA HKS carbon TI catback!!! only 8k on it jdmSpecC760 Engine/Power/Exhaust 0 10-22-2007 09:40 PM
WTT: My HKS Carbon Ti Catback for your ________ Catback! essteaeye Tri-State Area Private Classifieds 22 03-13-2006 08:34 PM
FS SoCal: HKS Ca/Ti Catback for WRX 02-03 WReXsy Private 'For Sale' Classifieds 22 09-10-2005 03:37 AM
HKS Carbon TI catback and HKS downpipe neversatisfied Private 'For Sale' Classifieds 22 11-05-2004 11:18 PM
Wanted: HKS Ca/Ti catback exhaust WReXsy Private 'Wanted' Classifieds 1 09-23-2003 03:58 PM
