Old 04-14-2013, 09:11 PM   #51
ZURCALED12
Member#: 309754
2012 Impreza Sport L
Ice Silver Metallic
News 2014 Crosstek XV Hybrid!
2014 XV Crosstek , They bolt right into our Impreza's
ZURCALED12 is offline   Reply With Quote
Old 04-14-2013, 09:26 PM   #52
scoutisimo
Member#: 315759
2014 WRX Hatch
Satin White Pearl
Installed the oe roof racks on my base. The silver cross bar ones that screw into the roof. Perrin stubby fits under their clearance nicely. I haven't noticed wind noise or anything. Perhaps a slight bit more drag. I wish they would make a deflector like thule and yakima do. Otherwise I am Loving the look but mainly purchased for my move to Phoenix in a few days. The kit is very nice and came with a t30 torx screwdriver for installation which now resides with my jack and spare tire. The racks are very very sturdy and seem of good quality thus far although I have yet to test them further than grabbing them and shaking the whole car with them.
I Will let you guys know if there are a lot of subis out in arizona as some were wondering since it is pretty much summer everyday. I'm starting to see them everywhere here in pa though. A lot of old people seem to be buying the sedan.
scoutisimo is offline   Reply With Quote
Old 04-14-2013, 09:35 PM   #53
ZURCALED12
Member#: 309754
Ice Silver Metallic
When you get a chance post some pics of your install see how it came out.
Old 04-16-2013, 04:10 AM   #54
kshiz
Member#: 352846
2013 Impreza Sport
ISM
Originally Posted by ZURCALED12 View Post
YES THEY ARE!
Exterior Auto-Dimming Mirror with Approach Light
MSRP: $199.95
Add to Cart
Your Price: $149.96
Description
Enhance your Auto-Dimming Mirror experience by adding the Exterior Auto-Dimming Mirrors with Approach Light.* Open or unlock the doors with the keyless entry system and LED lights located behind the Subaru logo in each exterior mirror help to light the way. Light is cast down all four doors and onto the ground next to and towards the rear of the vehicle. When in traffic, the Exterior Auto-Dimming Mirrors help add to a safer driving experience by reducing headlight glare on the exterior mirrors. This occurs when excessive light is detected from the rear of the vehicle. The dimming level of the exterior mirrors is regulated by the level of light detected by the Interior Auto Dimming mirror. *Requires accessory interior Auto-Dimming Mirror.
This item fits:
Forester 2014
Impreza 2.0i 2012-2013 *approach light only
XV 2013 *approach light only
Woah this is great news too! However does anyone know if the mirrors are pre-wired for the lights? Or maybe pre-wired from the connection coming out of the car. I can't check yet. My car is still on a boat here.
kshiz is offline   Reply With Quote
Old 04-16-2013, 06:14 PM   #55
ZURCALED12
Member#: 309754
Ice Silver Metallic
News There are for sure wires in the harness have to check them.
on my 2012 Impreza 2.0i Sport Limited the wires from the connector inside the door to the mirrors the wires are NOT present, but from the other side of the connector into the harness there are EXTRA wires in there, I need to test each wire and see what is what. I know that the signal Lens wires are in there that is how I wired up mine.
Old 04-17-2013, 01:11 AM   #56
Power6
Member#: 72730
2001 Lexus ES300,
2005 Outback XT
The description you posted shows compatible with the Impreza/XV for the approach lights (no dimming), if you search the part number J201SSG000 it seems everywhere states it is just 2014 Forester.
Typically with the 10-slot connector you have 9-pins in the car side, 3 for adjust, 2 heat, 2 signal, 2 power folding. SOA could have used the otherwise unused folding wires for the approach light, but there would have to be wiring with the taped up connector inside the mirror for it. Did you see that inside there?
Power6 is offline   Reply With Quote
Old 04-17-2013, 04:06 AM   #57
kshiz
Member#: 352846
2013 Impreza Sport
ISM
I'll try check when I get my car. Wire an LED into every unused pin until I find one that turns on with the dome light.
Old 04-17-2013, 07:04 AM   #58
RallySoob
Member#: 74872
2006 STi
White/Black
wow thats so nice. Thanx for posting
RallySoob is offline   Reply With Quote
Old 04-17-2013, 09:57 AM   #59
ZURCALED12
Member#: 309754
Ice Silver Metallic
News Correct wires for ............
I will test the wiring for the folding mirror when I get the harness from Power6 and post pictures of the correct wires to use. Subaru has a bad habit of changing wire colors from driver side to passenger side. And the approach light wires should also be in there, but I guess I will confirm this when I take the door panels off.
I am wondering if I am going to get power on the harness side when I turn on or off the alarm from the FOB/Remotes for the approach lights while the driver's side door is open? Also, I should have power for the fold and unfold mirror option as well. If theses wires are present, we are gonna have some nicely equipped Imprezas!
Old 04-17-2013, 10:01 AM   #60
ZURCALED12
Member#: 309754
Ice Silver Metallic
Unhappy No wires tapped inside mirror.
On the mirror side there are no extra wires. There are no wires tapped up at all. But on the harness side there are extra wires there, just need to test them out and see what is what.
Old 04-18-2013, 01:22 AM   #61
Power6
Member#: 72730
2001 Lexus ES300,
2005 Outback XT
The only way that the accessory would likely be compatible is if the wiring is there, through the mirror plug, into the mirror and there is a taped up connector inside it. Subaru only makes accessories that are plug and play. So based on that being missing, and there being only a 10-slot connector to the mirror, I am going to make an educated guess that the approach light mirror will not work out of the box you'd have to go custom.
You can't check for the folding function, the wires are dead it is tied back to some missing wiring under the dash and the switch which is not present in your car.
I have various service manuals including the '12 Impreza. The wiring pins have not changed the 10-slot or 8-slot connector which would have 7 or 9 wires on the car side and here are the pin locations and what they are with the typical wire colors used on the mirror side:
Base:
1 - Signal (+) (white)
2- Folding(out) (brown)
3- Common (blue)
4- Signal (-) (green)
5- Folding (in) (grey)
6- Up/down (pink)
7- Right/Left (purple)
8- **Unused**
Premium:
3- Common (blue)
4- Heat (black)
5- Signal (-) (green)
6- Folding (in) (grey)
7- Up/Down (pink)
8- Right/Left (purple)
9- **Unused**
10- Heat (black)
Old 04-20-2013, 05:26 PM   #62
ZURCALED12
Member#: 309754
Ice Silver Metallic
The wiring table is very helpful I got my package today, when I get home I am going to take the door panels off and remove my mirrors, I am going to count the wires on the connector. And make a note on the wires and colors. The swap should be an easy one since I did not do a permanent wire up. See picture below
Old 04-20-2013, 07:58 PM   #63
Power6
Member#: 72730
2001 Lexus ES300,
2005 Outback XT
Great! Let me know if the length works I am holding off cutting and crimping the wires on my new harnesses here until we know the length is good.
The colors I posted will match the mirror side. The car side will probably be different colors, wouldn't be surprised if the colors match the earlier years, but so far the pin locations are always the same. Make sure there are 9 wires in each door side mirror plug, the 11-13 WRX/STI are "missing" the JDM folding wires on the passenger's side.
Old 04-20-2013, 08:41 PM   #64
MackDaddy
Member#: 15451
2016 Accord EXL Navi
Lunar Silver
Oooh, progress! Good to hear guys. My mirrors will be here next week!
Edit: while we're at it, do we HAVE to pop the mirror glass off to get the "scalp cap" off? That's what the service manual says, and I've yet to try. Just curious...
Thanks!
MackDaddy is offline   Reply With Quote
Old 04-20-2013, 09:33 PM   #65
ZURCALED12
Member#: 309754
Ice Silver Metallic
Talking With very little effort the covers come right off.
Originally Posted by MackDaddy View Post
Oooh, progress! Good to hear guys. My mirrors wit be here next week!
Thanks!
No, All you have to do is move the glass a little bit and you will see one of the tabs from the mirror cover, and pry on it a little bit with a screwdriver or any object that would fit behind the glass and it should pop right off.
Old 04-20-2013, 09:48 PM   #66
MackDaddy
Member#: 15451
Lunar Silver
Excellent. Thank you sir.
Old 04-21-2013, 12:11 AM   #67
Power6
Member#: 72730
2001 Lexus ES300,
2005 Outback XT
Though taking the mirror glass off is very easy...
Old 04-21-2013, 01:14 AM   #68
MackDaddy
Member#: 15451
Lunar Silver
Good to hear as well. Are the harnesses getting close to production?
Thanks man
Old 04-21-2013, 08:57 PM   #69
ZURCALED12
Member#: 309754
Ice Silver Metallic
Well I did the passenger side first to check for the 10 pin connector. YES they have 9 wires on the harness side. And it's the 10 pin connector alright! I have the Sport Limited, so you guys with the premium would have to check your passenger side as well. I have to say this is fun to do and I quite enjoy the satisfaction of modding my subie. This time around I snaked the wires through the inside of the sleeve and into the mirror cavity. I will post some pictures in a few.
The two white wires is what I originally used for my retrofit, but after seeing the OEM I decided to go in one more time, the second time around is so much easier & I learned how to take the antire mirror apart too, very easy indeed. The white wires I used originally are way to big, an overkill really, there is not that much current going through these wires at all.
You are going to hold the 10pin connector from the mirror plug with the wires facing you,the press tab on top, pin#1 is on your right, connect the harness you got from "Power6" white (+) wire to that empty slot. And then pin#5 is right under it, connect the green (-) wire from the harness to that empty slot and you are done!
Here we got the wires from "Power6" these make the job so much easier. In my Original Post I pretty much worked with what I had on hand. This looks so much cleaner and OEM.
Old 04-21-2013, 09:24 PM   #70
ZURCALED12
Member#: 309754
Ice Silver Metallic
Yes, the wires need to be a little bit longer, like 3 inches longer. I will measure them when I am done. Having fun doing this to my subie!
Old 04-21-2013, 11:25 PM   #71
Power6
Member#: 72730
2001 Lexus ES300,
2005 Outback XT
Thanks man
Yes sir, just working a few things with ZURCALED12 we need to get the length just right, and there is the question of wire thickness, I may make a couple sets once length is set and send you out one to test too.
Old 04-22-2013, 03:48 AM   #72
ZURCALED12
Member#: 309754
Ice Silver Metallic
Pin #9 is going to be for my approach lights! I will post pictures on that mod at a later date. Oh, the possibilities! Thanks POWER6!!!!!
Old 04-22-2013, 04:57 AM   #73
kshiz
Member#: 352846
2013 Impreza Sport
ISM
Thanks for the updates and hard work!
Old 04-22-2013, 07:13 AM   #74
MackDaddy
Member#: 15451
Lunar Silver
No doubt! Thanks so much gents, this is great news!!
You're right, there's not much juice flowing to the turn-signal bulb, what you've got posted above from Power6 looks fine (gauge wise.)
Thanks again Zurcaled12 & Powe6, this will make a nice addition to the XV.
Old 04-25-2013, 12:22 AM   #75
Power6
Member#: 72730
2001 Lexus ES300,
2005 Outback XT
Assembled some signal wires tonight...
I'll PM the people who were asking about them.
